Z3ROT3CH Posted September 12, 2011 Report Share Posted September 12, 2011 hi this is my first posting on ratsun forum other than looking for a datsun. i was wondering what was better a weber 32/36 or weber 40 side draft. thanks for taking the time to answer my question. Quote Link to comment
flatcat19 Posted September 12, 2011 Report Share Posted September 12, 2011 2 completely different worlds. Quote Link to comment
Z3ROT3CH Posted September 12, 2011 Author Report Share Posted September 12, 2011 2 completely different worlds. im going to be buying a datsun here soon and the motor in it is a l18 with the 32/36 . but also has extra parts as in a cannon intake with a weber 40 side draft on it so was just wondering wat one was better . thanks for the reply Quote Link to comment
Laecaon Posted September 12, 2011 Report Share Posted September 12, 2011 That questions depends on what is better. What do you mean "better"? Quote Link to comment
I'm BLUE Posted September 12, 2011 Report Share Posted September 12, 2011 Is your L18 rig going to be a daily driver ? if so ,,, stick with the 32/36 ,,, it's a good carb ,,, for all around use/dependability ,,, :) If your planning on making your motor a little hopped up/hot ,,, then the Weber Sidedraft 40-dcoe (I'm assuming it's this or close to) ,,, is probably a direction you would look at going ,,, BUT ,,, IDK if the 40-dcoe is to big for what you are wanting/wishing to do !? They are both good carbs ,,, different applications period/potential/purposes :D The real question is ,,, what are planning to do ? Daily Driver the Rig ? Build a racer ? ,,, or looking for something in between ? ,,, for starters :) Good luck ! Quote Link to comment
Z3ROT3CH Posted September 12, 2011 Author Report Share Posted September 12, 2011 Is your L18 rig going to be a daily driver ? if so ,,, stick with the 32/36 ,,, it's a good carb ,,, for all around use/dependability ,,, :) If your planning on making your motor a little hopped up/hot ,,, then the Weber Sidedraft 40-dcoe (I'm assuming it's this or close to) ,,, is probably a direction you would look at going ,,, BUT ,,, IDK if the 40-dcoe is to big for what you are wanting/wishing to do !? They are both good carbs ,,, different applications period/potential/purposes :D The real question is ,,, what are planning to do ? Daily Driver the Rig ? Build a racer ? ,,, or looking for something in between ? ,,, for starters :) Good luck ! im looking to build in between to break loose if i wanna race and as my daily transport to and from work Quote Link to comment
Wide14u Posted September 12, 2011 Report Share Posted September 12, 2011 i think the 32/36 should be fine Quote Link to comment
banzai510(hainz) Posted September 12, 2011 Report Share Posted September 12, 2011 32 36 would be better for you. these are old cars .they break if beat on unless you have alot of spare parts like most of us. I have done 3 motor pulls on my 510 and 4 motor pulls on my 521. Key is RESOURCES!!!!!!good tools ect Quote Link to comment
racerx Posted September 12, 2011 Report Share Posted September 12, 2011 the question is "not better" but which one is more applicable/affordable. 32/36 will give you a little bit of performance, easy set-up/ maintainance, cheap and practical. 40 will give you some performance but will not max. effectiveness till you put cam, etc. A lot will depend on your budget, tech. know how..either way good luck. Quote Link to comment
Z3ROT3CH Posted September 13, 2011 Author Report Share Posted September 13, 2011 Alright thanks everyone for all the input ill go with the 32/36 till I get more time into looking at stuff for datsuns wish me luck will get pics up soon as the deal is made Quote Link to comment
flatcat19 Posted September 13, 2011 Report Share Posted September 13, 2011 Sell em both, and buy a 38/38. Quote Link to comment
ggzilla Posted September 13, 2011 Report Share Posted September 13, 2011 If the DCOE 40 has small venturis, it will be superior to the 32/36 in every way. Quote Link to comment
Z3ROT3CH Posted September 29, 2011 Author Report Share Posted September 29, 2011 thanks for all the replies guys sorry about neglecting this post. been busy on other posts. well i got my datsun for those who didn't see it ill attach some pics Quote Link to comment
