banzai510(hainz) Posted August 28, 2011 Report Share Posted August 28, 2011 maybe the lower intake bolts fell out? why run the fan all the time? If weber Carb adapter cracked? correct lower thermostat hoousing long bolt installed? if too long it pushes the tight side guide IN thus hitting the chain slightly Quote Link to comment
DISLEXICDIME Posted August 28, 2011 Report Share Posted August 28, 2011 awww yes good one hainz ! I have ran to long of a bolt on the thermostat housing and had it rub on the chain. Are you running a header? If so are the mounting point for the header the same thickness as the lower intake bolt mounting point? Quote Link to comment
.sunlover Posted August 28, 2011 Author Report Share Posted August 28, 2011 I just haven't bought the thermostatic switch for the fan yet, manual switch inside hides the smoke screen. wasn't able to check the adapter plate for a crack yet, no pcv valve, it would be louder with the oil cap off if it was rubbing internally, the header has been on this l20b head except when the heads been off for 300000 miles or so, however many since the mid 70s when it was installed by a mechanic originally. He was on the leading edge of the l20b head on an l16 and lightened flywheel btw. I'm remembering it being on the 2 pin, I think I tried whichever one was for a tight chain, but it needed the 2. not 100% sure a bolt didn't back out, just a quick check on that, I relaxed when I found it not to be an internal rubbing, went in and appologized to my GF for being irritated, and hung with my kid some. now it's dark, and i'm hitting it fresh tomorrow, starting with the intake/exhaust starting with the carb adapter. thank god for pb blaster, antisieze, Ratsun, and forgiving GF's :) Not in that order though. Quote Link to comment
banzai510(hainz) Posted August 28, 2011 Report Share Posted August 28, 2011 if a tensioner popped out cocked that could cause it to waer wrong and whine. key is a whistlse or a whine sound. Quote Link to comment
datzenmike Posted August 28, 2011 Report Share Posted August 28, 2011 He said he took the oil filler cap off and the noise didn't get worse or louder. Quote Link to comment
Just Joel Posted August 28, 2011 Report Share Posted August 28, 2011 throw out bearing, or pilot bearing? Quote Link to comment
.sunlover Posted August 28, 2011 Author Report Share Posted August 28, 2011 throw out bearing, or pilot bearing? [/quote these were also replaced. Seems to be coming from the engine Quote Link to comment
datzenmike Posted August 28, 2011 Report Share Posted August 28, 2011 throw out bearing, or pilot bearing? Easy to check... Release bearing isn't spinning and crank and tranny input shaft are turning together any time the clutch is engaged with peddle up.. Quote Link to comment
.sunlover Posted August 29, 2011 Author Report Share Posted August 29, 2011 Wayno advised clutch in and out test, and no change in whistle or squeel, whatever it is, I can't differentiate. noticed a missing shared intake/exhaust bolt today. Need a fat washer before the bolt to replace and see if it seals again without replacing gaskets, got some in my work toolbox (tomorrow night). Occupied myself adding a Nordic helm of awe to my windshield, and running new tubing for the pissers, and the smoke screen. Didn't get to the ultra coil upgrade today, gotta drill mounting holes, just figured where and how i'll mount it for today. Got the GF and son here this weekend, so didn't want to be rude. Thanks mike, with all the answers you've had for others, I was kinda' suprised you didn't have an itemized list of what it could be. I am a mechanic, but this is a new and strange problem, whistle or squeel that drags down rpm's and isn't internal, or alternator/water pump/belt when everythings new and fresh. Guessing intake is letting in air after carb mixes it up just right and dropping the idle down. It revs slower and with less fierceness I also noticed. Quote Link to comment
.sunlover Posted September 9, 2011 Author Report Share Posted September 9, 2011 It was my adapter bracket for my weber, 73 bucks in wasted money, and there it was. Forgot it shared 2 bolts with the stock mount, eliminated it from my troubleshooting when I grabbed my carb, and it was tight. now, I know. Hope this saves someone 73 bucks sometime in the future. All I needed was a retorque, 0 dollar fix. Quote Link to comment
