JasonGW Posted August 26, 2011 Report Share Posted August 26, 2011 So I've decided I'm not going to put the old, rusty-ass exhaust pipe back into my 210. However, I'm going to stick to the 1.5" pipe, as it seems that's the best way to ensure fuel economy is maintained (according to some threads here). Question is, can you just assemble your own? I notice that several of the local parts places have exhaust chunks, but is it a good idea to do that? Last thing i wanna do is screw it up :). Thanks! Jason Quote Link to comment
NOTES... Posted August 26, 2011 Report Share Posted August 26, 2011 U can.. but depends on ur welding skills.. clamping them isnt the way to go... But to have it looking clean u would need long piece of pipe and bent it... Quote Link to comment
Gary Posted August 26, 2011 Report Share Posted August 26, 2011 if you can weld, go for it if you cant, an exhaust shop will knock up something that'll do the trick perfectly, wont take long either :D Quote Link to comment
SR20-620 Posted August 26, 2011 Report Share Posted August 26, 2011 if you can weld and you have a chop saw, a grinder, and some files. Cut pie cuts on the chop saw @ 15* ANGLES, 2 15's make a 30, 3 a 45 and 6 a 90 etc etc. this way you can make bends on your own. google pie cut exhaust Quote Link to comment
racerx Posted August 26, 2011 Report Share Posted August 26, 2011 From my exp., I would take it to a muffler shop...i've installed exhaust systems on ol skool cars with u-bolts and somehow they don't look right and leaks.. Quote Link to comment
MikeRL411 Posted August 27, 2011 Report Share Posted August 27, 2011 Modern American spec inch and a half exhaust pipe is way thicker and will last longer than the original Datsun pipes [although mine lasted 44 years!] and any real exhaust shop can bend, twist, cludge any configuration of original Datsun pipe run. I had a local shop fabricate a [never really was stocked as replacement parts "they never wear out"] RL411 down pipe recently, they had to reuse the section from the flange to the vertical to horizontal transition due to the unique "deformation" of the original pipe into a "D" cross section to clear tires during left turns. Quote Link to comment
JasonGW Posted August 27, 2011 Author Report Share Posted August 27, 2011 Modern American spec inch and a half exhaust pipe is way thicker and will last longer than the original Datsun pipes [although mine lasted 44 years!] and any real exhaust shop can bend, twist, cludge any configuration of original Datsun pipe run. I had a local shop fabricate a [never really was stocked as replacement parts "they never wear out"] RL411 down pipe recently, they had to reuse the section from the flange to the vertical to horizontal transition due to the unique "deformation" of the original pipe into a "D" cross section to clear tires during left turns. Bizarre, but cool. I'll just take it in someplace. Think they'll let me bring my own muffler and cat? Speaking of which, I wonder if I should get a new cat. Muffler for sure, because it's got rust holes, but the cat looks fine (just ugly, but hell, it's underneath anyway :P). About how much should I expect to pay? Thanks! Jason Quote Link to comment
VintageRice Posted August 27, 2011 Report Share Posted August 27, 2011 Drive there and get a bid. Or just call them, how hard is that? Should get a quote right over the phone. Just ask them all the questions your asking us and get-r-dun. (did i just type get-r-dun?) :huh: Quote Link to comment
JasonGW Posted August 27, 2011 Author Report Share Posted August 27, 2011 Drive there and get a bid. Or just call them, how hard is that? Should get a quote right over the phone. Just ask them all the questions your asking us and get-r-dun. (did i just type get-r-dun?) :huh: I will, but I was just curious what others have paid :) Quote Link to comment
bananahamuck Posted August 27, 2011 Report Share Posted August 27, 2011 More cheap workmanship ahead if ya aint got the stomach for it please click away NOW !! Im building this to be cheap and on that note i am going to be putting most of the money spent on brakes and engine, so i made me an exhaust out of scrap today.Going through "the hole" would take either to much time or money so it exits out in front of drivers side rear tire..IMSA style baby Started with this pile of crap..and, what i think was a galvanized fence post ended up with this ( completely sealed ) pile of crap. Just do it !!................ Quote Link to comment
hang_510 Posted August 27, 2011 Report Share Posted August 27, 2011 Think they'll let me bring my own muffler and cat? Speaking of which, I wonder if I should get a new cat. if they don't, find another shop!!! i re did my stock to 1.5" for ~$120, muffler-no cat. if there is one now, you'll need it to pass the visual for smog. .. maybe :unsure: Quote Link to comment
