Clutch Problem?
Hello Fello Ratuners, Been A While Since I've Been On :hmm:
Lately I've Been Noticing That I Am Having To Push My Clutch Pedal All The Way To The Floor
(It Was Also Like This When I Bought It, But I Adjusted The Pedal's Play And There Weren't Any Problems)
Yesterday I Adjusted My Pedal Play To 1/4 Of An Inch And It Is The Same, I'm Not Grinding Any Gears (YET)
But I Want To Get Rid Of This Problem Before I Do
Maybe I Need To Bleed Or Change The Fluid....?
I Have Not Touched Anything, Transmission And Clutch Wise Since I Bought This Truck
Mostly Because I Have No Idea What The Hell I Am Doing When It Comes To Trannys (My First Stick Shift)
Any1 Know What's Going On? Help Is Greatly Appreciated :D
  • Replies 18
I Looked Down The Reservoir And There's Nothing
It's Not Dry But There's Not Much There
I Must Have A Really Small Leak Because It Took 10 Months For This To Happen
I Just Fill With DOT 3 Break Fluid, Bleed, Then Fill Again?
are you bleeding from the master cylinder (on top) or the slave cylinder (on bottom)...Check to see if your slave cylinder is not seized i had similar problem to yours a couple months ago and my slave was seized...replaced slave and was good to go. I figured it out by disconnecting the line from the master to the slave (put a towel cause it will squirt and this stuff is corrosive) and pumping the pedal. When i did this i was able to depress the pedal all the way and when connected the pedal had no play. Good luck
I Did This Yesterday And It Felt Brand New
But, Today I Went Out To My Truck, Started It, I Was About To Reverse And The Clutch Peddle Had No Resistance
So In My Mind I Was Like (RRRRRAAAAAAAAAAAAAAAAARRRRRRHHHHHHHHGGGGG :crying:)
I Started Pumping The Peddle And It Got Back To Normal :huh:
Does That Sound Bad?
Perhaps It Was Because I Used Synthetic DOT 3 Fluid? (That's All They Had)
I Guess I'm Back Where I Was....
I Do Get More Peddle Movement From Refilling And Bleeding, But There Is Still Some Play.
http://www.youtube.com/watch?v=m_i8l3-HW98
This Is Also Leaky, I Was Thinking About Replacing It Since It's Cheap Along With The Hose
http://www.rockauto....o.php?pk=484023
http://www.rockauto....o.php?pk=483881
I'm Positive The Hose Leaks, Now That I Bled The Line There Was A Big Puddle Of Fluid Under Truck This Morning...
So I'm Back Where I Started.... <_<
I Already Ordered Slave And Hose, Might Be In Wed Or Thrs.
That Should Fix Problem Forever (Or At Least A Long Time)
Ok, Got My Parts Yesterday...
So Now It's FRIDAY, FRIDAY!♫, Removed Parts And Gonna Install New Ones Now...
Just One More Question...
Is It Bad To Use Synthetic DOT 3 Fluid? Only Other Thing I Can Find Is Vatozone Fluid (I Know It's A Big NO-NO On Old Motors But Clutch/Break Systems?) :unsure:
