banzai510(hainz) Posted May 10, 2011 Report Share Posted May 10, 2011 blackdeth666 since you lowered your truck alot ai assume you got a spacer for the carrier bearing so you dont side load it up? between frame and under the bearing. More or less push bearing up a inch or so? I went to NAPA yesterday looking for that timming kit. She picked out like a Over 100$ one. I said a guy just got one for like 70$ from Napa. Then she looked better and found the 70 $ kit. Then she showed photos of the more expensive kit and it was a 3 hole sprocket. Where you might not see the V notch. where the cam dowl goes thu you should have a hole above it to see!!!!!! The cheaper kit shows the muti hole sprocket. She gave me a ATM part Number so I ordered it . Im hoping its a OSK brand. I think the 4 hole nissan ones are still the best. However since I work at Boeing I got a Discount and the timming kit is only 53$ so Now Im really scared if this is a made in Thailand kit cause how much Profit can one make on a 50$ timming kit???????But if made in Japan I will buy a few more spares. Quote Link to comment
blackdeth666 Posted May 13, 2011 Author Report Share Posted May 13, 2011 I do need to space the carrier up still, that or if there any 1pc drivelines that will bolt right up? Well I got it all put back together last night and it runs BETTER THAN EVER!! engine idles super smooth and quiet. Didn't do the valve guide seals because my friend said it could be the pcv valve thats making it smoke. Unplugged that and it still smokes. Fuck! Quote Link to comment
blackdeth666 Posted May 13, 2011 Author Report Share Posted May 13, 2011 The part number on my receipt is 053 90200 Quote Link to comment
banzai510(hainz) Posted May 13, 2011 Report Share Posted May 13, 2011 Yeah it was a OSK brand chain kit. the sprocket could fit on the dowl better. little loose. yeah get that carrier bearing lifted those are getting hard to get and could cause a noise of load on the trans. ont get a 1 pc driveline. carrier bearis there to keep it straight. just loose and see where it wants to go and make a specer and maybe get new bolts. PVC valve???? I never see go bad just clean them. Quote Link to comment
blackdeth666 Posted May 14, 2011 Author Report Share Posted May 14, 2011 Made some spacers today out of 1"square tubing and got some longer bolts to put them in. could that have caused a transmission leak? Quote Link to comment
HRH Posted May 14, 2011 Report Share Posted May 14, 2011 You know, I don't like the 8 hole gears. I haven't seen any wear on cam sprockets to speak of, so I keep using the old 4 hole iron cross gears from whatever L motor I have laying around. Think it came off a pull and save motor. I've had it on the 510 since I built the motor, works great. I think I did use the 8 hole gear on the KAZ24 though, just because I didn't have another iron cross gear laying around. Good one like this: Quote Link to comment
banzai510(hainz) Posted May 14, 2011 Report Share Posted May 14, 2011 HRH that is a good sprocket just cant figure out why soembody redrilled unless its was a race motor. then people redrill them or pbuy the Compitition sprocket but really those people know how to set up their timming and dont worry about those people. I just reccoment the EZ to understand newbie sprockets in case there off a tooth and it EZ to spot. If my sprockets get sharp I change them. But yes I used the old ones also if they fit titie on the dowl. I like the 4 hole better also. Blackdeath666 If alot angle is on the trans ut put shaft I guess it coul leak but im thinkinf its leaking cause it just old. Try to find a output trans seal the has the 2 inner ridges. The SKF ones I seen a only one lip. I have one of these and leaky already. Nissan and other will have the twin lip ones Do this while you have drivline out and youll see how the 521 has the 4 bolt flang up from and then youll see a big 22mm nut or close to it to pull off and pry the old seal out and pound in ta new one with a pc of woord or soemthing. oil it up before install Quote Link to comment
Sealik Posted May 14, 2011 Report Share Posted May 14, 2011 HRH that is a good sprocket just cant figure out why soembody redrilled unless its was a race motor. then people redrill them or pbuy the Compitition sprocket but really those people know how to set up their timming and dont worry about those people. I just reccoment the EZ to understand newbie sprockets in case there off a tooth and it EZ to spot. If my sprockets get sharp I change them. But yes I used the old ones also if they fit titie on the dowl. I like the 4 hole better also. Blackdeath666 If alot angle is on the trans ut put shaft I guess it coul leak but im thinkinf its leaking cause it just old. Try to find a output trans seal the has the 2 inner ridges. The SKF ones I seen a only one lip. I have one of these and leaky already. Nissan and other will have the twin lip ones Do this while you have drivline out and youll see how the 521 has the 4 bolt flang up from and then youll see a big 22mm nut or close to it to pull off and pry the old seal out and pound in ta new one with a pc of woord or soemthing. oil it up before install Ya...Matt drilled another whole Now that would be retarding the cam???? Quote Link to comment
4xs Posted April 18, 2013 Report Share Posted April 18, 2013 is it ok to set a new chain on the # 1 hole Quote Link to comment
datzenmike Posted April 18, 2013 Report Share Posted April 18, 2013 L20Bs came from the factory on the number 2 hole. Running it on #1 will retard the cam timing. This could adversely affect running and mileage. Quote Link to comment
racerx Posted April 18, 2013 Report Share Posted April 18, 2013 so OSK is best for the money? will keep this in mind in case I have to do this later..thx. Quote Link to comment
banzai510(hainz) Posted April 18, 2013 Report Share Posted April 18, 2013 OSK is OK. Tsubaki is like the nissan sprockets. My last OSK the sprocket dowl hole was a little bigger than the dowl on the cam . Was a slight wiggle. so the v would most likely be more to the right as I tighten the bolt down. I pulled it off and put another Nissan sprocket I had laying around. Quote Link to comment
racerx Posted April 18, 2013 Report Share Posted April 18, 2013 OSK is OK. Tsubaki is like the nissan sprockets. My last OSK the sprocket dowl hole was a little bigger than the dowl on the cam . Was a slight wiggle. so the v would most likely be more to the right as I tighten the bolt down. I pulled it off and put another Nissan sprocket I had laying around. These are the little things that make a difference...thanks. With being slightly over to the right, could this be a reason why some are off, even they are TDC with the dist. Quote Link to comment
banzai510(hainz) Posted April 19, 2013 Report Share Posted April 19, 2013 it s a minor difference that one has to take note. not enought o move a tooth or anything. The distributor can be adjusted by loosening the plate on the back side and ajust the timming plate. Quote Link to comment
