Bunchy Posted May 21, 2011 Author Report Share Posted May 21, 2011 My new alarm system (pico) :D Quote Link to comment
Bunchy Posted May 22, 2011 Author Report Share Posted May 22, 2011 Did some stuff to my goon today..:cool: Quote Link to comment
Bunchy Posted May 22, 2011 Author Report Share Posted May 22, 2011 I want it lowered... :rolleyes: Quote Link to comment
banzai510(hainz) Posted May 22, 2011 Report Share Posted May 22, 2011 Lower go with 2 inch blocks and DO NOT REMOVE !!!!any leafs.Lower looks cooler on wagons but sucks .youll hit the drivleine in the tunnel. Remove to many leaf you get axle wrap. then drop the front a bit more to to give the rake look. But I thought you needed a new clutch? i think you sould sell me this wagon Quote Link to comment
Bunchy Posted May 22, 2011 Author Report Share Posted May 22, 2011 how would i lower the front? Quote Link to comment
banzai510(hainz) Posted May 23, 2011 Report Share Posted May 23, 2011 got 250- 350$ bucks. do coil overs bell tech bolcoks are cheap. they have 1,2 and 39with 2 deg slant for diff angle) I would go 3 inch but ZNot sure ow muchtravel you loose untill you hit the tunnel. that why I say go with 2 in back and drope the front maybe 3. But you have a common year which has most like like the longer strut. thus you can only cut the stock spring so much untill you bottom out then that chear alternator bolt in the L16 as they are smaller(unless you got a L18/20 in there and they have bigger alternator bolts. ask another Datsun guy to help you out locally. this is the best way to learn and dont be in a rush. Quote Link to comment
Bunchy Posted May 24, 2011 Author Report Share Posted May 24, 2011 I beat my Dad in a bet today for 250$...:D What should i buy for my GooN? Quote Link to comment
skunk Posted May 24, 2011 Report Share Posted May 24, 2011 some gray car not just "some gray car" its a datsun 610. cool wagon, if you got 250 to spend i would go for http://portland.craigslist.org/clc/pts/2387284387.html http://portland.craigslist.org/clk/pts/2384945574.html or get some of the parts you need to lower it. Quote Link to comment
Bunchy Posted May 24, 2011 Author Report Share Posted May 24, 2011 I have 850$ to spend on my goon so i wanna lower it or get a Ka24 Quote Link to comment
hobbes_the_cat Posted May 24, 2011 Report Share Posted May 24, 2011 Don't go jumping into a motor swap. lower it, and a get new clutch. look at what ground control has for coilovers. don't just throw money at it, think about what you want the car to be finished, and work towards it. Quote Link to comment
Icehouse Posted May 24, 2011 Report Share Posted May 24, 2011 I have 850$ to spend on my goon so i wanna lower it or get a Ka24 Get some enjoyment out of your rig before you go jumping into a motor swap. We've all had to surfer L series in our life. It's your turn to put in a year or two. That way you will appreciate the beauty of EFI and the low end torque of a 2.4L. Get it to daily driver status fix, the little things then when your sure you've read everything there is to know about a KA swap, read more then decide if that's the route you want to go. Quote Link to comment
Rustina 510 Posted May 24, 2011 Report Share Posted May 24, 2011 I would go suspension, drop that ride, plus when you do get around to doing a Ka or sr, vg or even rb swap Wich are heavier motors, your upgraded suspension will be able to handle the bigger load. Or do a brake upgrade too, it's great and important to get these done if your really planning on doing a bigger power plant Quote Link to comment
banzai510(hainz) Posted May 24, 2011 Report Share Posted May 24, 2011 I think I should sell my 510 convertable and get this wagon.Its clean and straight. You know how to use a volt meter/ohm meter and test light? Learn that first before even thinging about a motor swap. and plan on spending 2k to do it right. Otherwise just drive it. Man I love this car, cant believe it made it almost 40years and never hit thru snow and ice on the road ect... this car should be garaged Quote Link to comment
Bunchy Posted May 24, 2011 Author Report Share Posted May 24, 2011 I will probably end up doing suspension brake stuff first but i have no clue on what to do as for as the setup and what i need to buy. Quote Link to comment
banzai510(hainz) Posted May 24, 2011 Report Share Posted May 24, 2011 it depends on what strut you have or going to have and wheel options(Offsets) your going to use. Quote Link to comment
Bunchy Posted May 24, 2011 Author Report Share Posted May 24, 2011 what strut do you recommend? Quote Link to comment
The Dat-side Posted May 24, 2011 Report Share Posted May 24, 2011 Get some 280zx struts and brakes. Shortenthe struts to take 200sx inserts or MR2 or Rabbit. Get coil overs and camber plates. And while everything is apart see if you need or just go ahead and replace balljoints, tierod ends, an basically anything else you may need. That'll take care of the front. Better suspension and better brakes. The rear, lowering blocks as described above. Quote Link to comment
Bunchy Posted May 24, 2011 Author Report Share Posted May 24, 2011 Where could I get some 280zx struts? Quote Link to comment
hobbes_the_cat Posted May 24, 2011 Report Share Posted May 24, 2011 search the classifieds here or go to the wrecking yards. there is more than a few threads about what to look for and what modifications to make to the struts.;) Quote Link to comment
banzai510(hainz) Posted May 24, 2011 Report Share Posted May 24, 2011 Bunchy Cut 1.5 coils and see low that looks. Wont cost you anything. Dont go any more as the long strut(if that what you have) will bottom out sooner. Might be a MOFO to take out as the spring is so long.best to have a good toolset at least a Craftsman. Pull the brake calipers place them to the side. 17mm pull the lower 2 bolts to A arm 3 bolts on top of strut. If you never hit the brake you can slide the caliper back on when re assembling. But it me I would put new brakes on and get new shocks but that me. I dont know what strut size you have but assume the common long strut. Quote Link to comment
Bunchy Posted May 25, 2011 Author Report Share Posted May 25, 2011 How do i get this stupid rusted stripped nut off please help anyone!!! Quote Link to comment
Bunchy Posted June 3, 2011 Author Report Share Posted June 3, 2011 The bottom one it connects to the fender... Quote Link to comment
Laecaon Posted June 3, 2011 Report Share Posted June 3, 2011 First lots of PB blaster. Over the use of the day. Hit the back side as well. But I will tell you this. That bolt head will shear off. If you can get the socket on just take it off. You might need vise grips. Once the head has sheared, pull the fender off, and use the vise grips on the remaining portion of the bolt on the back side. I had 4 bolts on each fender simply shear off. Quote Link to comment
banzai510(hainz) Posted June 5, 2011 Report Share Posted June 5, 2011 why pulling the fender ? Car is fine way it is Just roll it!!!!!!!! Quote Link to comment
hobbes_the_cat Posted June 7, 2011 Report Share Posted June 7, 2011 I think fixing the clutch should be the priority, not tearing it apart... Quote Link to comment
