Head gasket modification
68Datsun510
Hey folks, using a Z22 H/G on a big bore L18. Timing cover gasket area has already been modded to not leak. But, as some know, the Z22 and L engines dont have the same coolant ports and oil drain holes.
Should every single coolant hole be drilled to match the L head and block?
Thanks!
  • Replies 8
