Topher88 Posted April 20, 2013 Author Report Share Posted April 20, 2013 Sickness! Canby? If I feel all is up to par I hope to make it up there. It's something I have wanted to do for a few years. My L20B was so tired I never wanted to risk it. Now I should have a relatively reliable car :) Quote Link to comment
Topher88 Posted April 20, 2013 Author Report Share Posted April 20, 2013 Still gotta get it dyno tunned? im guessing? wich reminds are u using a stock sr ecu? I have an Emance tune. Johns going to plug it into his computer and make sure all is ok. I have heard ALOT of bad things about Emance so fingers crossed! I'm running 810 injectors so I had to get a new map Quote Link to comment
sedition88 Posted April 20, 2013 Report Share Posted April 20, 2013 If you've heard bad things about the Emance tune, why are you sticking with it? Quote Link to comment
Topher88 Posted April 20, 2013 Author Report Share Posted April 20, 2013 I head all the stuff after I got the tune. Quote Link to comment
Topher88 Posted April 20, 2013 Author Report Share Posted April 20, 2013 I hope all is well... Quote Link to comment
Topher88 Posted April 20, 2013 Author Report Share Posted April 20, 2013 Triple post. FIRST ON PAGE WHOOOOO Never understood that ^ Quote Link to comment
sedition88 Posted April 20, 2013 Report Share Posted April 20, 2013 Makes sence then. I hope it goes well for you too. GL! 1 Quote Link to comment
El Compa_510 Posted April 20, 2013 Report Share Posted April 20, 2013 good luck, what i did when i stroked and went with a bigger blower on my cobra i was concerned of driving it to the tune shop, so after i tighten everything i towed it straight to the shop, thats what ima do with my dime just to be on the safe side, especially since u have alot of upgraded parts bro... but im cheering for you 1 Quote Link to comment
Josh K. Posted April 21, 2013 Report Share Posted April 21, 2013 Be very careful. You should be able to look at the timing maps and tell if its even in the ball park. Josh- 1 Quote Link to comment
El Compa_510 Posted April 21, 2013 Report Share Posted April 21, 2013 yah bro make sure everything is timed and everything tidy, im always a lil nervous when firing a freshly rebuilt engine, especially boosted, just keep an eye on that air to fuel and timing u should be fine till u dyno tune it bro Quote Link to comment
Topher88 Posted April 21, 2013 Author Report Share Posted April 21, 2013 Ya johns gonna plug it into his PC and check everything out Quote Link to comment
Josh K. Posted April 21, 2013 Report Share Posted April 21, 2013 After I went with a nistune ecu I took a look at the last tune emance sent and looking at the timing map I would've blown the head straight through the hood... I was living in Maui at the time and would've been real pissed if I scattered my motor.... When is fire up? Quote Link to comment
aintnobiscuit Posted April 21, 2013 Report Share Posted April 21, 2013 You're probably fine. You can always datalog and watch your Wideband. You see something you don't like, just adjust it based on the datalog. I'm super happy for you buddy. Can't wait to hear this thing 1 Quote Link to comment
72dyme Posted April 21, 2013 Report Share Posted April 21, 2013 Man, John is bad ass when it comes down to the wiring. He knows wxcatly what hes doing. You know it is in good hands, can't wait to see it running. Maybe the OC meet 1 Quote Link to comment
Josh K. Posted April 21, 2013 Report Share Posted April 21, 2013 Its not the afr's as much as the timing map. The Sr likes a lot of timing off boost and you have to pull it out real fast as the boost comes up. The real trick is getting the timing right in that transitional area and where the experience of the tuner shows. A load dyno with good knock detection is the only way to tune IMHO. Josh- Quote Link to comment
Topher88 Posted April 21, 2013 Author Report Share Posted April 21, 2013 Its not the afr's as much as the timing map. The Sr likes a lot of timing off boost and you have to pull it out real fast as the boost comes up. The real trick is getting the timing right in that transitional area and where the experience of the tuner shows. A load dyno with good knock detection is the only way to tune IMHO. Josh- Once I put on about 500-800 miles on the motor I'm going to get it dyno tuned. I already have a guy lined up that is someone I highly trust with my car. Quote Link to comment
Topher88 Posted April 21, 2013 Author Report Share Posted April 21, 2013 Man, John is bad ass when it comes down to the wiring. He knows wxcatly what hes doing. You know it is in good hands, can't wait to see it running. Maybe the OC meet When's the OC meet? I don't know if I want to take the car on the freeway simply because I want to have as much RPM changes as possible for the first 5-800 miles. But I would totally be down to take side streets all the way to the OC haha Quote Link to comment
aintnobiscuit Posted April 22, 2013 Report Share Posted April 22, 2013 I don't have specific experience with the SR but that sounds like most motors. I wasn't advocating driving it hard or anything, i was talking about driving it to get it properly tuned. I just spent some time with a base map on my haltech and did some datalogging then adjusted it enough to drive it off boost to the dyno. That's not saying much since the dyno i use is only 5 miles away :) I agree with you on the knock box. You NEED to have one if you're going to tune the ignition because that's how you get all your torque. Quote Link to comment
SR20DETdatsun510 Posted April 22, 2013 Report Share Posted April 22, 2013 Dynopak or similar is the way to go... Quote Link to comment
Topher88 Posted April 22, 2013 Author Report Share Posted April 22, 2013 Before and after Quote Link to comment
SR20DETdatsun510 Posted April 22, 2013 Report Share Posted April 22, 2013 Nice. A world of difference! 1 Quote Link to comment
El Compa_510 Posted April 22, 2013 Report Share Posted April 22, 2013 i just got a hard on lol 1 Quote Link to comment
Topher88 Posted April 22, 2013 Author Report Share Posted April 22, 2013 This is my brake in prosses what do you guys think? run normal 10w30 for the first start up till the motor gets warm then let it cool down fully. Once its cooled down put normal 10w30 for the next 150 miles. at 150 do another oil change but this time I'm going to put 15w50 full synthetic mobile one. Then drive it for 500 miles and another oil change. then drive to 1000 and another oil change then dyno tune and done Quote Link to comment
aintnobiscuit Posted April 22, 2013 Report Share Posted April 22, 2013 Looks amazing! Before and after is epic! I dont think you need to go do that many oil changes, but you should use break in oil. John did tons of research on it and i'm sure he'll chime in :) Quote Link to comment
