How to KA throttle cable in a 510
Guest kamakazi620
Guest kamakazi620
So i'm KAing my 510 goon,and i found that a 240sx 1989 to be exact works very well.Heres what i did..............................
factory throttle rod
240sx throttle rod/pedal
here they are side by side
I bolted the 240sx in with one bolt/screw it seems to hold fine
next is the 240sx cable
Notice the ears on the bracket,I trimmed them off to fit it flush against the firewall
and i ran the cable threw the factory throttle hole in the fire wall,make sure and remove the grommet
I will later drill 2 holes to mount the cable assembly to,and use 2 small bolts with 4 nuts to make studs to bolt it to
here is the pedal assembly in the car
at full throttle
you will also have to bend the rod back about an inch with a box end wrench or "dogbone" wrench to take up the slack.
  • Replies 11
y not just weld 2 bolt on. drill holes for them like u plan on and put a nut on them to hold tight, then put 2 lil tacks on the head of each bolt. remove nuts and u have studs that u can mount it flush on
and yes i qouted all the pics just for the ollz (no you didnt)
edit:someone (skib) fucked with the original, it had an epic pic repost
  • 1 year later...
