Jassifrass Posted February 14, 2011 Report Share Posted February 14, 2011 some ass hole smashed my rear window last night. so looks like im going to need a new one. as always the cheaper the better. Link to comment
datzenmike Posted February 14, 2011 Report Share Posted February 14, 2011 Fuck! See if you can find one locally. Link to comment
flyerdan Posted February 14, 2011 Report Share Posted February 14, 2011 Is this for a 710 wagon? I have one out of a '75. Link to comment
Jassifrass Posted February 14, 2011 Author Report Share Posted February 14, 2011 can you measure it for me? I can go check mine...ore whats left of it....and we can compare and find out! Link to comment
datzenmike Posted February 14, 2011 Report Share Posted February 14, 2011 Jess they should be the same for all years. There were only two ... with or without tint. Link to comment
Jassifrass Posted February 14, 2011 Author Report Share Posted February 14, 2011 Jess they should be the same for all years. There were only two ... with or without tint. Found two places in town that have one. both with out the defrost. would rather have one with the defrost, seeing that i live in Oregon. Link to comment
Jassifrass Posted February 14, 2011 Author Report Share Posted February 14, 2011 46 1/2 across the bottom 39 across the top 21 1/2 from top to bottom (in the middle) and 20 1/2 from top to bottom (on the side) Link to comment
Jassifrass Posted February 14, 2011 Author Report Share Posted February 14, 2011 found some glass for my wagon, thank you ratsun. Link to comment
skunk Posted February 14, 2011 Report Share Posted February 14, 2011 now we just need the gasket. any ideas?? Link to comment
Skib Posted February 14, 2011 Report Share Posted February 14, 2011 found some glass for my wagon, thank you ratsun. damn that was quick! Link to comment
datzenmike Posted February 14, 2011 Report Share Posted February 14, 2011 now we just need the gasket. any ideas?? Can't use the old one??? Link to comment
skunk Posted February 14, 2011 Report Share Posted February 14, 2011 old one looks ok, just want to have a new one if the old one is not going to work Link to comment
420n620 Posted February 14, 2011 Report Share Posted February 14, 2011 if you use the old seal, remember to get some soapy water in a spray bottle so the seal will slide in easier. Link to comment
Jassifrass Posted February 15, 2011 Author Report Share Posted February 15, 2011 Im not going to be able to put the new one in myself. I dont have tools or the know how so im taking it to a shop. I just need a gasket...or to take it in and have them check mine and see if they can re use it... Link to comment
tdaaj Posted February 15, 2011 Report Share Posted February 15, 2011 if you guys were closer i'd put it in for free, i usually get a bucket of hot soapy water the soak the old gasket in, makes it much more plyable. only tool you need is a piece or 1/4" nylon rope about 4 ft long. Link to comment
Rustina 510 Posted February 16, 2011 Report Share Posted February 16, 2011 It isn't hard to install windows, the hard part is not tearing the old gasket. Hope you can remove the chrom from the gasket with out messing up the rubber, a friend told Me it shouldn't be set in to deep. Link to comment
