zianian Posted May 6, 2013 Report Share Posted May 6, 2013 Keep watching. It'll be for sale again someday Might be sooner. Might be later. Btw... Me n baby blu went auto crossing yesterday. That was a mother humping BLAST. Car was AWESOME. Me.... not so much (yet). (Burn outs after your run ain't cool come to find out) It'll probably be later. ;) Quote Link to comment
zianian Posted May 7, 2013 Report Share Posted May 7, 2013 Choices choices. GoPro Hero 2 Black Motorsports Edition w WiFi BacPac remote. Or rear disc breaks. GoPro Hero 2 Black Motorsports Edition w WiFi BacPac remote. Or rear disc breaks. GoPro Hero 2 Black Motorsports Edition w WiFi BacPac remote. Or rear disc breaks. GoPro it is. Quote Link to comment
zianian Posted May 21, 2013 Report Share Posted May 21, 2013 Rear end clunks. Only when turning right from a stop. Especially from 1st to 2nd. It's getting worse :( Gotta baby them turns for now. No biggie... we'll catch up to you soon after we straighten the wheels and stomp gas thingy. Time to get to know my LSD. I think it's an LSD. Quote Link to comment
macgyver Posted May 21, 2013 Report Share Posted May 21, 2013 check your u-joints....had same prob a while back Quote Link to comment
510T Posted May 22, 2013 Report Share Posted May 22, 2013 Yeah you do not want one to let go... happened to me twice now. Quote Link to comment
zianian Posted May 22, 2013 Report Share Posted May 22, 2013 U joints and shafts seem solid as a rock. I have had and heard plenty of U joints in the past (not on 510s) and this seems different. What did your bad ujoints sound like? and when? all gears? R to 1st? Straight line or turns? Etc? Did they/it have much play/slop that you could feel/see from looking at and tugging at turning them? I have been reading up on the Subaru rear ends and it sounds like some of them are netorious for clunking on the right side. But I think that clunk has to do with upper right rear suspension components. Maybe diff bushing? Maybe suspension? Maybe in the diff? Maybe even u joints. lol Might try mounting the GoPro under there. See if it shows anything. Quote Link to comment
510T Posted May 22, 2013 Report Share Posted May 22, 2013 I'd check all of the above, my first u joint clunked for a little while out of 1st gear if I recall correctly before going and the second time it just went kablooey. Give the whole rear sub frame and driveline a good once over. Quote Link to comment
zianian Posted May 22, 2013 Report Share Posted May 22, 2013 Will do Baba. Thanks. Quote Link to comment
zianian Posted May 23, 2013 Report Share Posted May 23, 2013 I think I "fixed" it.. Jacked it up in the back for the first time. Gave it a once over. (darn... forgot to take pictures re: ID the diff). Didn't see anything outta sorts. Thought I might as well lower the rear end back down a bit to let it sit a bit lower. Sean raised it all around a few inches for the trip from TX. I lowered front a bit weeks back. 2" down... I think. 1" too much. It rubbed. F that. Put it away for the night. Changed dinner plans. But anyways... Before I lowered it I noticed where springs were rubbing on shock towers a bit. Lubed it in those spots. Just happened to buy a grease gun at a yardsale on Sat. Good timing. $2 Raised it up a bit again this morning. Drove it. No more clunk. Neat. Now onto why it bogs a bit at initial throttle commencement. Ran sorta funny ever since I got caught in that rain. And tuner... Call tuner. And drive. That goes without sayin'. Quote Link to comment
zianian Posted June 5, 2013 Report Share Posted June 5, 2013 Well after 4 years with the GS300 I grew bored of it and decided that I wanted something fun to drive for a daily again. So I promptly listed it around on a few forums and started looking for something. I wasn’t sure what I wanted at that point and was initially looking for a swapped SC300 or a well taken care of and modified 240. I later came across a thread somewhere with some bad ass OG Japanese rides and I then got hooked in the idea of owning one. At one point had a trade worked out for a 72’ Celica coupe in Kentucky but with bad timing and bad weather it didn’t end up working out before the guy had a cash offer for it. After a bit more looking around I happened upon this 1971 4dr from Cali that, in looks, reminded me of the Datsun my parents had when I was growing up. So I contacted the owner and worked out a good deal, put a deposit down on it and had it on the way here a couple weeks later. It finally showed up mid last week and man… this thing smaller than I remember! Being 6’2” 230 it’s a bitch to get in and out of but once you get seated there is plenty of room and it’s actually comfy. Driving it is a blast and the handling it has is way better than I had expected. It’s also a bit faster than I thought it was going to be and once the VVL kicks in the thing just screams. The crap tune it has is on it is rich as hell but it runs great, I haven’t had a chance to find a place to weight it yet but the guy said it was right around 2000lbs. With some cams, lightweight flywheel and a good tune this thing will be a beast. Body and panel wise it is very solid, some surface rust here and there but nothing bad. The interior is pretty much stripped aside from the carpet and door panels so driving in the rain is going to be LOUD! Motor and go stuff S14 SR20DE block with SR20VE NEO VVL head (11:1) R&D Factory high capacity oil pan Custom Danstoy intake manifold, AE111 ITB’s and T3 velocity stacks One off DGR equal length stainless 4-1 header Custom DGR aluminum radiator with 12" electric fan RCI aluminum overflow tank LS1 coilpacks 2.5" exhaust with stainless Magnaflow muffler S14 5spd with short shifter Modified S14 driveshaft 4:38 JDM Subaru LSD RCI aluminum 10 gallon fuel cell with walbro pump Electronics Haltech E6X EMS Custom S14 wiring harness Greddy oil pressure and water temp gauge Pivot 80mm tachometer Suspension MADDAT engine mount kit with 1" front swaybar MADDAT steering box brace S14 Meagan front coilovers on 280Z spindles Techno Toy rear coilovers Techno Toy RCA’s Techno Toy Camber plates Techno Toy tension control rods Cusco strut bar 280Z front disk brakes Interior Recaro SRD seats with schroth harnesses Nardi Deep corn 350mm wheel, ACR (Japan) Steering wheel adaptor and Works Bell quick release hub New carpet Odyssey battery/bracket relocated behind passenger seat I had a couple friends take some pics of it for me Saturday. We were only able to hit 2 spots that day so we’re going to shoot some more soon. Couple of edited pics "Driving it is a blast...." Your darn tootin' it is. Quote Link to comment
510T Posted June 5, 2013 Report Share Posted June 5, 2013 Did you figure out that gopro thingy yet? We want clips! :) (smoky loud ones) 1 Quote Link to comment
zianian Posted June 6, 2013 Report Share Posted June 6, 2013 Who wants to watch me go to the first yardsale of that day? lol Well here ya go Baba. (the same Saturday I went to the tuner/dyno guy... GoPro-ed that too) Quote Link to comment
zianian Posted June 10, 2013 Report Share Posted June 10, 2013 Had to come back to that place the next day... pick up 32" LCD TV. This next one is still boring. But we did get some crazy passin' in and some twists n turns n shit. Quote Link to comment
zianian Posted June 19, 2013 Report Share Posted June 19, 2013 My rear end is a lil' crooked. About an inch lower on passanger side. I think I need to adjust the fuel cell baffles. Quote Link to comment
zianian Posted July 12, 2013 Report Share Posted July 12, 2013 Let's hit up a church sale. ;) Quote Link to comment
Just Joel Posted August 1, 2013 Report Share Posted August 1, 2013 Another cryptic post... Not good :( 1 Quote Link to comment
zianian Posted August 1, 2013 Report Share Posted August 1, 2013 Wed 7-31-2013 R.I.P Baby Blu Quote Link to comment
zianian Posted August 1, 2013 Report Share Posted August 1, 2013 Thur 8-1-2013 We can rebuild it. Quote Link to comment
Tristin Posted August 1, 2013 Report Share Posted August 1, 2013 All that moping around for just a rear-end? 2 Quote Link to comment
510T Posted August 1, 2013 Report Share Posted August 1, 2013 We have the technology! :) Time for an r180 Quote Link to comment
macgyver Posted August 1, 2013 Report Share Posted August 1, 2013 What rear were you running? Key word: were Quote Link to comment
zianian Posted August 1, 2013 Report Share Posted August 1, 2013 I don't even know what is in it now. Subaru JDM is what the add said (also Sean's first post this thread I think). What was in there may have been welded? On gravel esp. and on turns it felt and sounded like the rear wheels would skip a bit. Like both turning at same rate. Same with calling the tow guy Bob. Straight yesterday was OK. Turn just a touch and it was clatter clack city. Called AAA. No large chips or shards or even many tiny ones. (seeable) gears look OK. Can't see inside that inner gear thing and even if I could I wouldn't know what I'm looking at... Yet. Called a few tranny/gear shops. Would love to be able to just (have them?) drop a new diff(?) unit in it. Stout one. One that won't clatter clank so much... ever. For a while anyways. Any drop in posi thingies ideas/advice? Thanks. Quote Link to comment
Tristin Posted August 1, 2013 Report Share Posted August 1, 2013 Theres lots of options. Give the search bar a good use... theres lots of "posi thingies." I would suggest that you figure out what they are called to aid in better results though... Quote Link to comment
