La Pitufa
Zeusimo
  • Replies 97
So My Truck Had Some Started Having Some Electrical Problems
Constant Misfiring, Stalling When Under Load, Dying Headlights
Turns Out It Was The Old 30 Amper
So I Bought A 60 Amper Meant For A 81' 510
It Was A Simple Swap But The Fan Would Hit The Radiator Hose So I:
Extended The Arm An Additional 1"
Got A Belt That Was 1/2" Bigger
And A Flexible Hose That Would Go Under And Around The Alt
Prepped For Cuttin' And Weldin'
Put Into Place
Tac Tak
Welded All The Way Around
Cleaned And Grinded Flush
My Final Clearance To The Idler Nut Was A Finger :lol:
Well The Engine Is Already In Tip Top Shape
But My Hitachi Is On It's Last Legs
So Right Now I'm Saving Up For Some Weber DCOE 40's And Manifold
^^ If That Doesn't Happen Then A 32/36 DGEV :(
Remove All Of The Smog And Eventually Get Another Hitachi To Smog It
Updates? No
Setadpu? Yes :lol:
My Hitachi Went To Carburetor Heaven January 12, 2011 Approximately 3:25ish PM :(
It Might Sit In My Back Yard For A While Since I'm Going Back To Japan In April And The Plane Ticket Alone Is $1300
So I Guess I'm Riding My Bike To School For The Next 3 Months <_<
My Primary Jet Went Out About 3 Months Ago And Welded A Few Pieces Together So I Could Run The Truck Off The Secondary Barrel...
But Didn't Last Too Long, Now It Won't Start Unless Someone Pumps Gas From Under The Hood
And When It Does Turn On It Idles At 200-300ish, Revs Up To 1k And Dies Under Load :angry:
oh damn, thats alot worse than my carb was, my stock carb only needs the float adjusted, so im just sellin it, you can get it for a good price if you want ;)
Well, Not Really An Update But I Found This Little Millermatic 150 On Craigslist For $100
The Owner Bought It For 500 Bucks, Used It Once And Had Been Sitting In His Garage For About A Year
He Said It Didn't Work But I Went To Go Look At It
It Was In Really Good Condition, Popped The Hood And Paid The Man
I Left Really Quick, Got Home, And All It Had Was A Bird's Nest :rofl:
Adjusted Everything And Ran A Quick Bead
Personally I Don't Like Or Trust MIG, But This Is Going To Make A Killer Tacker For Only $100 :frantics:
I Forgot To Take Pictures Of The Process But When I Re-Did My Exhaust On My El Camino I Recycled It's Old Exhaust On My 620 :P
2.25" Pipe, Magnaflow High-Flow Cat, Dynomax Muffler (Turbo Maybe???) And The Last 2 Feet Of Pipe Is 3"
I Will Get Some Video Once I Can Get The Truck Started <_<
  • 1 month later...
Haven't Updated In A While But I Bought A Weber That Had A Bad Gasket And My Rebuild Kit Came In Today, So I Rebuilt It :)
And Removed Smog Crap
Truck Is Still Not Running, Tomorrow I Will Make An Adapter Gasket And Plug All Vacuum Lines
If I Do Everything Right, Gonna Take Her For A Spin :D
I Put The Weber On My Truck And Had Vacuum Issues, I Got New Adapter Plate Bolts Because I Was Missing A Few.
Got Rid Of One Leak But I Have Another Leak Somewhere...
Gonna Look Tomorrow If I Have Time :blink:
