Mini-L320 Posted December 10, 2010 Report Share Posted December 10, 2010 Not a stock Fuel Gauge. Its a VDO Fuel Gauge. Have it wired up just like the stock one but doesnt seem to give me an accurate reading. When car is empty of Fuel, gauge reads 1/2. When car has full gas tank reading goes over "Full" on Gauge. when car has anything below 3/4 of gas thats when the Fuel Gauge Needle starts to go all over the place. The only time it doesnt move is when Tank is Completely Full :D Not making good Ground? Sender is Busted? Fuel Gauge is Bad? Where can I find a New Fuel Sender? Quote Link to comment
Mini-L320 Posted December 10, 2010 Author Report Share Posted December 10, 2010 Oh and I've had this Fuel Gauge put on since the beginning of summer. It just started bothering me now tho. ;) Quote Link to comment
wayno Posted December 10, 2010 Report Share Posted December 10, 2010 I do beleave that VDO type gauges need there own VDO senders also, I have never had a aftermarket gauge work with a stock sending unit. I have had a 1971 datsun gauge work properly with a 1984 nissan fuel tank though. wayno Quote Link to comment
izzo Posted December 10, 2010 Report Share Posted December 10, 2010 i believe its the ohms, you need the correct for it to work right? iirc 0-90 Quote Link to comment
datzenmike Posted December 10, 2010 Report Share Posted December 10, 2010 I do beleave that VDO type gauges need there own VDO senders also, I have never had a aftermarket gauge work with a stock sending unit. I have had a 1971 datsun gauge work properly with a 1984 nissan fuel tank though. wayno True. Getting one of these things safety approved must be expensive. Once a design is perfected why make a new one every year or for every car??? If the senders are the same the gauges must be similar in operation too. My '78 gad an '82 2wd and at least two 4X4 720 tanks in it and they all worked just fine. Quote Link to comment
Z-train Posted December 10, 2010 Report Share Posted December 10, 2010 Sending units/guages work off of "ohms".If they don't match-it ain't gonna work.Find out teh factory ohm rannge and then the VDO.If's it's a mismatch,well-there's yer problem,Vern. Quote Link to comment
Mini-L320 Posted December 10, 2010 Author Report Share Posted December 10, 2010 Sending units/guages work off of "ohms".If they don't match-it ain't gonna work.Find out teh factory ohm rannge and then the VDO.If's it's a mismatch,well-there's yer problem,Vern. Oops,totally forgot about checking the Ohms :P . Hey thanks you guys, :D Quote Link to comment
Mini-L320 Posted December 10, 2010 Author Report Share Posted December 10, 2010 i believe its the ohms, you need the correct for it to work right? iirc 0-90 Is 0-90 Ohm Range Pertaining to a 210 or any Datsun? Cause if it is, then i just found an Autometer Fuel Gauge Range from 0-90 Ohms :D Quote Link to comment
izzo Posted December 10, 2010 Report Share Posted December 10, 2010 I believe 0-90 is all datsuns, but not positive. i think 0-90 is actually a common range, i know autometer sells em, so must be popular? Quote Link to comment
Mini-L320 Posted December 10, 2010 Author Report Share Posted December 10, 2010 I believe 0-90 is all datsuns, but not positive. i think 0-90 is actually a common range, i know autometer sells em, so must be popular? Eh I'll try em out, Thanks. Quote Link to comment
datzenmike Posted December 10, 2010 Report Share Posted December 10, 2010 FSM: Full reads 10 ohm. empty reads 80 ohm. 0 to 90 ohm is close enough range. Quote Link to comment
Mini-L320 Posted December 10, 2010 Author Report Share Posted December 10, 2010 FSM: Full reads 10 ohm. empty reads 80 ohm. 0 to 90 ohm is close enough range. Oh Ok Nice, Thanks alot. :thumbup: Quote Link to comment
Paul G. Posted December 11, 2010 Report Share Posted December 11, 2010 FSM: Full reads 10 ohm. empty reads 80 ohm. 0 to 90 ohm is close enough range. Wow, that is true even for my '66 411! Full is 8 ohms and empty is 84 ohms. Quote Link to comment
datzenmike Posted December 11, 2010 Report Share Posted December 11, 2010 Yup. Once you get something working why re-invent or change it every year or model. Same with the oil pressure gauges. The 280zx, 200sx (S110, S12) 720, Maxima and likely the altimas sentras and any dash with an oil pressure gauge use the same sender on the block. All the ones I've seen are the same. Quote Link to comment
DeathByNissan55 Posted November 11, 2015 Report Share Posted November 11, 2015 Sorry to wake this from the grave, but would a fuel sender with 70 ohms empty, 10 ohms full, be too different than stock? I'd be using 77 datsun 280z stock fuel gauge, and according to you guys higher up, its 90 ohms empty and 0 ohms full. Quote Link to comment
datzenmike Posted November 11, 2015 Report Share Posted November 11, 2015 I get empty 80 ohms (or more)and full 10 ohms (or less). At worst it will read empty early but that's better that showing something in the tank. Quote Link to comment
Draker Posted November 11, 2015 Report Share Posted November 11, 2015 Could offset the reading with a 10 ohm resister if it's worth your time. Quote Link to comment
DeathByNissan55 Posted November 11, 2015 Report Share Posted November 11, 2015 For some reason, using the 70 E/10F makes the fuel cell I had planned out, a lil less than 100$ more.....I wonder why..... 90F/0E is cheaper, but then I guess I'd need to use an op amp or something.....Or just write the bottom leg of E over the F and paint the bottom leg of the E black so that it looks like an F haha. Quote Link to comment
