Rustina 510 Posted December 8, 2010 Report Share Posted December 8, 2010 I am building a 71 Datsun 510, this car is in pretty bad shape, I have been working on it every time I get a chance, while I'm not working on the car I am researching and hunting down parts. So I have been buying parts for months now and here is my idea. I purchased a L20b motor, compression rated it and I thinks it's good to go or at least start with while I improve it's abilities, I just found a good deal on a 200sx 5 speed dogleg tranny, The l20 will bolt righ onto the l16 mounts, but what do I need to do to get the tranny to mount up correctly? The car has the original l16 and automatic tranny "which is up for grabs" in it so will the new 5 speed bolt up no problem? Please help, any advice is appreciated Quote Link to comment
hobbes_the_cat Posted December 8, 2010 Report Share Posted December 8, 2010 the trans should bolt up no problem to the L20. the L20 has a bigger flywheel (225 mm i think) than the l18 and l16 tho, so make sure you get the right clutch parts to match your flywheel. Quote Link to comment
Rustina 510 Posted December 8, 2010 Author Report Share Posted December 8, 2010 It's a 1979 200sx tranny and from the research I've gathered, they are almost the exact same length as the l16 auto tranny! So it should fit the tranny mounts or the spot on the crossmember with no real issues right? Is 140$ a good price? Quote Link to comment
justin 620 Posted December 8, 2010 Report Share Posted December 8, 2010 140$ is a lil steep, but that's just my opinion. Quote Link to comment
datzenmike Posted December 8, 2010 Report Share Posted December 8, 2010 Yes the dogleg will physically bolt to the L16.................................................. ................................ but: Behind the automatic flex plate is a spacer that fits over the end of the crankshaft. This has to be removed. You will need to press a pilot bushing into the end of the crankshaft. The very front of the input shaft on the transmission fits and is supported by this bushing. You will need a 6 bolt flywheel. The majority are 200mm clutch disc contact surface if from a Nissan car and 225mm if from a truck. You will need a 200mm or 225mm clutch disc and matching pressure plate. Depending on the flywheel you decide on. A new release bearing... may come with the clutch. A release bearing retainer, housing or collar. It goes by many names ,and it clips to the clutch arm and has the release bearing pressed onto it. The dogleg may still have it on it. Be sure to replace the used release bearing. A clutch arm and dust boot.... It may come on the transmission. A clutch slave cylinder... may also be on the transmission. A clutch master cylinder. A hard line and flex line connecting the master to the slave cylinder. Clutch and brake peddles, springs, bolts and push rod to connect the peddles to the master. A shifter.... may come on the transmission. Do not forget to keep and use the metal plate that fits between the flexplate or flywheel and engine and is sandwiched between the motor and the transmission when bolted up. Quote Link to comment
Rustina 510 Posted December 8, 2010 Author Report Share Posted December 8, 2010 Hmm. Well it's the first one I found, I'm more worried about having to do mods to the crossmember or tranny mounts than the price, I want to make sure that this is as close to a straight bolt on swap for a 5speed as I can find. I will be puttin a L20b with a 1979 200sx dogleg tranny into a 1971 Datsun 510 that has a automatic tranny in it, ive never done this kind of job before and I don't wNt to vet in over my head. Ps, does anyone have a cherry picker and Saturday off work? Lol I'll buy the beer! Quote Link to comment
Rustina 510 Posted December 8, 2010 Author Report Share Posted December 8, 2010 My L20 motor has 6 holes for where the flywheel goes Quote Link to comment
datzenmike Posted December 8, 2010 Report Share Posted December 8, 2010 That they do, my bad. Quote Link to comment
Skib Posted December 8, 2010 Report Share Posted December 8, 2010 hey Rustina Iv got a bunch of extra L20B parts if your interested. Iv got a clutch set, flywheel, along with 2 short blocks to scavenge parts from got a 5 speed or two laying around too Quote Link to comment
Laecaon Posted December 8, 2010 Report Share Posted December 8, 2010 The dogleg will need light modification to your tranny mount. Buts its the simplest of the 5 speeds to put in your car. Im starting to gather parts to replace my auto tranny too with a dogleg. Quote Link to comment
Rustina 510 Posted December 8, 2010 Author Report Share Posted December 8, 2010 Hey skib do you have a dogleg in working condition I can get for less than 100$ Quote Link to comment
Skib Posted December 8, 2010 Report Share Posted December 8, 2010 I have a long tail one you can have for 80, gotta shorten the drive shaft tho Quote Link to comment
Rustina 510 Posted December 8, 2010 Author Report Share Posted December 8, 2010 Well it sounds like this is a good idea, i will need a bunch of parts aside from the tranny to make this work so if you have the nit bits and extra pieces I need let me know. If I can't find a tranny for a better price by Friday I'll go and get the one I already have in tow this Saturday or Friday. It's going pretty well, I got floor pans to buy Friday, a intake manifold for my dual 48mm su carbs and the linkage, the tranny Saturday, I already have the motor now, and most of the parts and tools to put it all together except for a cherry picker. Anyone have this weekend off work and have a cherry picker? Lol I'll buy the food and beer! Quote Link to comment
Skib Posted December 8, 2010 Report Share Posted December 8, 2010 lol i got tons of bits and pieces :lol: (I try and get rid of them but just seem to wind up with more) Quote Link to comment
Rustina 510 Posted December 8, 2010 Author Report Share Posted December 8, 2010 Ok, I need a 6 bolt flywheel, a entire clutch assembly, a pedal assembly, dual su carb intake mani and linkage, l20 wire harness... Send me a parts list of what you have because I probably need it Quote Link to comment
Skib Posted December 8, 2010 Report Share Posted December 8, 2010 Ok, I need a 6 bolt flywheel, a entire clutch assembly, a pedal assembly, dual su carb intake mani and linkage, l20 wire harness... Send me a parts list of what you have because I probably need it lol Im always finding stuff I didnt even know I had :lol: I have the 6 bolt flywheel and the clutch shouldnt need a new harness for the L20 tho Quote Link to comment
Rustina 510 Posted December 8, 2010 Author Report Share Posted December 8, 2010 How much for the clutch assembly and the flywheel shipped to 97006 zip? Quote Link to comment
Laecaon Posted December 8, 2010 Report Share Posted December 8, 2010 Dooooood, Skib lives near you. No shipping, make it a meet and greet. Rustina 510: Location: Portland oregon Cars: Beaverton Skib: Location: The Interwebs/PDX Quote Link to comment
Rustina 510 Posted December 8, 2010 Author Report Share Posted December 8, 2010 Sweet!!!! I won't be able to meet up this weekend, I'm driving to Salem Friday to get floor pans and a intake manifold at z therapy, then Saturday I'll be in Vancouver getting the tranny. I'm getting close to all the parts I need, and including the car itself I'm still under 1k Totall amount spent. I love datsun's Quote Link to comment
Rustina 510 Posted December 8, 2010 Author Report Share Posted December 8, 2010 Here it is the day I bought it. 1 Quote Link to comment
Rustina 510 Posted December 9, 2010 Author Report Share Posted December 9, 2010 Well shit, the Duse with the dogleg tranny just called me to let me know it sold today before I could get thier on Friday :( Do you have one skib? I can come by this weekend and pay you for it. Quote Link to comment
DISLEXICDIME Posted December 9, 2010 Report Share Posted December 9, 2010 Get azx trans or pick up a truck 5 speed. Dog legs brake when you drive them hard with an l20b. Quote Link to comment
Rustina 510 Posted December 9, 2010 Author Report Share Posted December 9, 2010 Do you know where I can find one? It's the last major piece I need, then its the small stuff Quote Link to comment
Laecaon Posted December 9, 2010 Report Share Posted December 9, 2010 Any other tranny besides the dogleg will require the driveshaft to be shortened. Quote Link to comment
Rustina 510 Posted December 9, 2010 Author Report Share Posted December 9, 2010 The 1979 200sx came ithe the l20 and the dogleg, it's not a good swap? Wasn't it built for the l20? Quote Link to comment
