Akumazedex S130
so heres the details so far;
1982 Datsun 280zx N/A
Stuff thats not stock;
MSA short ram intake
MSA cat-back exhaust with generic muffler
MSA rear wing
Unknown front airdam (now called "squishy")
Custom front strut bar
Cut springs with tokico blues (working on sleeves and springs) needs more drop
Rota Grid Offroad wheels 16x8 +10 offset with 3m spacer on front to clear strut
One off carbon fiber reclinable bucket seat
Custom Purdy valve cover
HID headlights and fogs
Chastain Shadow louvers (rare)
Heres what it was like when I first picked it up.. stock ugly and sitting behind my shop for 5 years..
and over the past 2 years this is how it came along..
so now that everyone is cought up heres whats going on now...
im currently in the long process if swapping over to turbo, gonna be running an N/A-T setup using megasquirt as an ecu.
Im actually really close to bolting everything on at this point, only things i have left are fuel and oil pumps, i need an oil feed line made, and to get megasquirt and do all the necessery tuning and junk..
Some of the stuff i have for the swap...
and the crappy ebay oil lines i got.. too short and the return is the wrong diameter.. no biggie, i was after the fittings anyways.
I have another T3 turbo that is actually in better shape than the one pictured but will be getting rebuilt anyways.. i have the kit on the way, see the rebuild here when i do it.
Also i got another set of struts so i can cut the perches off to put sleeves and springs on so i can lower it more..
and today i scored on a digital gauge cluster center gauge pod and harness
plugged it in and it works!!!
well thats pretty much it for now.. i'll keep this updated as much as i can.
  • Replies 225
looks like the standard S130 airdam with break ducts, most of them are similar or dead on to that one.
the one on my 83 might be that same one too (gotta go take a look at it lol)
almost looks exactly like the MSA one but its hard to tell from your pics
i've seen that one before, but mine has a raised section in the middle and has a less aggressive cuts, plus its circa the late 80's, i got it off of my buddies 10th ann in the picture above which we got from the original owner.. thats where i got the strut bar sway bars (which i still have to install) louvers and squishy. its polyurathane and has no markings on it whatsoever, also the ducts are taller.. the original owner called it "custom" :hmm: still a score tho since i have yet to see the same exact one ^_^
Not the digital cluster! <_< I like the voltmeter of the NA gauges and then add an aftermarket boost gauge. They are far more accurate anyway and will go up to 20psi since that is where you'll be at soon :cool:
The car is looking good though. You have some tasteful mods....
I finally got around to swapping my gauges today, heres how it went..
To start of, heres the before.. stock analog gauges
Its easier to get the cluster out if you drop the steering wheel, two bolts on the column.
Once you get the 4 screws holding the cluster in place out and disconnect the spedo this is what youll have left
Next youll need to remove the radio console 4 bolts on each side
Youll need to detach the climate control from the dash, not necessary to remove it tho
now the fun stuff, unbolting the dash, theres 4 bolts on the bottom and 4 screws under beauty covers in top
slowly start to wiggle the dash free making sure to detach any connectors in the precess carefully
and voila!
heres the dash with the harness still attached
and heres what were doing, swapping in digital cluster and turbo gauge pod
heres the backside, remove the harness and replace with the digital one, connectors are the same as the analog but we need the whole thing, also a good time to replace that buzzing center speaker that has been annoying you for years
with the gauge pod installed
installing is the opposite of the removal
and the finished result
and the best part is my clock finally works!!
The only gauges that don't work is the boost and oil temp.. And yes the speaker was replaced, I had one laying around.. It's soo awesome driving around at night! Haha now I know what I've been missing! An everyone is swapping to analog pffffttt this is wayyyy more cooler! And no wiring and connector problems like the z31
The first gen z31's t3's are the same, the second gen z31's are water-cooled. I need the first gen.
what do you mean by first/second gen Z31?
any Z31 T3 is useable on the ZX, and that includes the one with the oil/water cooled center
the 1984 to 1987 Z31 turbos had a T3 but the 1988 and 1989 Z31's got a T25
to use them you just have to remove the Z31 T3 exhaust housing (since it has the cast in downpipe) and just bolt on the 280ZX exhaust housing.
then your good to go with a stock downpipe and it bolts in.
Ohh that's right they bumped up the compression and used a smaller turbo for quicker response.. Anyways.. I'll dig around hybridz an see if I can get another housing. Turbos aside. I'll be checking out the springs and sleeves I might be using to go mad jdm super slammed yo tomorrow. Hopefully the sleeves fit the struts.. If they do expect to see my car much lower than it is by Monday..
so after many days of procrastinating the turbo if finally back together. I talked to some of the guys at GPOP about the cracked turbine housing and they said its not a big deal. yes, I am stubborn. haha
correct me if im wrong, i dont remember the parts off the top of my head
so this is everything in pieces
the center section has two bushings and four snap rings, those all get replaced
the back of the compressor, the center springy thing for the thrust washer and the bearing get replaced
the new thrust bearing
now you can start putting everything back together
the turbine housing and compressor wheel back on
the compressor housing back on, be sure to clock the housing, otherwise youll have clearance issues and fitment problems
reinstall the wastegate actuator and voilla! dones.
now you have a nice rebuilt turbo for a fraction of the cost of a new one, sure its not pretty but it works.
Prices: Garrett Airesearch T3 turbo $60 from HybridZ
G POP shop complete rebuild kit about $110 shipped
personal satisfaction of mending something, 4 tquitos and a slerpee :P
now all I need is Turbo fuel pump, turbo oil pump and the oh soo confusing megasquirt
