paradoxx Posted January 19, 2008 Author Report Share Posted January 19, 2008 I have news for ya about my head. I took it to the shop yesterday and the even sandblasted it, its nice just like a brand new head. Also, hainz, remember about the rust marks you told me? the they applied some special glue and rectified it. The mistake with the last head job was that they collocated the wrong way on the bench and used a rectifying rock to rough for the head. I hope im explaining well. Let me get some pics about it for you to watch it. Quote Link to comment
datzenmike Posted January 19, 2008 Report Share Posted January 19, 2008 i may have a set of stock nissan main/crank bearings (if not for an l16 then for a L20)ill check this weekend for ya Brian FYI, the L16/L18 five bolt crank mains are 2.1631". When Nissan built the L20B six bolt crank the mains were increased to 2.3599". All six bolt cranks that I have, 2 L20Bs, 2 Z20Es, a Z22 and 2 Z24s are all 2.3599", even many manuals say they reverted back to the earlier 2.1631" size around '79. My '84 720 FSM lists them wrong for the Z24!!!! If you order a six bolt crank bearing it will be correct but most manuals list them the wrong size. Well boyz..I recently overhauled mi powerplant. Its getting harder to get spare parts, I used to have hastings 2C piston rings but no one sells them anymore. I still have my flat top pistons. I did the work because it started to burn oil and I hate that, the problem was taht on the last overhaul, almost 10 years ago, the mechanic put some cheap piston rings and 3 out of 4 1st ring were broken in half, a complete mess on my head. But please take a look at the coverage. :D Broken rings are usually caused by not checking the ring end gap with the ring installed in the cylinder. If there isn't enough clearance they will expand and meet when hot. To relieve the pressure they will snap. Quote Link to comment
paradoxx Posted January 20, 2008 Author Report Share Posted January 20, 2008 I totally agree with you datzenmike. The thing is that the guy that did the work some years ago, didnt even realize about the mark that the piston rings have and that tells you which side is the top. Im already running the dat and started for 20 minutes and let it cool, tomorrow I will continue. Quote Link to comment
banzai510(hainz) Posted January 21, 2008 Report Share Posted January 21, 2008 thanks for the update Quote Link to comment
paradoxx Posted January 21, 2008 Author Report Share Posted January 21, 2008 There you go, the last set of pics. Working overnight. Done! its in The first start......but a exhaust leak. Time to repair the leak. The first start :D Im in love! Done! Quote Link to comment
]2eDeYe Posted January 21, 2008 Report Share Posted January 21, 2008 :cool: I really like the night pic with the engine bay all lit up :D Quote Link to comment
paradoxx Posted January 21, 2008 Author Report Share Posted January 21, 2008 that pic is my wallpaper now :D Quote Link to comment
paradoxx Posted January 21, 2008 Author Report Share Posted January 21, 2008 Resolving Hainz question and for you all to know, I had to take my head to another shop because the first screwed up when placing it on the bench. So I took it to my cousin's shop, I guess Ive told you that was a friend of mine, well not, hes family :D before: After: He applied a special bond to the corroded surface to leave it completely flat. He also welded on some places where the water holes got bigger and leak risky and of course sandblasted, looks like new. Amazing job done, now a friend of mine that races autoX will carry a sticker promoting "Reconstructora Wolff 18 Calle". I will show you some pics when the circuit starts. Quote Link to comment
