VintageRice Posted September 23, 2010 Report Share Posted September 23, 2010 Help me ID this motor. In a 510 and turboed. I don't know my nissan engines very well yet. Thanks!! Quote Link to comment
DISLEXICDIME Posted September 23, 2010 Report Share Posted September 23, 2010 read ythe flat spot near the number 4 spark plug is this engine in a redish 4 door? Quote Link to comment
datzenmike Posted September 23, 2010 Report Share Posted September 23, 2010 L20B by the looks of it. Has EFI but I don't see a turbo. Not sayin' it isnt. Quote Link to comment
ariascarlos1990 Posted September 23, 2010 Report Share Posted September 23, 2010 L20Bt Quote Link to comment
VintageRice Posted September 23, 2010 Author Report Share Posted September 23, 2010 It is turboed, heres another pic.. Is EFI on a L20b very common??? I thought it was L series but the guy claims it a 2.4 240sx motor. Obviously not.... Turbo Quote Link to comment
datzenmike Posted September 23, 2010 Report Share Posted September 23, 2010 There's no such animal in North Am. No turbo and no EFI. Look behind the dip stick handle on the top edge of the block just below the head, the engine size should be there. Looks factory so JDM maybe? Quote Link to comment
VintageRice Posted September 23, 2010 Author Report Share Posted September 23, 2010 He DID say it was an imported motor. Bought it from japan and a buddys shop put it in. I'm going to look at this car soon. Not running but was when parked. Needs radiator and other bits. Need to check compression and for spark when I'm there. What else should I look out for besides the obvious stuff like water in the oil. Thanks a million guys!!! Quote Link to comment
DISLEXICDIME Posted September 23, 2010 Report Share Posted September 23, 2010 never mind i know what car this is Quote Link to comment
ariascarlos1990 Posted September 23, 2010 Report Share Posted September 23, 2010 Whats up with the valve cover hold down strap? lol Quote Link to comment
Braden Posted September 23, 2010 Report Share Posted September 23, 2010 Whats up with the valve cover hold down strap? lol wondering the same thing myself, too much boost might blow the valve cover off i guess! Quote Link to comment
Skib Posted September 23, 2010 Report Share Posted September 23, 2010 Looks factory so JDM maybe? deff not a factory set up, the intake may be a JDM L4 EFI intake or a cut down Z car one. the throttle body and AFM look like they came off a KA tho Quote Link to comment
DISLEXICDIME Posted September 23, 2010 Report Share Posted September 23, 2010 i wonder if that is steves old engine Quote Link to comment
datzenmike Posted September 23, 2010 Report Share Posted September 23, 2010 I dunnow skib, check the exhaust manifold to turbo.. looks cast iron. L18 EFI with LD20 turbo and exhaust manifold. Quote Link to comment
DISLEXICDIME Posted September 23, 2010 Report Share Posted September 23, 2010 my other question is what are or where they running for engine management ? because one hard pull and pop piston fail! the more i look at it the more i think this is steves old engine Quote Link to comment
Skib Posted September 23, 2010 Report Share Posted September 23, 2010 I dunnow skib, check the exhaust manifold to turbo.. looks cast iron. as far as I know there are no factory L4 turbo exhaust manis, it was never a factory option. I cant see any of the mani clearly in the pics, the cast looking part in the last pic is the turbo exhaust housing lets get some exhaust mani and ECU pics! Quote Link to comment
Guest kamakazi620 Posted September 23, 2010 Report Share Posted September 23, 2010 Whats up with the valve cover hold down strap? lol If you look closely the battery is missing,and they put the hold down on the valve cover.(I know most of us ratsun guys have NEVER seen or used a battery hold down,unless its in bungie cord style.) Quote Link to comment
ggzilla Posted September 23, 2010 Report Share Posted September 23, 2010 Looks like a 610 SSS engine -- L18E with a bunch of mismatched parts. You can look on the engine for the number itself. Might be an L20B with the SSS manifold fitted. Also looks like a Dodge engine, er i mean Dodgey. That battery hold down would make me think twice about buying it, and the seller passing it off as a 240SX engine would make me not trust the buyer. Quote Link to comment
VintageRice Posted September 23, 2010 Author Report Share Posted September 23, 2010 I'm going to look at this car tomorrow night. I'll be bringing my camera FOR SURE. Be ready for a pic heavy post when I return. Either way, with no one knowing for sure what this is, should I be skeptical about buying it???? :unsure: Quote Link to comment
ggzilla Posted September 23, 2010 Report Share Posted September 23, 2010 Always be sceptical about buying any used or rebuilt engine. Check it for smoke, and carefully listen for tapping or knocking sounds. A well-tuned Datsun L-series engine makes zero tapping sounds. Quote Link to comment
VintageRice Posted September 23, 2010 Author Report Share Posted September 23, 2010 Always be sceptical about buying any used or rebuilt engine. Check it for smoke, and carefully listen for tapping or knocking sounds. A well-tuned Datsun L-series engine makes zero tapping sounds. Good advice but............Not a running car currently. :( Quote Link to comment
DISLEXICDIME Posted September 23, 2010 Report Share Posted September 23, 2010 You lucky I am not closer or I woulod buy it Quote Link to comment
sssr20det510 Posted September 23, 2010 Report Share Posted September 23, 2010 Looks like a z manifold cut down u can see a seam that looks like its been welded, the car itself don't look like its in too bad of shape id check it for rust though. The rear flair looks like its cracked where its molded to the body Quote Link to comment
datzenmike Posted September 23, 2010 Report Share Posted September 23, 2010 Look behind the dip stick handle on the top edge of the block just below the head, the engine size should be there. Quote Link to comment
DISLEXICDIME Posted September 23, 2010 Report Share Posted September 23, 2010 definitely check the rear flares they always rust out under the flare Quote Link to comment
