Cruzn620 Posted January 7, 2008 Report Share Posted January 7, 2008 ok guys, after all my braking woes that i have had, i think i am going to break down and buy myself a one man brake bleeder. my friends are tired of driving 10-40 minutes to help me bleed my brakes, and i still haven't done a good job of it yet. i am thinking about buying this kit here...what do you guys think? have you tried one or have something different? Thanks for the input http://cgi.ebay.com/ebaymotors/Phoenix-Injector-V-12-Brake-Clutch-REVERSE-Bleeder_W0QQcmdZViewItemQQcategoryZ43989QQihZ005QQitemZ150202633107QQrdZ1QQsspagenameZWDVW Quote Link to comment
Voleurz Posted January 7, 2008 Report Share Posted January 7, 2008 the hell is fascar? in theory it sounds like it would work.. Quote Link to comment
0.C. Posted January 7, 2008 Report Share Posted January 7, 2008 I have a Mityvac, I think it cost me around $120, but it also works for different applications other than bleed brakes; testing, diagonosis etc. I think they are more convenient than having someone pump the pedal, plus you don't spill brake fluid all over the floor. edit: I found the one I bought 3-4 years ago. http://cgi.ebay.com/ebaymotors/MityVac-4000-Silverline-Automotive-Vacuum-Pump-Kit_W0QQitemZ160195089714QQihZ006QQcategoryZ43989QQssPageNameZWDVWQQrdZ1QQcmdZViewItem The prices have drop. Quote Link to comment
Cruzn620 Posted January 7, 2008 Author Report Share Posted January 7, 2008 yeah i was looking at a mity vac, but i don't have a compressed air source in the shop i am working in right now, so that reverse bleed type really caught my eye. i have reverse bled my bikes before and it worked great, so this looked like a good kit to buy. Quote Link to comment
Fineline Posted January 7, 2008 Report Share Posted January 7, 2008 Never had much with the vacuum bleeders. I put these on my truck and love em'. Go to the hardware store and cet some clear tubing so you can see the air bubbles and youve got a 1 man bleeder. Theyre cheaper than a bleeder too. These poped up for a Datsun 620 http://store.summitracing.com/partdetail.asp?autofilter=1&part=RUS%2D639560&N=700+4294845333+4294907666+4294906943+115&autoview=sku Another site http://www.speedbleeder.com/ I also found that when I was bleeding my drums it helped to adjust them out and lock up the drums, bleed them, and then adjust them. Hope this helps. Quote Link to comment
mklotz70 Posted January 7, 2008 Report Share Posted January 7, 2008 I also found that when I was bleeding my drums it helped to adjust them out and lock up the drums, bleed them, and then adjust them. Hope this helps. I like this suggestion since not many people have their rear breaks setup correctly. With them "locked up" you'll know if your pedal is rock hard or not. Then you can back them off after they're bled. Then you'll know how much of your travel is from the back brakes. Quote Link to comment
Cruzn620 Posted January 7, 2008 Author Report Share Posted January 7, 2008 after reading on the speed bleeders, i think i am sold on those....thanks for tip. i seriously don't know how i made it in life before i found this forum! LOL!! Edit: did you guys notice that they don't have a speed bleeder for the rear drums? whuddafuxup with that? i emailed russell about it, i'll post what i find out Quote Link to comment
hang_510 Posted January 7, 2008 Report Share Posted January 7, 2008 Edit: did you guys notice that they don't have a speed bleeder for the rear drums? whuddafuxup with that? :unsure: ive been looking fot them for awhile... Quote Link to comment
Bleach Posted January 7, 2008 Report Share Posted January 7, 2008 I just run clear hose into a can and let it gravity bleed. Works on front and rear. Done it on the Datsun trucks and Z's I had. Never had a better bleed before. :) Quote Link to comment
Cruzn620 Posted January 7, 2008 Author Report Share Posted January 7, 2008 about how long do you let it gravity bleed per wheel? and do you also gravity bleed the m/c and the proportioning valve? Quote Link to comment
fisch Posted January 7, 2008 Report Share Posted January 7, 2008 I used the cheap little one way bleeder valve bottle from autozone. Worked great. Only problem is the container is so small you have to stop to empty sometimes. Don't think it was even $10. Quote Link to comment
Cruzn620 Posted January 7, 2008 Author Report Share Posted January 7, 2008 Sooo Many Choices!!! Quote Link to comment
LAYEDOUTB2K Posted January 7, 2008 Report Share Posted January 7, 2008 i just use one way valves connected to a hose. works great, weve been usin it on our rececars and karts for years where you really have to trust your brakes are gonna stop you quick at 100+ Quote Link to comment
Bleach Posted January 7, 2008 Report Share Posted January 7, 2008 I used the cheap little one way bleeder valve bottle from autozone. Worked great. Only problem is the container is so small you have to stop to empty sometimes. Don't think it was even $10. I bought that too. I use it as a gravity bleeder and forget the one-way valve it comes with. I never had good luck with those valves. You let them bleed for 10-20 min. If I had done any work on the master, I bench bleed the master cylinder out of the car. (on a bench vice) Then install and gravity bleed. I would bleed the front pair at once, the the back pair since they run off the same source. I never had good luck gravity bleeding a clutch if it was empty of fluid. It just wouldn't start flowing. (too short of a hydralic line?) If it had some fluid in it already it would bleed fine. Quote Link to comment
ppeters914 Posted January 8, 2008 Report Share Posted January 8, 2008 A lot of folks swear by the Speed Bleeders. I bought a MityVac and never could get it to work correctly. Better options are: 1. Gravity 2. Power Motive bleeder system (from Summit Racing and a zillion other resellers) 3. Build-It-Yourself (I'll add the link to the site tonight when I get home). I actually bought the parts to do this, but haven't assembled it. :mellow: Quote Link to comment
