ONELOWDATS Posted September 17, 2010 Report Share Posted September 17, 2010 i realy hope one of u guys can help. i have a 66 411 wagon with a j13 in it and i was wondering if there was anyway to install a 5speed trans without having to change the motor out? i have a fealing that ur all gonna tell me no but hey u guys r the best people to ask! lol. any info would be great thanx. Quote Link to comment
jefe de jefes Posted September 17, 2010 Report Share Posted September 17, 2010 I thought I read somewhere you can run a dogleg as long as you have the the flex plate the dogleg was mounted to? Could be wrong. Hit up Datzenmike. He might know. Or check this out.......... http://community.ratsun.net/topic/19412-trans-adapter/page__p__269754__fromsearch__1#entry269754 Quote Link to comment
ONELOWDATS Posted September 17, 2010 Author Report Share Posted September 17, 2010 thank u for that info. i wonder how hard it would be to swap the j13 to an L motor? Quote Link to comment
wayno Posted September 17, 2010 Report Share Posted September 17, 2010 Didn't some of the 411s come with a R16? That would fit and you would use the 5 speed from the datsun 2000 roadster. If that tranny is not exceptable then find a SD22 diesel tranny front case, and use a napZ 5 spd. tranny, it will bolt on to the R16 or U20 blocks with the diesel case. wayno Quote Link to comment
erichwaslike Posted March 1, 2011 Report Share Posted March 1, 2011 but finding a good r16 with the correct intake and such aint easy (ask me how i know) Quote Link to comment
DanielC Posted March 1, 2011 Report Share Posted March 1, 2011 It's not on the shelf, right next to the L-18 fuel injection intake manifold? Quote Link to comment
MikeRL411 Posted March 1, 2011 Report Share Posted March 1, 2011 L motors are too long to fit in the engine compartment of a 411 sedan or wagon without much butchery [e.g. front cross member and firewall], even then you have radiator clearance problems. There is for all practical purposes no room to install an electric pusher fan without removing the front grill unless you can find an impossibly thin motor / fan combination. Even the 1600 type R roadster engine had to be modified to fit the RL411 version. Quote Link to comment
MikeRL411 Posted March 1, 2011 Report Share Posted March 1, 2011 Didn't some of the 411s come with a R16? That would fit and you would use the 5 speed from the datsun 2000 roadster. If that tranny is not exceptable then find a SD22 diesel tranny front case, and use a napZ 5 spd. tranny, it will bolt on to the R16 or U20 blocks with the diesel case. wayno The 4 speed "on the floor" WRL / RL 411 transmission could be fitted with race option gear sets based on the Austin Healey gear set. On of the gears was even a remachined AH part restamped with the Datsun part number. The older NISMO catalogs had these part numbers, doubt if any sets survive. There were different kits for the steel vs brass synchros. Quote Link to comment
