chris67 Posted September 6, 2010 Report Share Posted September 6, 2010 Clutch pedal wont move its solid as a rock. The fluid level was low but thats as far as i got. The truck has been sitting for over 10 years. I am not sure what tranny it is but it is a L16 motor. Slave cylinder? Quote Link to comment
ggzilla Posted September 6, 2010 Report Share Posted September 6, 2010 Just as easily could be the master cylinder. To test that open the bleeder at the slave. If the pedal still won't move it is not the slave cylinder. Maybe the pedal is stuck, but seems unlikely. Quote Link to comment
chris67 Posted September 6, 2010 Author Report Share Posted September 6, 2010 Just as easily could be the master cylinder. To test that open the bleeder at the slave. If the pedal still won't move it is not the slave cylinder. Maybe the pedal is stuck, but seems unlikely. I will try that tomorrow Quote Link to comment
wayno Posted September 6, 2010 Report Share Posted September 6, 2010 Hey Chris, I have brought home trucks that the master cylinders(both) were frozen solid inside themselves, like the brake slaves when they set for long amounts of time, they just rust themselves solid. wayno Quote Link to comment
paradoxx Posted September 6, 2010 Report Share Posted September 6, 2010 yes, definetly they dont work anymore.....the same thing happened to me with 2 510's that I bought. Time to change them! Quote Link to comment
chris67 Posted September 6, 2010 Author Report Share Posted September 6, 2010 Hey Chris, I have brought home trucks that the master cylinders(both) were frozen solid inside themselves, like the brake slaves when they set for long amounts of time, they just rust themselves solid. wayno I disconnect the hard line coming from the master cylinder drained out some fluid and now my clutch pedal moves normally but its still not doing anything at the tranny so I am guessing the slave cylinder is bad? (The spring was also only attached to one side of the slave). Quote Link to comment
paradoxx Posted September 6, 2010 Report Share Posted September 6, 2010 either way, its very recommended to replace them, for testing purposes you could use them, but not for normal drive, because the rust cavities might damage the seals and may cause a severe damage to the transmission, just my thoughts. Quote Link to comment
chris67 Posted September 6, 2010 Author Report Share Posted September 6, 2010 either way, its very recommended to replace them, for testing purposes you could use them, but not for normal drive, because the rust cavities might damage the seals and may cause a severe damage to the transmission, just my thoughts. Thanks i plan all replacing them just trying to confirm whats all bad before i start tearing eveything apart.:cool: Quote Link to comment
datzenmike Posted September 6, 2010 Report Share Posted September 6, 2010 I disconnect the hard line coming from the master cylinder drained out some fluid and now my clutch pedal moves normally but its still not doing anything at the tranny so I am guessing the slave cylinder is bad? (The spring was also only attached to one side of the slave). Either the slave is seized or the clutch arm isn't moving. Unbolt the slave and have someone gently depress the peddle. If the slave is ok the pushrod will move outward. If there is movement, have the person stop or the piston in the slave may over extend. I imagine it's the slave that's seized. Quote Link to comment
chris67 Posted September 7, 2010 Author Report Share Posted September 7, 2010 Wow i found a issue the slave push rod is pushed all the way out and just hanging there that might be the problem :lol: Quote Link to comment
chris67 Posted September 9, 2010 Author Report Share Posted September 9, 2010 all fixed she shifts again just wish I could get her to start GRRRRRRRRRRR Quote Link to comment
banzai510(hainz) Posted September 9, 2010 Report Share Posted September 9, 2010 look for spark at the center coil wire near ground? when trying to start. get gas or pour some gas in carb, ck the valve lash to make sure the valves are closing and your not loosing compression read this http://olddatsuns.com/620tech.htm I would really ck the gas tank also ,maybe even empty it Quote Link to comment
Braden Posted September 10, 2010 Report Share Posted September 10, 2010 its super easy to remove and rebuild the clucth master and slave, probably total of about 1.5 hours worth of work, even if you havent ever done it. just make sure verything is super cleand and the rubber plunger cups are in good shape and not damaged Quote Link to comment
