datsunz Posted August 17, 2010 Report Share Posted August 17, 2010 My 520 has the stock size 6.00's on it and they have some bad dry rot. I did a search and most said use 195/75/14, but also say it is almost too big for the stock older rims. Mine has the older stock rims and I was wondering if I should go 195/75/14 or if there is a better size that will look "stock" ? Thanks Chris Quote Link to comment
datzenmike Posted August 17, 2010 Report Share Posted August 17, 2010 6.00 14 is the same as (more or less) a 160/70R14 . A 195/75R14 is close to an inch wider but a whopping 2.5" taller. Width is fine but the extra height will affect the speedometer and act like a lower diff. ratio. Quote Link to comment
420n620 Posted August 17, 2010 Report Share Posted August 17, 2010 I run 195/70/R14 on my stock 78-620kc and I'm not having a prob, except my speed-o is off a little. I'd go ahead an run the 195/75/14 and go have sum fun. where's the pic's of thee 521, i don't see themz.. :P Quote Link to comment
datsunaholic Posted August 17, 2010 Report Share Posted August 17, 2010 I have a 6.00 PR14 OEM Toyo tire I pulled from under my '76. Tube-type. Probably one of the original tires from the factory. Standing next to a P205/75R14, the 6.00 is taller by about an inch. And it's nearly wore out. The P205/75R14 isn't. I should break out the measuring tape, but just eyeballing it the tire sidewalls are a bit more than 6" tall. The tire is only 6" wide- more like a 165/110R14. Quote Link to comment
510kevin Posted August 17, 2010 Report Share Posted August 17, 2010 what about a 185 70 14? that gets you a little closer. and its a common size Quote Link to comment
Charlie69 Posted August 21, 2010 Report Share Posted August 21, 2010 I ran across this researching tire size for my 520 stock wheels. 1966 520 OEM tire size was 6.00-14 6 ply front wheel size 4.5-Jx14 1966 520 OEM tire size was 6.00-14 8 ply rear wheel size 4.5-Jx14 1976 620 regular cab OEM tire size was 6.00-14 6 ply front wheel size 4.5-Jx14 1976 620 regular cab OEM tire size was 6.00-14 6 ply rear wheel size 4.5-Jx14 1980 720 regular cab OEM tire size was 7.00-14 4 ply front wheel size 5-Jx14 1980 720 regular cab OEM tire size was 7.00-14 4 ply rear wheel size 5-Jx14 1980 720 king cab OEM tire size was 185R14 front wheel size 5-Jx14 1980 720 king cab OEM tire size was 185R14 rear wheel size 5-Jx14 http://clubs.hemmings.com/clubsites/chevylist/tech/tire_size_conversion.htm Quote Link to comment
Bob3 Posted August 22, 2010 Report Share Posted August 22, 2010 I ran across this researching tire size for my 520 stock wheels. 1966 520 OEM tire size was 6.00-14 6 ply front wheel size 4.5-Jx14 1966 520 OEM tire size was 6.00-14 8 ply rear wheel size 4.5-Jx14 1976 620 regular cab OEM tire size was 6.00-14 6 ply front wheel size 4.5-Jx14 1976 620 regular cab OEM tire size was 6.00-14 6 ply rear wheel size 4.5-Jx14 1980 720 regular cab OEM tire size was 7.00-14 4 ply front wheel size 5-Jx14 1980 720 regular cab OEM tire size was 7.00-14 4 ply rear wheel size 5-Jx14 1980 720 king cab OEM tire size was 185R14 front wheel size 5-Jx14 1980 720 king cab OEM tire size was 185R14 rear wheel size 5-Jx14 http://clubs.hemmings.com/clubsites/chevylist/tech/tire_size_conversion.htm 1966 MX520 tire size 205-50-15 front and rear wheel size 15x7 (4x100 bolt pattern) :P Quote Link to comment
mklotz70 Posted August 22, 2010 Report Share Posted August 22, 2010 If I remember right....the stock tire is about 26" in diameter. Probably a pic in my PB somewhere :) ...found....aired up and full tread...26" Quote Link to comment
