521rat Posted July 20, 2010 Report Share Posted July 20, 2010 pics of the rat. 72' datsun 521. took some pics with my phone. i can take some normal photos if anyone cares to see more. Quote Link to comment
skunk Posted July 20, 2010 Report Share Posted July 20, 2010 we always want more pics :D welcom to ratsun, great first post. I really like the truck. Is it a runner? what do you plan to do with it? Quote Link to comment
521rat Posted July 20, 2010 Author Report Share Posted July 20, 2010 yea it runs. its my first Datsun so not to sure of my plans yet. if you guys want to shoot some ideas or advise of what i should do that would be great. Quote Link to comment
dat521gatherer Posted July 20, 2010 Report Share Posted July 20, 2010 thats kyle's truck. looks like he moved on like wanted. glad to see you signed up. looks like that rug i gave him went to good use. welcome!!! Quote Link to comment
banzai510(hainz) Posted July 24, 2010 Report Share Posted July 24, 2010 get a real battery holder tie down.Not a bungy cord get real battery cables ,ones with the molded ends put a nice crome side mirrow read olddatsuns.com ck the tran oil level and diff level. convert to electronic ignition as soon as possible this will save alot of heartache unless your good at points adjustment which alot of young guys know nothing about Quote Link to comment
elmerfudpucker Posted July 24, 2010 Report Share Posted July 24, 2010 And last but not least cross the bridge this Sunday and join the Bar-B-Que with us! pics are great but seeing them in person is much better! Quote Link to comment
Pumpkn210 Posted July 24, 2010 Report Share Posted July 24, 2010 I fixed that truck :smile: You should come to the PNW Ratsun BBQ on Sunday: http://community.ratsun.net/topic/22992-weekly-pnw-ratsun-bbq/ Quote Link to comment
521rat Posted July 24, 2010 Author Report Share Posted July 24, 2010 And last but not least cross the bridge this Sunday and join the Bar-B-Que with us! pics are great but seeing them in person is much better! ill definitely make it out there one of these sundays Quote Link to comment
521rat Posted July 24, 2010 Author Report Share Posted July 24, 2010 get a real battery holder tie down.Not a bungy cord get real battery cables ,ones with the molded ends put a nice crome side mirrow read olddatsuns.com ck the tran oil level and diff level. convert to electronic ignition as soon as possible this will save alot of heartache unless your good at points adjustment which alot of young guys know nothing about thanks for the advise Hainz. Quote Link to comment
banzai510(hainz) Posted July 24, 2010 Report Share Posted July 24, 2010 look like a good set up you got already, weber carb the iteam I list will hemp in the longivity of the rig. also maybe a solid state volt reg will next iteam to find also the batt end capble you have get corrotion proplems and also the 521 fuse box area. most times this is the proplem with lights ,battery not charhing ect..... dual points suck when possible find a single point distributor with the timming mount and converrt to a Pertronix or get a Matchbox IG with the coil. I myself havent change a cap in rotor in over 5-8 years. Quote Link to comment
Phixius Posted July 24, 2010 Report Share Posted July 24, 2010 Not sure if you know this already, but if you want heat for when it starts to get cold. Your heater core isnt hooked up. Might have been disconnected because of a leak at the core or one of the hoses sprung a leak (like mine did last week) and it is just a quick fix. Quote Link to comment
521rat Posted July 24, 2010 Author Report Share Posted July 24, 2010 Not sure if you know this already, but if you want heat for when it starts to get cold. Your heater core isnt hooked up. Might have been disconnected because of a leak at the core or one of the hoses sprung a leak (like mine did last week) and it is just a quick fix. yea what do i need to do to fix it? Quote Link to comment
Phixius Posted July 24, 2010 Report Share Posted July 24, 2010 yea what do i need to do to fix it? Well, if it is the heater core that is leaking. either a new one or find the hole and solder it. But, hopefully you just need to get the two hoses that go to the heater core which is located on the firewall behind the engine. I believe the hoses go from 3/4" from the block to 5/8" to the core. Does anyone know some good part numbers for heater hoses? Quote Link to comment
521rat Posted July 24, 2010 Author Report Share Posted July 24, 2010 Well, if it is the heater core that is leaking. either a new one or find the hole and solder it. But, hopefully you just need to get the two hoses that go to the heater core which is located on the firewall behind the engine. I believe the hoses go from 3/4" from the block to 5/8" to the core. Does anyone know some good part numbers for heater hoses? well i do remember him sayin sumthing bout it leaking. where is the best place to find a replacement heater core? Quote Link to comment
74datsun620 Posted July 24, 2010 Report Share Posted July 24, 2010 Welcome to Ratsun! Cool Datsun pickup!:cool: Quote Link to comment
521rat Posted July 24, 2010 Author Report Share Posted July 24, 2010 why is there a gap here? other side is flush Quote Link to comment
mklotz70 Posted July 25, 2010 Report Share Posted July 25, 2010 Driver's side tends to sag after 30+ years :) Along with the driver, a full tank of gas, steering column and equipment, pedal assy, ....it all makes the D-side heavier. :) Quote Link to comment
banzai510(hainz) Posted July 25, 2010 Report Share Posted July 25, 2010 why is there a gap here? truck has been lowered using spacers!!!!!!!If not lowering blocks youl have a huge gas as thats your traval You serious? Thats your travel till you hit the rubber bump stop. see if you can remove it to give you more travel. But then it will be metal on metal. or just grind more of the rubber off. your from will have one too. I removed mine. Quote Link to comment
521rat Posted July 25, 2010 Author Report Share Posted July 25, 2010 why is there a gap here? truck has been lowered using spacers!!!!!!!If not lowering blocks youl have a huge gas as thats your traval You serious? Thats your travel till you hit the rubber bump stop. see if you can remove it to give you more travel. But then it will be metal on metal. or just grind more of the rubber off. your from will have one too. I removed mine. sorry hainz im new to the whole Datsun thing so.. im gonna ask ALOT of dumbass ?'s Quote Link to comment
banzai510(hainz) Posted July 26, 2010 Report Share Posted July 26, 2010 Doug and Ben live your way they can help So can I But one thing that was best 75$ ever spent was me putting a electronic ignition on my rig. It saves alot of heartache on soemone whos not familier with points ignitions. If you have a single point dist you can put or I a Pertronix in there. Or if you find a matchbox that will be good also. Buy a slave cylinder and brake/clutch master if your stuff is old. if you think your going to keep the rig long. Most od this stuff isnt in the store and is a order item. stayed up late replacing Datto510(Eric's) clutch master and slave on his 521 last nite till 12:30. Quote Link to comment
