180Bsss Posted June 9, 2010 Report Share Posted June 9, 2010 im in the middle of a 510 wagon build its going to have a l20 and dog leg with 280zx struts my question is whats a good spring rate and length for this combo and also whats a good short shock to use when shortening the zx strut's that fits in the tub right? Quote Link to comment
D@tsuks Posted June 9, 2010 Report Share Posted June 9, 2010 I used 80's vw rabbit strut inserts for my 280z struts. Can"t remember exactly how much shorter they were but it's 2 - 3 inches. Quote Link to comment
sssr20det510 Posted June 9, 2010 Report Share Posted June 9, 2010 spring rate depends on how you drive and how stiff you want it, 200-250 is what most people run. Quote Link to comment
djaztek12 Posted June 12, 2010 Report Share Posted June 12, 2010 i have tanabis 235 lbs they work great i dont like ground control there to soft for me i hadn't in my goon and it use bounce alot. :lol: Quote Link to comment
thisismatt Posted June 12, 2010 Report Share Posted June 12, 2010 i have tanabis 235 lbs they work great i dont like ground control there to soft for me i hadn't in my goon and it use bounce alot. :lol: What is too soft? Are you saying the Eibach spring rate is lower than rated? Bouncing means your shock isn't damping properly, regardless of what spring rate you're using. Quote Link to comment
djaztek12 Posted June 13, 2010 Report Share Posted June 13, 2010 What is too soft? Are you saying the Eibach spring rate is lower than rated? Bouncing means your shock isn't damping properly, regardless of what spring rate you're using. yes the Eibach spring was to soft for me and it was a 255 lbs spring if i recall. it just didnt feel right for me ,about the struts i have tokico iuminas. so 1 of my friends had some oooooold school tanabi black springs rated at 235 lbs and carrera coil overs witch i had already. and they felt and handle allot better and only thing we change were the springs. Quote Link to comment
thisismatt Posted June 13, 2010 Report Share Posted June 13, 2010 yes the Eibach spring was to soft for me and it was a 255 lbs spring if i recall. it just didnt feel right for me ,about the struts i have tokico iuminas. so 1 of my friends had some oooooold school tanabi black springs rated at 235 lbs and carrera coil overs witch i had already. and they felt and handle allot better and only thing we change were the springs. Interesting, thanks for clarification Quote Link to comment
djaztek12 Posted June 13, 2010 Report Share Posted June 13, 2010 Interesting, thanks for clarification no problem.but how come it seems like the old school tuff work the best :lol: those tanabi spring and the carerra coil overs are old like 7 years old, but there were new. and it was a good price. i guess they don't make parts like they use too. :angry: Quote Link to comment
180Bsss Posted June 13, 2010 Author Report Share Posted June 13, 2010 cool thank you guys for the info does someone know if all the vw rabbit scirocco shocks are the same diameter? cuz my brother has sum vw rabbit shocks in his 280zx struts and they dont fit right in the strut tube Quote Link to comment
djaztek12 Posted June 14, 2010 Report Share Posted June 14, 2010 i there a bit smaller. they need to be modified. :o Quote Link to comment
180Bsss Posted June 14, 2010 Author Report Share Posted June 14, 2010 update i ended up getting sum vw sensa trac shocks the diameter of the shock is smaller than the 280zx strut tube but i think once the gland nut smashes the shock down it should stay in place Quote Link to comment
djaztek12 Posted June 14, 2010 Report Share Posted June 14, 2010 thats, :rolleyes: cool good luck Quote Link to comment
dennis Posted June 14, 2010 Report Share Posted June 14, 2010 The popular 280zx strut/shock combo is the MR2 inserts. I believe they are 2" shorter than stock 280zx inserts. Quote Link to comment
180Bsss Posted June 17, 2010 Author Report Share Posted June 17, 2010 thank all you guys for the info ok yesterday i got my gc coilovers i ended up getting a 300 lb spring and a 6" adjuster sleeve hopefully today by the end off the day i should have the struts cut and welded il post pics when im dun Quote Link to comment
DISLEXICDIME Posted June 17, 2010 Report Share Posted June 17, 2010 Agx mr2sw20. For inserts then shorten the tubes 40mm if. I remember right Quote Link to comment
The Dat-side Posted June 17, 2010 Report Share Posted June 17, 2010 Agx mr2sw20. For inserts then shorten the tubes 40mm if. I remember right What about the GR-2 if you're on a budget? If it's a DD with little auto-x at Canby next year. Quote Link to comment
180Bsss Posted June 19, 2010 Author Report Share Posted June 19, 2010 alright i got the struts finished today the end result is a 280zx strut choped down 2.5" with a vw shock and weld on ground control coilover kit with a 300 lb spring Quote Link to comment
djaztek12 Posted June 19, 2010 Report Share Posted June 19, 2010 alright i got the struts finished today the end result is a 280zx strut choped down 2.5" with a vw shock and weld on ground control coilover kit with a 300 lb spring looks nice :P Quote Link to comment
Pedro Posted June 20, 2010 Report Share Posted June 20, 2010 Wow they look short Quote Link to comment
PurePontiacKid Posted June 30, 2010 Report Share Posted June 30, 2010 This is exactly what I did with mine, but I used Koni red inserts and shorter/stiffer springs. the GC spring and collar look nicer than mine though :P Quote Link to comment
CorAce Posted July 3, 2010 Report Share Posted July 3, 2010 300 lb seems like a lot, I got the same setup with 250lb and am thinking of dropping to 200lb for a DD. Quote Link to comment
180Bsss Posted July 4, 2010 Author Report Share Posted July 4, 2010 300 lb seems like a lot, I got the same setup with 250lb and am thinking of dropping to 200lb for a DD. i think the springs are too soft maybe cuz there to long Quote Link to comment
180Bsss Posted July 4, 2010 Author Report Share Posted July 4, 2010 this is the wagon on the ground that's how much travel i have the spring is fully compresed Quote Link to comment
CorAce Posted July 4, 2010 Report Share Posted July 4, 2010 That seems about right; mine sits roughly the same height on uncut struts with the adjustment collar bottomed out. It looks like you should have another 2.5 – 3in left to drop? Don’t be afraid to use the whole range of travel. Were are you out of? Quote Link to comment
PurePontiacKid Posted July 5, 2010 Report Share Posted July 5, 2010 Just a word of caution, if you're on just regular replacement shocks and/or gas filled shocks, you're pretty close to the limit of them with the 300lb springs. Anything moar, and they will start to not be able to control the rebound of the springs well enough and the car will bounce like crazy. Trust me, I had my ~450lb/in springs on my Tokico Blues, and I looked like a retard whenever I went over bumps and bounced like a low rider. I got my VW Koni's in, set em to full stiff rebound, and the car rides BEAUTIFULLY meow, but I'd like them to be a bit stiffer... Quote Link to comment
