Pacific coast Datsun Posted March 31, 2010 Report Share Posted March 31, 2010 Ever wanted to shave your 620 cowl & did'nt know how ? well here ya go. Basic welding & bodywork skills are a must to do this but it's not rocket science :cool: 1st use a grinder with a thin cut off wheel to remove the "vents". Cut them as close to the edge as possible... then make a template out of cardboard. Lay it over a piece of sheetmetal & trace,when you cut you'll wanna cut right on the line you made.. & now SLOWLY tack the filler piece until you have a solid bead all the way around. Then use the same cut off wheel on the grinder to gently grind the welds smooth... youll wanna spread a generous layer of seam sealer on the perimiter of the filler piece on the underside. This will prevent moisture from entering... then primer & paint over the seam sealer after it dries....... next apply a few skim coats of body filler, sand, & primer.... Ive shaved a few 620 cowls & it takes me a few days. But, take your time & dont rush it. Any ?'s PM me ill be glad to help out :cool: Quote Link to comment
Guest DatsuNoob Posted March 31, 2010 Report Share Posted March 31, 2010 I did one today actually. I just traced mine out with a sharpie, trimmed to fit, tacked in randomly making sure everything was flushed up with some magnets, and ground it all down with some 40gt rolocs. Took the better part of a day, but they DO look SO much better and well worth the time it takes. I'll get some pics of mine, I havent put any filler on yet, should only need a very small amount though. Quote Link to comment
Grey_Matter Posted March 31, 2010 Report Share Posted March 31, 2010 awesome write up :thumbup: Quote Link to comment
datzenmike Posted March 31, 2010 Report Share Posted March 31, 2010 I guess it's ok in Calli but how does your heater get air for defrost? Quote Link to comment
Bleach Posted March 31, 2010 Report Share Posted March 31, 2010 I guess it's ok in Calli but how does your heater get air for defrost? through the holes for the windshield wiper? :) Quote Link to comment
Pacific coast Datsun Posted March 31, 2010 Author Report Share Posted March 31, 2010 I guess it's ok in Calli but how does your heater get air for defrost? Good question Mike. On my 620 the blower motor doesnt even work & theres no roof so defrost is the least of my worries :rolleyes: I did the same mod on my HB & the defrost along w/ the blower motor still works great. Quote Link to comment
Grey_Matter Posted March 31, 2010 Report Share Posted March 31, 2010 I guess it's ok in Calli but how does your heater get air for defrost? its not an air tight compartment Quote Link to comment
Pacific coast Datsun Posted March 31, 2010 Author Report Share Posted March 31, 2010 Send me your cowls & i'll shave em :thumbup: Quote Link to comment
Unclejesse88 Posted April 1, 2010 Report Share Posted April 1, 2010 I guess if you shave these off you would just use "recirc" instead of "fresh" air. Quote Link to comment
74datsun620 Posted May 27, 2010 Report Share Posted May 27, 2010 You could add a fire wall hole for cold air to the heater. Quote Link to comment
Duke Posted May 27, 2010 Report Share Posted May 27, 2010 I'm gonna nit pick here, but I believe that the seam for the filler panel should be fully welded. Doing so negates the need for seam sealer prevents any moisture from ever getting behind the body filler. I don't claim to be a body man but in my opinion that is the right way to do it. Quote Link to comment
Pacific coast Datsun Posted May 27, 2010 Author Report Share Posted May 27, 2010 I'm gonna nit pick here, but I believe that the seam for the filler panel should be fully welded. Doing so negates the need for seam sealer prevents any moisture from ever getting behind the body filler. I don't claim to be a body man but in my opinion that is the right way to do it. Duke you are correct sir. I did indeed run enough tack welds until it was a solid bead. The pic i took was before that step was done. Quote Link to comment
lilblackwagon Posted June 10, 2010 Report Share Posted June 10, 2010 A tip for those with a compressor but no welder(don't really need a compressor either I suppose)... I've shaved a few things in my time and decided I didn't like all the welding, grinding and filler work. I started using a flange tool and "small body panel adhesive". My ol' air powered flanger had a 1/4" throat so I'd just add that amount to my patch, spread the goo, clamp it down and go about my bidness. Then I'd use a fiber disc, wire wheel or spot blaster to clean out the seam and spread some filler in there with a plastic razor blade to minimize how much filler I had to use. Works great! No heat = No distortion. I've tested the Fusor stuff myself and verified that when used properly it has a higher yield point than a series of plug or spot welds. Also if you use factory metal the advantage of factory paint protection is a plus if you don't plan on stripping your car to bare metal for a repaint. You'll use less material 'cause you won't mess up as much area surrounding your shave. Shave on my non welding brothas! Quote Link to comment
jesusno2 Posted June 10, 2010 Report Share Posted June 10, 2010 heres a little tip for ya too (although ya might not have the problems i had) when making a template for those pesky body panels or sheetmetal in general. a great template maker is construction paper. its way more precise so ya dont wind up with gaps to try and fill. of coarse i like to tig panels in, but either way it helps alot try it sometime works like a champ, learned that from a old timer. Quote Link to comment
Pacific coast Datsun Posted June 10, 2010 Author Report Share Posted June 10, 2010 Those are some good tips guys. Thats why Ratsun rules :cool: Quote Link to comment
Pacific coast Datsun Posted November 17, 2010 Author Report Share Posted November 17, 2010 I shaved another cowl today for Steroid. This one will go on his 4 door topless "river truck" & since it does'nt rain in Arizona i shaved the wiper holes as well... & it has his approval :D Quote Link to comment
