wayno Posted July 27, 2019 Report Share Posted July 27, 2019 I have an issue related to photos Mike posted on page 2, I just pulled out my black speedo gear to replace it with a yellow gear as I just switched over to 3.3 gears in my 521 kingcab, the speedo gears are not the same length, it is a 1985/86 short shaft 5spd, is this a short shaft 5spd only part? You can see the mount tab is part of the gear also(black one). So did they ever make a mileage option 720 with a short shaft 5spd in it that I could get a yellow gear out of? 1 Quote Link to comment
Crashtd420 Posted July 27, 2019 Report Share Posted July 27, 2019 3 hours ago, wayno said: I have an issue related to photos Mike posted on page 2, I just pulled out my black speedo gear to replace it with a yellow gear as I just switched over to 3.3 gears in my 521 kingcab, the speedo gears are not the same length, it is a 1985/86 short shaft 5spd, is this a short shaft 5spd only part? You can see the mount tab is part of the gear also(black one). So did they ever make a mileage option 720 with a short shaft 5spd in it that I could get a yellow gear out of? That definitely looks different then the ones I have seen... I'm using the black gear in mind, I have the stumpy 5spd also.... I used one from my 63 series 4spd but i had to rotate it 180 and grind a new notch to get it to engage properly.... I think i have a long yellow one from my 4spd that I dont need ... I'll trade you for the black one you have..... 1 Quote Link to comment
Crashtd420 Posted July 27, 2019 Report Share Posted July 27, 2019 This is the one I am currently running in mine next to the yellow one... 1 Quote Link to comment
datzenmike Posted July 28, 2019 Report Share Posted July 28, 2019 I had no idea the shortys were so long. The shorty speedometer pinion IS in a different location than the long ones so maybe this is what it is. The shorter aluminum with yellow gear is definitely from a 71B long. All good info, thanks. 1 Quote Link to comment
wayno Posted July 28, 2019 Report Share Posted July 28, 2019 (edited) The black one I have is 3.75" long/tall the way you measured yours, I can find black ones but finding a yellow one, well I didn't think they existed, and if they do they were likely only in the 1985/86 regular cab/short box trucks with the mileage package(Z20 block), that would be the rare of rare. I would happily trade you a black one for that yellow one you have, it looks to be 3 5/8ths inches tall but I suspect that will work, I will PM you. Edited July 28, 2019 by wayno 2 Quote Link to comment
Crashtd420 Posted August 2, 2019 Report Share Posted August 2, 2019 On 7/27/2019 at 9:23 PM, wayno said: The black one I have is 3.75" long/tall the way you measured yours, I can find black ones but finding a yellow one, well I didn't think they existed, and if they do they were likely only in the 1985/86 regular cab/short box trucks with the mileage package(Z20 block), that would be the rare of rare. I would happily trade you a black one for that yellow one you have, it looks to be 3 5/8ths inches tall but I suspect that will work, I will PM you. I was lucky enough to trade with wayno and since he was much quick than me with the shipping I was able to compare the 2..... While I have proved in my own transmission that they will engage the black one is definitely a little different... And about 1/8 inch longer.... looks like the gear its self is even a little different.... So the stumpy 71b from the 85/86 720 is definitely an odd pinion assembly... 1 Quote Link to comment
datzenmike Posted August 2, 2019 Report Share Posted August 2, 2019 The worm drives on the main shaft are either metal or some later are plastic but the same otherwise. 1/8" is nothing... the worm only engages about 1/4" in the middle of the pinion gear. 1 Quote Link to comment
wayno Posted August 7, 2019 Report Share Posted August 7, 2019 I put the yellow gear I got from Crash in today, I had to cut a new groove 180 degrees out so the teeth would engage the teeth on the drive shaft in the tail housing. It appears to work just fine, I drove the truck twice today, I went past one of them radar speed signs and it said I was doing 28mph when my speedo showed 30mph. I am leaving it in there, as I recall the black gear was 2mph off also. While driving down the freeway I showed 2150rpms at 60mph, 2500rpms at 70mph, and 2850/2900rpms at 80mph, I have P205/70R14 tires on it all the way around, seems like with these tires I would be going faster than I am showing. 1 Quote Link to comment
