sycloned916 Posted January 4, 2010 Author Report Share Posted January 4, 2010 It has a subie diff 3.55 gonna see how the SR likes it and if its driveable and not like the 520 and a good burn out truck. If not I will change it. Today got the engine bay half way do spent allday wet sanding it,still have to drill out the horn mounts and flush the pass side were the battery was. Quote Link to comment
moath Posted January 4, 2010 Report Share Posted January 4, 2010 What size spacers are you running with those wheels? Should be a fun build. Great color. Quote Link to comment
sycloned916 Posted January 5, 2010 Author Report Share Posted January 5, 2010 No spacer from what I can see?? Quote Link to comment
sycloned916 Posted January 7, 2010 Author Report Share Posted January 7, 2010 Got the engine bay semi ready firewall and inside have sound deadening spray,rest of the bay has epoxy spray till i finish the battery tray and remove the horn mounts. Then clean up the wiring and get rid of the brake master and get Wilwood tandom brake master and clutch master. Also flipped the crossmember and welded it back up,should have the engine bay finished this week and still waiting for the SR. Quote Link to comment
Just Joel Posted January 7, 2010 Report Share Posted January 7, 2010 Got the engine bay semi ready firewall and inside have sound deadening spray,rest of the bay has epoxy spray till i finish the battery tray and remove the horn mounts. Then clean up the wiring and get rid of the brake master and get Wilwood tandom brake master and clutch master. Also flipped the crossmember and welded it back up,should have the engine bay finished this week and still waiting for the SR. What sound deadening product did you use for the fire wall? Thanks Joel Quote Link to comment
sycloned916 Posted January 7, 2010 Author Report Share Posted January 7, 2010 What sound deadening product did you use for the fire wall? Thanks Joel DEI Boom Mat #050220 from Summit Quote Link to comment
sycloned916 Posted January 13, 2010 Author Report Share Posted January 13, 2010 So after waiting for my engine, I had to go pick it up at Saia's shipping yard,but its here and almost ready to go in. Yesterday pulled the a/c,P/S all the unwanted brackets,downpipe,hoses and any thing else i'm not gonna use. Taking a look at the wiring my harness has two plug,were my red top had three,Hum! Once i get new motor mounts I'll pull the ex manifold and turbo and drop it in and figure out what to do for the header. When to PnP with a buddy on here today and got a 240sx sending unit minus the pump for the tank. The engine bay is drying now layed some gloss black was going to do bronze but didn't like it. Also going to try to run a top mount IC from a sentra see if that works,if not I'll just run a FMIC. Quote Link to comment
playsnmud Posted January 13, 2010 Report Share Posted January 13, 2010 I think they shipped the motor to the wrong place, Nice build I will be tracking this thread Quote Link to comment
bonvo Posted January 13, 2010 Report Share Posted January 13, 2010 epic man i can only imagine what it would be like to have 2 sr powered monsters in the same garage Quote Link to comment
sycloned916 Posted January 15, 2010 Author Report Share Posted January 15, 2010 Got that Beast in today,took me awhile doing it all alone,but its in. Now i just need the right engine mounts,i tried to use the smaller ones but no go,so I guess i have to go get the taller ones for it. Soon as the engine is bolted in I'll make the tranny mount and start looking into the manifold/turbo situation. But It's In. Pulled the tank found the two hidden bolt in the back,and going to drop the 240sx sending unit in get that already. And then start the wiring,got the 70amp breaker and now have to cut the hole for the harness and mount some relays/breaker and it will be getting closer to running! My homewoek is to read the pin outs for the 91-93 and the 96-98(I think these yrs) to find the fuel pump relay for the harness. Quote Link to comment
78kingcab Posted January 15, 2010 Report Share Posted January 15, 2010 nice work.....both your rides are bad ass :cool: Quote Link to comment
sycloned916 Posted January 25, 2010 Author Report Share Posted January 25, 2010 Need some options on the IC set-up, I don't mind running a A2A on the 510,but my buddy has me looking into a W2A using a 1in radiator in the front and a extra 5-8gal. Ice box in the trunk. Not to sure yet,I still have a ways to go before I pick but its up in the air still. Quote Link to comment
sssr20det510 Posted January 25, 2010 Report Share Posted January 25, 2010 Use the a2a you can pic up an evo intercooler for 100 bucks fits good and cheap Quote Link to comment
sycloned916 Posted January 26, 2010 Author Report Share Posted January 26, 2010 Motor and tranny are sitting in nice, I made my own tranny mount using some thick round bar and square tube,thing is solid. Filled the rest of the tranny tunnel up and layed down some Fatmat,now its ready for carpet. Summit will be here tomorrow with my fuel lines,muffler,fittings and exhaust/waste gate piping. Got the header on waiting on a turbo. BOV and wastegate got here the other day its a turbonetics evo wastegate and a turbo xs-rfl bov,should be loud. Cut the hole out of the tank for the 240sx sending unit,now just have to order a walbro. Its been cold/wet so I'm moving kinda slow. Quote Link to comment
sssr20det510 Posted January 26, 2010 Report Share Posted January 26, 2010 You going to be able to fit exhaust with that tranny crossmember looks like it will hang way down Quote Link to comment
sycloned916 Posted January 26, 2010 Author Report Share Posted January 26, 2010 Ya it will clear,when i was making it I had some extra exhaust pipe to check,if not I'll press the pipe to oval it abit,work on my syclone. Quote Link to comment
sycloned916 Posted March 4, 2010 Author Report Share Posted March 4, 2010 Started back on my 510 figured not another Dam 510 all i see is 510 swaps, but got the IC in,semi wired and some other stuff done. Should be running real soon been alittle lazy. Quote Link to comment
ichorid Posted March 4, 2010 Report Share Posted March 4, 2010 what IC is that it looks like it fits perfect. Quote Link to comment
sycloned916 Posted March 4, 2010 Author Report Share Posted March 4, 2010 One on ebay it's 27x7x2.5in. fits good in the front and i still have room for a 3in. radiator and i was able to put the grill all back on with out really cutting too much. Quote Link to comment
78kingcab Posted March 4, 2010 Report Share Posted March 4, 2010 oh yaaa.....lol nice build, not everyday someone drives 2 states to buy a turbo l 69 dime drives it home to tear it apart and sr swap it...gotta love it.... :cool: Quote Link to comment
sycloned916 Posted March 5, 2010 Author Report Share Posted March 5, 2010 Sometimes i think i should have left it alone,but that carb and choke was pissing me off. I only drove the 510 for two days, back from oregon and to dmv for reg's,I miss driving it. Quote Link to comment
sycloned916 Posted March 20, 2010 Author Report Share Posted March 20, 2010 Almost there got alot done this week but still need afew more things. Quote Link to comment
BayArea510 Posted March 20, 2010 Report Share Posted March 20, 2010 One on ebay it's 27x7x2.5in. fits good in the front and i still have room for a 3in. radiator and i was able to put the grill all back on with out really cutting too much. Last week I picked up the same size intercooler from eBay too! I wanna run the intercooler just like you any tips u can help me with. Your Turbo also looks very much like the one I got what type of turbo is it? What did you have to cut?? Quote Link to comment
sycloned916 Posted March 20, 2010 Author Report Share Posted March 20, 2010 Last week I picked up the same size intercooler from eBay too! I wanna run the intercooler just like you any tips u can help me with. Your Turbo also looks very much like the one I got what type of turbo is it? What did you have to cut?? I had to cut some of the radiator core by the headlight holes abit, I trimmed the front grill to clear the IC by the tanks. Was not to bad to fit it. Tubro is a turbonetics with a different compressor housing. Exhaust housting is a stage 3 port matched for the header should spool nice. Quote Link to comment
