ratsun members map
tnip
  • Replies 91
I dont have the NWDE map link but heres one for the classic datsun yahoo group.................
http://www.frappr.com/classicdatsunpickups/map
A few of the guys on the CD map are on Ratsun already. Looks very simple to create a new map for Ratsun peeps.
well i though it would be easy... but i'm having trouble with coding. anybody know anything about that? i have a basic knowledge of html. i tried a few simple things but couldn't get it to show up right.
here is the code for the one i setup:
[url="http://www.slide.com/pivot?cy=un&ad=0&id=576460752325871345&map=5"][img=http://widget-f1.slide.com/c1/576460752325871345/un_t001_v000_a000_f00/images/xslide1.gif][/url] [url="http://www.slide.com/pivot?cy=un&ad=0&id=576460752325871345&map=6"][img=http://widget-f1.slide.com/c2/576460752325871345/un_t001_v000_a000_f00/images/xslide6.gif][/url]
it's from slide.com, here's the link to what it looks like: http://www.slide.com/r/dpiCj8xX1D8WMhhtaWzQEIeHEmBjA0Yp
which works well enough, but i wanted it to be embedded here.
if anybody knows how to make this as an embedded thingie let me know.
from the other comments i had also setup a frappr map, but same issue with coding.
oh, you can only do pictures on a forum. The forum does not use HTML code.
The link should be fine. I worked for me. I added myself.
again, Frappr is crap. :D but that site used to work.
you wanna throw the link up there in the first post? i apparently can't edit it after replys have been made. just delete the text there and put the link in place, or do whatever you want.. haha
edit: apparently you already did that... nevermind
by the way, if anybody has any issues with this map or needing to change or delete it or anything... contact me, cause i set it up with my email address, and i'm the only one that knows the password... mwuhahahah... unless an admin wants it then they'll have it.. ha
