DRIVEN Posted October 5, 2009 Report Share Posted October 5, 2009 Here's the victim: Rather than posting in the suspension section, I thought I would go directly to the target audience. As you can see stance is an issue. The rear has 2" blocks and I like the way it looks but haven't driven it enough to know if clearance is a problem. The front is what I'm concerned with. I don't even know for sure that these are even 510 struts/springs. It sits about 2" higher (measured from the spindle up to the fender lip) than my other wagon. They both have L-motors and 4-speeds. After hours of searching here and on the realm, this is what I plan to do: -280zx struts/brakes -1990ish MR2 rear strut inserts -cheap eBay coilover kit -RCAs -braided hoses -15/16" 280zx master Here are my questions: -Which is better - RCAs? or relocating the LCA mount points on the crossmember? -Do the Z32 and 240sx share the same 2" strut tube diameter as the 280zx? (These are some eBay options) -Will my 13" wheels fit over the 280zx brakes? Keep in mind that this won't be a track-car. If anyone has ANY input or suggestions please set me straight before I screw this up. Quote Link to comment
Just Joel Posted October 6, 2009 Report Share Posted October 6, 2009 How low do you plan to go? I'm curious if the mr2 inserts might be to short if you only plan to drop it a couple inches... Later Joel Quote Link to comment
benzo Posted October 6, 2009 Report Share Posted October 6, 2009 if you can get MR2 inserts for a good price go that way. as for coil overs be careful as sometimes you do get what you pay for. at least find out what coil rates they are using. as for the the control arms if that is what you are talking about I would not move them but get bump steer spacers. as for if the 13" wheels will fit not sure as some wheels do and some don't over zx brakes. the only 13's I know would be panasports or some jdm wheels depends on offset. I would consider moving up to 14" as tire choices are more abundant but then again a good looking set of 13's are nice at times. you should consider changing all the bushings and suspension items like ball joints and tie rods and for sure get alignment good luck Quote Link to comment
SIXTY-NINE-DIME Posted October 6, 2009 Report Share Posted October 6, 2009 if you can get MR2 inserts for a good price go that way. as for coil overs be careful as sometimes you do get what you pay for. at least find out what coil rates they are using. as for the the control arms if that is what you are talking about I would not move them but get bump steer spacers. as for if the 13" wheels will fit not sure as some wheels do and some don't over zx brakes. the only 13's I know would be panasports or some jdm wheels depends on offset. I would consider moving up to 14" as tire choices are more abundant but then again a good looking set of 13's are nice at times. you should consider changing all the bushings and suspension items like ball joints and tie rods and for sure get alignment good luck i dont believe 13's will clear at all. no matter how much offset you have Quote Link to comment
RoadRace Posted October 6, 2009 Report Share Posted October 6, 2009 (edited) going on personal experience, fitting 13" rims over the 280zx brakes is not very easy, but i have heard that it can be done. the ID of the rim is not the problem and i think you only need 11.5 inches of ID on the rim (going from memory). the brake caliper interferes with the back of the vertical face of the rim and prevents the wheel from sitting flush on the hub. i had minilites that were very close - i had to grind .150 - 200" off the front corner of the caliper to get the wheels on. i didn't feel the risk was worth it and i went to 14's. re:ebay coil-overs. be careful as the springs are junk. they will collapse. probably easiest to go to a circle-track supply place like Coleman racing. The circle track guys change shocks/springs every race and Coleman (there are others i'm sure, Bicknell Racing if your north of the border) sells the threaded sleaves and stuff for pretty cheap. re: 280zx master cylinder - it works with 2 mods. 1) trim the little overhanging lip on the firewall above the m/c as it interferes with the m/c reservoir. 2) adapt the 510 pushrod and clevice to work with the 280zx m/c. The 510 pushrod is captive and the 280zx is not - so it takes a little work, but it works great in the end. Edited October 6, 2009 by RoadRace grammar, added text Quote Link to comment
mklotz70 Posted October 6, 2009 Report Share Posted October 6, 2009 ...subscribed! :) The new wgn is a WAAAAAAY better one to fix up!! :) As for the rims.....you know you want to switch to 5 lug!! ......if only cause you feel bad that I still have the struts sitting in my shed!!! :) geez....just seeing another wgn project makes me want to get off the computer and go work on mine......................give me a min......I'm sure it will pass! :) Quote Link to comment
datzenmike Posted October 6, 2009 Report Share Posted October 6, 2009 Put a heavier KA or VG in there.... that'll bring the front down. It may already have uncut zx struts in there. Quote Link to comment
DRIVEN Posted October 6, 2009 Author Report Share Posted October 6, 2009 Put a heavier KA or VG in there.... that'll bring the front down. It may already have uncut zx struts in there. There is a heavier engine swap planned but probably not till next winter. I was hoping that it did have zx struts in it but the calipers look more like a 510 to me. The Nissan # on the strut housing is 54302 UO551. I guess I'll have to dig out the zx struts and compare them. Then I can test fit the wheels too. If they don't fit does anyone know if the steel roadster wheels (14's?) will fit. I like the look of the steelies with the small caps. Thanks for the heads-up on the eBay coilovers. I'm a slow learner so it probably won't deter me. Suggestions on spring rates for the L-motor setup? Quote Link to comment
DRIVEN Posted October 6, 2009 Author Report Share Posted October 6, 2009 re: 280zx master cylinder - it works with 2 mods. 1) trim the little overhanging lip on the firewall above the m/c as it interferes with the m/c reservoir. 2) adapt the 510 pushrod and clevice to work with the 280zx m/c. The 510 pushrod is captive and the 280zx is not - so it takes a little work, but it works great in the end. That's what I did for the disc conversion on my brother's 521. Are there other m/c alternatives that make more sense? BTW, I just glanced at your fleet info. The clue to my top secret engine swap is there!:thumbup: Guys, I appreciate all the guidance here. I'm completely green when it comes to 510s so please excuse any stupid questions. I HAVE been doing a lot of research but there is tons of conflicting info out there and I just want to get this right. This is gonna be my wife's driver. She keeps saying she is going to join Ratsun but I'm not sure why. I'm doing the work. How many different times can she say "I picked the color"?:lol: Quote Link to comment
72dyme Posted October 6, 2009 Report Share Posted October 6, 2009 Are you going to go the 3.8 v6 turbo? Quote Link to comment
DRIVEN Posted October 6, 2009 Author Report Share Posted October 6, 2009 Cannot confirm or deny:cool:. There was a guy on the realm who was doing a 3800 swap but stalled at the exhaust/steering point. He hasn't posted in a while. I'd like to see how it turned out. Quote Link to comment
72dyme Posted October 6, 2009 Report Share Posted October 6, 2009 That would be a sweet set up, but good luck with your project. Quote Link to comment
