just fooling around (VH45DE in the engine bay)
sean1978
  • Replies 17
ironic lynch and i were talking about this the other day now that ive seen it in the hole i can see the firewall would need to be modded for a rad in a 510 but the 610 has more forward room then a 510 hmmmmmm(gears start spinning) would need ot relocate brake master and the typical x- member flip but that looks to be about it along with mounts
Edited by bonvo
is ur buddy going to use the z32 adaptor and use the z32 5 speed transmission or the automatic that it comes with?
info:
VK45DE-
Dry Weight: 236.5 kg = 522 lbs.
Size(mm) (L x W x H): L= 921mm W= 692 mm H= 778mm
Size (inches)(L x W x H): L= 36.25” W= 27.25” H= 30.6”
VH41DE-
Dry Weight: 260 kg = 573 lbs.
Size(mm) (L x W x H): L= 850mm W= 680mm H= 760mm
Size (inches) (L x W x H): L= 33.5” W= 26.75” H= 29.9”
info:
VK45DE-
VH41DE-
smaller in every way but weighs more wtf :blink:
info:
VK45DE-
