Icehouse Posted September 9, 2009 Report Share Posted September 9, 2009 From what I've heard it's a Nismo RB flywheel. I don't know if it's true so I figured I would ask. Maybe someone has a link to a sight that sells the same flywheel. I want to pick up a clutch for it and use it with my LZ22. Quote Link to comment
datzenmike Posted September 9, 2009 Report Share Posted September 9, 2009 (edited) Geez. Is it the same diameter so the starter will work on it?? Is the starter ring at the same offset so the starter will reach it?? Measure the clutch contact diameter for the size... looks big like 240mm. And thin!!! 4 1/2 lbs? http://i138.photobucket.com/albums/q251/datzenmike/Tranny/flywheel240mmthree2Large.jpg[/img]"] Edited September 9, 2009 by datzenmike Quote Link to comment
Icehouse Posted September 9, 2009 Author Report Share Posted September 9, 2009 I think everything will work out fine offset and gear wise. I will double check before I order the clutch. I just want to know it I can actually get a clutch before I spend the extra time. Quote Link to comment
dat u racing Posted September 10, 2009 Report Share Posted September 10, 2009 4 1/2 lbs. !! I need one of those !! Quote Link to comment
SHADY280 Posted September 10, 2009 Report Share Posted September 10, 2009 looks like the aluminum one i got, its disc is the same a z car, but the pp is too big for the flywheel. i could find a pp, so if you do let me know Quote Link to comment
Icehouse Posted September 10, 2009 Author Report Share Posted September 10, 2009 I think this one is chromoly, my guess is 14lbs or so. I haven't tried fitting any clutches we have laying around because I'm worried about the step. I'm also not sure if I removed it if removing that much mass would make it weak. Quote Link to comment
CorAce Posted September 10, 2009 Report Share Posted September 10, 2009 Summit's got a grip of clutch kits for nissans. Quote Link to comment
datsunaholic Posted September 10, 2009 Report Share Posted September 10, 2009 Clutch isn't gonna be the problem, it's the pressure plate that's gonna be a bear. I'd find the RB pressure plate, assuming that it's the same spacing as a stock RB, and the thickness of the clutch plate. If it's the same thickness, then you just match diameter and use whatever clutch plate meets both measurements. Well, clutch COULD be a problem if there isn't one that fits the RB pressure plate and has the right number of splines for the input shaft, but I think they're the same. Quote Link to comment
Icehouse Posted September 10, 2009 Author Report Share Posted September 10, 2009 I think your right Doug I should be able to find any random disk as long as it's the right diameter and spines. I just don't want the pressure plat pressing with a million pounds of force if it isn't designed for the step. I do have huge muscles so I don't want to make them bigger. Quote Link to comment
Jester Posted September 11, 2009 Report Share Posted September 11, 2009 That is cool. Keep us posted as to what you find out. Quote Link to comment
