73super Posted October 5, 2007 Report Share Posted October 5, 2007 Trying to get one of my drums of is proving difficult. The brake adjuster doesn't seem to want to budge for me to bring the shoes in so I can pull the drum. Any ideas? The other one came off no problem. It had the holes in drum for screws to assist in drum removal.. the "difficult" one does not. I've ordered new drums, but need to get this bugger off first. Help oh wise ones. Butch.:eek: Quote Link to comment
banzai510(hainz) Posted October 5, 2007 Report Share Posted October 5, 2007 to loosen to up rotate the wheel upward. sometimes need to get to screwdrivers or a brake adj tool. If you get it off make sure no to be cheap and get some antiseize compound and tab the threads so you can adjust the brakes ezer next time. BELIEVE ME!! Most drums can just get turned. also if alot of oily brakes then the outermain seal is bad and axle needs to be pulled to replace it. That hole on the drom is the seep hole if oil is outside of that then it needs replaced Quote Link to comment
73super Posted October 5, 2007 Author Report Share Posted October 5, 2007 I guess I'll just have to try a little harder. No oil to speak of, just grime. It's looks like it's been awhile since these things have had any kind of attention. Thanks for the info. Quote Link to comment
copacetickid Posted October 5, 2007 Report Share Posted October 5, 2007 One of my brake adjusters was hard to turn; I eventually found a spot underneath where I could use a screwdriver against the brake housing as a lever to turn the wheel. Hard to find around all the suspension though. Quote Link to comment
datzenmike Posted October 6, 2007 Report Share Posted October 6, 2007 Make sure the E brake for that wheel is nice and loose. If you are replacing the shoes, nothing to loose spraying a can of WD-40 in the adjuster hole. Get as much on the adjuster itself and leave overnight. Too much prying can snap the star wheel cogs off. Give the drum a few good single handed smacks with a 6 lb sledge hammer around the lug bolts. Don't hit them and wear hearing protection. As a last resort use a propane torch and heat the star wheel through the adjuster slot. Get it as hot as you can and then quickly pry on it. I did this on a frozen one in a vice and it worked, should work on the truck. Used white lithium grease on assembly. It doesn't dry out and seals out dirt and moisture, not affected by break heat. Quote Link to comment
tnip Posted October 6, 2007 Report Share Posted October 6, 2007 i had trouble with all four of my drums... found a 3lb deadblow (? the one with sand in it) rubber mallet that helped me out... spinning backwards, cracking it good around the edges... Quote Link to comment
datzenmike Posted October 6, 2007 Report Share Posted October 6, 2007 Maybe lead shot? Quote Link to comment
tnip Posted October 6, 2007 Report Share Posted October 6, 2007 idk... i just know its built in so as to prevent bounce back which puts strain on your wrist and wastes energy Quote Link to comment
mklotz70 Posted October 7, 2007 Report Share Posted October 7, 2007 I wouldn't recommend the torch....if there's brake fluid in there, you could end up with some trouble. If you already ordered new drums.....take a 4" grinder with a thin cutoff wheel and cut around the outer front edge...where the front part rolls over to the side. ...hhmm...sparks may do the same as the torch :) The front piece should come off pretty easy, then you can get at the adjuster....or put a cut in the side piece...either way, you'll have it off. Quote Link to comment
tnip Posted October 7, 2007 Report Share Posted October 7, 2007 what? you're worried about starting a fire? ... pffft Quote Link to comment
mklotz70 Posted October 7, 2007 Report Share Posted October 7, 2007 There's at least 3 extinguishers around my shop and one in a couple of datsuns.....too much to lose in my shop!!! :) Quote Link to comment
datzenmike Posted October 7, 2007 Report Share Posted October 7, 2007 I just have a garden hoes 10 feet away. Good idea, Mike. Like life insurance, you pay for something you never intend to use, weird, huh? I'll talk to my wife, maybe she can get me one through her work (safety supplies), chuckle. Quote Link to comment
73super Posted October 8, 2007 Author Report Share Posted October 8, 2007 A garden hoe'.. ???? My wife would kill me!:P Quote Link to comment
73super Posted October 10, 2007 Author Report Share Posted October 10, 2007 Well I finally got it off. Yes, I did have to cut it off. My word what a pain in the Keester. Thanks for all the useful (and other) tips that cha gave me.. much appreciated. :D Quote Link to comment
