Phil's 510 2 door. The tranny 68
Hey Phil I have the same kit on my wagon and I have fit 15"x6" +15 Panasports over them without an issue its all based on the inside design of the wheel and where they mount the wheel weights
Clayton
Cool! Because I'm liking panasports or longchamps. Think I should run the booster with this set up?
  • Replies 730
Those are the 12.2" rotors on stock 510 hubs with 4 piston Wilwoods .... . . I had the wheel weights in the wrong spot with 16x8 panasports and the weights hit the calipers
the 16x7 Panas had a better design for clearance ... .. .. and the rear rotors are 11.5" 300zx floating rotors and 2 piston Wilwoods ... 15's would probably fit
Indy has 16's...
I personally dont like boosted brakes ( I want to remove the booster from my KC)I like getting feedback from the pedal...
here are a few pics of my old 510 with the 12.2 rotors and wilwoods behind 15" Panasports
Nice! There they are. Thanks
Had to pull the dent before i replace the rotted rocker. From the door to wheel well. Sealed both sides. Pics only show the patch panel though. And welded all the rocker trim holes
Now the fun part begins...bodywork
The shell is in primer !!! Finished up the front half of the quarter. Then atom helped me seal the floor pans.
The floor pans weren't bad at all. Had to wire wheel it all . The sandblaster didn't like por15
Laid down the carbon fiber filler as my base. Then regular filler to smooth it out. Hate rockers. Dust always seem to land in my face
Next step is finishing up the engine bay and painting that!
I am curious phil, or anyone who knows... I see it primered in gray, then the last photo shows black and gray. How/whats that about? Did you shoot some black on there and sand it down some to make sure its smooth/straight?
yeah usually people do like a rough over coat to check for high/low spots when you start blocking out the body
  • 2 weeks later...
Parts progress !!! These past few weeks I've been up and down the west coast scouring parts. Even had some brought down from Canada eh. Thanks to Byron, boaty, slodat,Hector,Jose, and huge thanks to Michael spreadbury for the much needed 68 hood hinges and the trunk lid.
Oics of the loot!
