WTB U67 head
  • Replies 12
Heh, it worked well for smog Hainz! Passed clean with dual SU's and a high lift cam on the first try on mid grade pump gas! Now, if you want to make some power, it isn't the greatest though ....
I figured as much Hainz. Being the slowpoke I am, the W58 worked fine for me. I have to pull the L20b because it's leaking oil all over, not because it's burning anything or is too slow. I just figure if I have to dismantle the beast I'll switch over to a A87 head on it and up the compression a bit....
