philip1 Posted July 30, 2009 Report Share Posted July 30, 2009 I've had this car for several years but haven't done much with it till now. I've swapped the blown z20s for a z22s to give a bit more torque. I plan to add a weber carb for a little more power. I've lowered it a bit for slightly better handling and much better looks. The exhaust has been upgraded to 2.25in from the cat back. I've also upgraded the wheels from 13 inch to 15 inch. Other than these changes the car is stock including an automatic transmission. OK on to photos Quote Link to comment
Edz280zx Posted July 30, 2009 Report Share Posted July 30, 2009 Car looks good! Quote Link to comment
philip1 Posted July 31, 2009 Author Report Share Posted July 31, 2009 it will get better as I go too. I'm currently looking for some 90s era maxima seats in blue for this so I'll have a nice perch. I am also possibly going to add a turbo for that extra grunt every car needs. handling wise I'm on the hunt for 200sx s110 sway bars and a set of good shocks/struts. I may possibly in the future swap a 5-speed in for better milage/performance. Quote Link to comment
datzenmike Posted July 31, 2009 Report Share Posted July 31, 2009 The NAPS engine is perfect for a turbo with exhaust on one side and intake on the other. The limitations of the head are nothing to a turbo. See if you can find the EFI set up for the 200sx Z22. It should handle 5-7 lbs of boost, any more and you will need better fuel management. The optional FS5W63 dog leg 5speed was only made for 2 years for your car, '80 and '81. Might be better to convert it over and run 720 or '80-'83 200sx FS5W71B 5speeds in it. You would have to shorten the drive shaft and mod the tranny mount but it's more plentiful and a stronger tranny if using a turbo. Quote Link to comment
philip1 Posted July 31, 2009 Author Report Share Posted July 31, 2009 I think I'll stay carburated and blow through that. I have some help from a dimer in Canada who has been running and developing a blow through carb for about 30 years. I think for now the auto will stay just because I'm not rich enough to have a driveshaft made. these autos are tougher than you think I had a friend who ran this trans behind an L20 turbo that saw regular NO2 runs at close to 500hp. I will not even come close to that I'm aiming at sub 200hp and hammer reliable. Quote Link to comment
turbojunker Posted July 31, 2009 Report Share Posted July 31, 2009 I like yours a lot more than mine. Quote Link to comment
datzenmike Posted July 31, 2009 Report Share Posted July 31, 2009 I think I'll stay carburated and blow through that. I have some help from a dimer in Canada who has been running and developing a blow through carb for about 30 years. Yes, I know Keith. Can't argue with 250-ish RWHP L20B right? (well I assume it's at least an L20B block) Quote Link to comment
philip1 Posted July 31, 2009 Author Report Share Posted July 31, 2009 you should you hooked me up with his advice. Quote Link to comment
datzenmike Posted August 1, 2009 Report Share Posted August 1, 2009 So many posts, so many members... Quote Link to comment
philip1 Posted August 1, 2009 Author Report Share Posted August 1, 2009 that was meant to say thanks for the contact Quote Link to comment
datsunfreak Posted August 2, 2009 Report Share Posted August 2, 2009 (edited) I think I'll stay carburated and blow through that. The EFI is cheaper. And probably easier. :P I think for now the auto will stay just because I'm not rich enough to have a driveshaft made. If you can't afford $70-90, you might have the wrong hobby. :D You don't have to have a new one made, you just have to have yours shortened by a competent driveshaft shop. ;) Edited August 2, 2009 by datsunfreak Quote Link to comment
datsunfreak Posted August 2, 2009 Report Share Posted August 2, 2009 Oh, and I love your car. :D Quote Link to comment
philip1 Posted August 2, 2009 Author Report Share Posted August 2, 2009 The EFI is cheaper. And probably easier. :P If you can't afford $70-90, you might have the wrong hobby. :D You don't have to have a new one made, you just have to have yours shortened by a competent driveshaft shop. ;) the last driveshaft I had made cost me closer to $250. I am working on a very limited budget being unemployed. Quote Link to comment
datsunfreak Posted August 2, 2009 Report Share Posted August 2, 2009 the last driveshaft I had made cost me closer to $250. I am working on a very limited budget being unemployed. What do you mean by "had it made"? All new, or they shortened it? Quote Link to comment
philip1 Posted August 2, 2009 Author Report Share Posted August 2, 2009 shortened actually. I vowed to never do that again. Quote Link to comment
datzenmike Posted August 2, 2009 Report Share Posted August 2, 2009 that was meant to say thanks for the contact And you're welcome.... I meant I just forgot. :o Quote Link to comment
philip1 Posted August 3, 2009 Author Report Share Posted August 3, 2009 I've been thinking about this for some time. I've been thinking about a diesel conversion for this something along the lines of a sd22 out of the 720 truck with the 5 speed. add a turbo and shoot for 100hp. It would be cool to get close to 40 mpg and still pull hard. Quote Link to comment
bonvo Posted August 5, 2009 Report Share Posted August 5, 2009 the last driveshaft I had made cost me closer to $250. I am working on a very limited budget being unemployed. good god man:eek::eek::eek: i had my driveline lengthend and it only cost me $100 and im in california the place that did yours raped dry man Quote Link to comment
philip1 Posted August 6, 2009 Author Report Share Posted August 6, 2009 That is why I am avoiding any drive shaft changes for a while. What really made me mad was I had a vibration after all that money. Quote Link to comment
datzenmike Posted August 6, 2009 Report Share Posted August 6, 2009 The drive shaft may be fine, only the angle out of the tranny and into the diff don't match. Maybe shim the tranny mount. Quote Link to comment
philip1 Posted August 6, 2009 Author Report Share Posted August 6, 2009 I ended up yanking it and installing a stock autobox shaft and the vibration went away. Quote Link to comment
philip1 Posted August 7, 2009 Author Report Share Posted August 7, 2009 (edited) If I can do it I will trade out the gas z22s for a sd22t and look at a gearing change for 3.15:1 or so. I will retain the auto but swap the vac modulator for the one on the max diesel. Edited August 7, 2009 by philip1 Quote Link to comment
