72wagun Posted June 22, 2009 Report Share Posted June 22, 2009 I've been looking for a doner with a L20b and a 5 speed, and I spotted this on craigs list. I got it for $350 and drove it home. I'm planning to eventually put this in the 72 wagon. I wasn't sure how much difference the L20 would be over my L16, but this thing really goes. The truck is pretty rough, but almost all the sheet metal forward of the bed is rust and dent free. Jester will probably end up taking parts for his KC. Quote Link to comment
datzenmike Posted June 22, 2009 Report Share Posted June 22, 2009 The L20B is 2cm or about 3/4" taller (block height) You will need the 510 oil pan on it. If the L20B has a U-67 head, swap the intake and exhaust from your L16 onto it. If it has the W-58, run what's on it and join the L20B down pipe to the L15 exhaust syatem. (just my opinion) I'm guessing it's a '77??? or earlier with a 5spd swap. Quote Link to comment
72wagun Posted June 22, 2009 Author Report Share Posted June 22, 2009 It's got the U67 head. Not sure what head is best performance wise for the L20, but from what I've read, this one isn't bad? It was listed on CL as a 78, but I didn't think to check to data plate or title. I have barely had time to even look at the truck. Quote Link to comment
banzai510(hainz) Posted June 22, 2009 Report Share Posted June 22, 2009 300$ for that truck. I think I would just roll the truck and find another L20 to build up on the side. Quote Link to comment
izzo Posted June 22, 2009 Report Share Posted June 22, 2009 check your pms I want that truck, ill give up mine. has l20b with dogleg behind it. also have rebuilt engine sitting on a stand. pm me back and ill get you a phone # Quote Link to comment
72wagun Posted June 22, 2009 Author Report Share Posted June 22, 2009 check your pms I want that truck, ill give up mine. has l20b with dogleg behind it. also have rebuilt engine sitting on a stand. pm me back and ill get you a phone # pm'ed you back Quote Link to comment
72wagun Posted June 22, 2009 Author Report Share Posted June 22, 2009 300$ for that truck. I think I would just roll the truck and find another L20 to build up on the side. This makes four datsuns sitting around for me:blink: I don't have much room for extra cars, and I want to keep the wagon and 521. The KC will go to good use though. I plan to go through the L20. Not sure if I'll do a full rebuild. Depends what I find inside. Quote Link to comment
Jester Posted June 23, 2009 Report Share Posted June 23, 2009 I hate to tell you, but, it will be coming to my house. :fu: Quote Link to comment
yello620 Posted June 23, 2009 Report Share Posted June 23, 2009 Looks like a 78 to me. Remote igniter distributor and square reservoir on the master cylinder for the front brakes are the two things i looked at. Oh and the cover over the relays on the passenger fenderwell, but i dont know what year those started. Jester, you packrat Quote Link to comment
Jester Posted June 23, 2009 Report Share Posted June 23, 2009 Luke knows I have been looking for another cab. Mine is pretty hammered on the roof line. Plus, I can strip it to the frame and start over with a clean slate. The build date on this truck is 12/77. It was probably sent out as a 78. Quote Link to comment
Bandit240 Posted June 23, 2009 Report Share Posted June 23, 2009 You west coast people just don't know how lucky you really are. If a 620 or even a 720 KC showed up around here in that good of shape and that cheap, i would snatch it up. But no, everything over here is rusted or just beat to hell. Quote Link to comment
Jester Posted June 23, 2009 Report Share Posted June 23, 2009 Aside from the bed and gate this one is pretty good. The floors appear good and the top of the cab has just a couple small dents. Unlike my current cab. It looks like a Saint Bernard was playing up there. :lol::lol: Quote Link to comment
datzenmike Posted June 23, 2009 Report Share Posted June 23, 2009 (edited) It's got the U67 head. Not sure what head is best performance wise for the L20, but from what I've read, this one isn't bad? It was listed on CL as a 78, but I didn't think to check to data plate or title. I have barely had time to even look at the truck. Looks like a 78 to me. Remote igniter distributor and square reservoir on the master cylinder for the front brakes are the two things i looked at. Oh and the cover over the relays on the passenger fenderwell, but i dont know what year those started. It has a '78 grill. (could have been changed) U-67 head was used on L20Bs up till the '78 model year. Could be a '78 with a U-67 swapped on... look behind the distributor... you can see the water return line from the intake is disconnected and the end plugged. A U-67 head doesn't have the holes in it for intake manifold heat. The intake and exhaust are bolted together like this: http://i138.photobucket.com/albums/q251/datzenmike/L%20Z%20Heads%20and%20Motors/620headU-67Large.jpg[/img]"] ... plus the U-67 has square exhaust ports so the matching manifolds would have been used. Maybe the whole motor was swapped. The U-67 and W-58 are basically the same head... square exhaust on the U-67 and round on the W-58. The W-58 also has steel exhaust liners that might restrict flow somewhat but they are removable. Yes the rearmost master cylinder reservoir is square for the '78 model year and on. How do you tell it's a remote igniter? That black terminal block with the Red and Black wires was used from '76 on. If it has a voltage regulator then it's a '77. (can't tell in the picture) If it has disc brakes it's a '78. Edited June 23, 2009 by datzenmike Quote Link to comment
datzenmike Posted June 24, 2009 Report Share Posted June 24, 2009 The build date on this truck is 12/77. It was probably sent out as a 78. Missed this post. Anything after August '77 is a '78 model year. Head or motor must have been changed. Quote Link to comment
72wagun Posted June 24, 2009 Author Report Share Posted June 24, 2009 (edited) I forgot to mention it in my first post, but the PO said that he put that head on about 3 years ago. He said as far as he knew, everthing else was pretty much stock (except for the weber of course. Oh, and the custom airhorns :lol:). He said that the truck had been handed down through 3 brothers with him being the last. Datzenmike, As Jes said, it's got disc brakes. It sounds like it matches up with everthing you described for a 78. The intake and exhaust look like your picture. No external regulator either. Several connections around the intake and exhause manifolds are capped, crimped, etc. Looks like no one bothered to hook up the electric choke either. The guy said it's pretty cold blooded. Well... duh! I'll post some more pics so you can see how bad the bed is. I think the cab is in really good shape though. Edit: On second look, the exhaust and intake are a little different than your picture they are not actually bolted together like that. Edited June 24, 2009 by 72wagun Quote Link to comment
yello620 Posted June 24, 2009 Report Share Posted June 24, 2009 Yes the rearmost master cylinder reservoir is square for the '78 model year and on. How do you tell it's a remote igniter? That black terminal block with the Red and Black wires was used from '76 on. QUOTE] Mike, My 76 did not have that little black box on the corner of the radiator with the Red and Black wires. And the only trucks that i have seen that on is Remote igniter trucks. Quote Link to comment
72wagun Posted June 24, 2009 Author Report Share Posted June 24, 2009 Here are some more pics. Tailgate's a little rough. Closeup of the manifold that was discussed. Seats appear to be original but in vintage condition. Notice custom shifter! Some nice features: Custom airhorn system. Chrome wheels. Misc. stickers already applied (not shown: Metallica and Choppers forever stickers). Quote Link to comment
72wagun Posted June 29, 2009 Author Report Share Posted June 29, 2009 Some pics from this weekend. Not sure when I'll have a chance to work on it, but at least it's out and on a stand. Had to twist it to the side a little to clear the pulley. Same with the pan. Jes had some bailing twine laying there, so used it to get the flywheel off. Quote Link to comment
