Greiggy Posted September 9, 2007 Report Share Posted September 9, 2007 hey all, just wondering if you guys have any sources on whole front end bushes for the 620. im in austalia, but would like an international source as i cant get them over here. anyone able to help? thanks Quote Link to comment
yello620 Posted September 10, 2007 Report Share Posted September 10, 2007 Are you talking about all the suspension BUSHINGS? Or are you referring to something motor related? If it is suspension related, I should be able to get you part numbers for new parts. Jason Quote Link to comment
Greiggy Posted September 10, 2007 Author Report Share Posted September 10, 2007 yeah basically all the bushes for the front suspension. thanks Quote Link to comment
banzai510(hainz) Posted September 11, 2007 Report Share Posted September 11, 2007 http://www.rockauto.com/ I use this website to cross ref and for the photos of the part. havent ordered to much from them myself. Quote Link to comment
]2eDeYe Posted September 12, 2007 Report Share Posted September 12, 2007 I plan to get a hardbody poly bushing set. I'm hoping most of the bushings and body mounts are the same. They seem to be close to the same from '78 up through the frontiers. Quote Link to comment
Z-train Posted September 12, 2007 Report Share Posted September 12, 2007 2eDeYe;18347'']I plan to get a hardbody poly bushing set. I'm hoping most of the bushings and body mounts are the same. They seem to be close to the same from '78 up through the frontiers. Let us know as i need to do my truck also. Quote Link to comment
yello620 Posted September 13, 2007 Report Share Posted September 13, 2007 1978/79 620's share the same upper and lower bushings as the 720's. Energy suspension part #7-3101 covers the upper and lower control arms of the 1980-1986 720's. Not sure if the strut rod bushings were the same or not, will try to look that up tomorrow. Jason Quote Link to comment
Z-train Posted September 13, 2007 Report Share Posted September 13, 2007 What about sway bars?:cool: Quote Link to comment
yello620 Posted September 14, 2007 Report Share Posted September 14, 2007 What diameter bar are you running, and what size bolts are used in the endlinks, And what is the bolt spacing for the frame mounted bushings. Are you looking at getting urethane or rubber? Jason Quote Link to comment
Z-train Posted September 14, 2007 Report Share Posted September 14, 2007 Stock 620 bar.Urethane if possible. Quote Link to comment
yello620 Posted September 16, 2007 Report Share Posted September 16, 2007 http://www.energysuspension.com/pages/swaybbct.html Take a look at this page for sway bar bushings for the 79 and older 620's. Sorry, i dont know off the top of my head what size the stock sway bar is. Jason Quote Link to comment
PtheDude Posted January 23, 2008 Report Share Posted January 23, 2008 Anyone know where I can get some new / better rubber for my front end? Quote Link to comment
hang_510 Posted January 23, 2008 Report Share Posted January 23, 2008 http://www.suspension.com/nissancars.htm Quote Link to comment
]2eDeYe Posted January 23, 2008 Report Share Posted January 23, 2008 to bad it's not nissantrucks.html :( Quote Link to comment
yello620 Posted January 24, 2008 Report Share Posted January 24, 2008 All the rubber bushings are still available at most parts stores. If they tell you they are not available it is only because they dont want to look them up. These counterman nowdays think that just cause the computer doesn't list a part that it must not be available. Jason Quote Link to comment
djmoreron Posted February 13, 2008 Report Share Posted February 13, 2008 good to know. im about to do all the bushings on the front end of my 77kc. ill post part numbers when i get em... Quote Link to comment
Javin Posted May 9, 2011 Report Share Posted May 9, 2011 Does anyone actually have all the part numbers for the new rubber/polyurethane bushings to redo the rubber on the front end of the 620s (78)? My metal is still good... my rubber is just toast. Would rather replace the rubber instead. Yes, necro post Quote Link to comment
