Phirus Posted May 15, 2009 Report Share Posted May 15, 2009 I'm wanting to switch to electronic ignition on my 75 620 (l20b). Where do I start? I don't know the basics of it, all I know is it should increase performance and reduce maintenance. Plus I think it would be a good combo with a set of pulsar plugs on my birthday wish list. I still use the same coil right? cause I'm working on getting a 60k volt mallory. (I think that's the brand) So Can someone tell me what I need to buy and kinda step by step walk me through it? thanks peoples. Quote Link to comment
izzo Posted May 15, 2009 Report Share Posted May 15, 2009 search is ur friend :D Be sure to check out the FAQ and how to, then search. but below is a link to get you started. http://forum.ratsun.net/showthread.php?t=11828 Quote Link to comment
izzo Posted May 15, 2009 Report Share Posted May 15, 2009 (edited) I was talking to Bagged_Datsun last night about this change over, check this out. points to electronic is easy basically all the same just take out the resister for teh coil and change the dizzy they are very simple doing the swap fron Edited May 15, 2009 by h2theizzo Quote Link to comment
Phirus Posted May 15, 2009 Author Report Share Posted May 15, 2009 When I say I dont know the basics I truley mean it lol Quote Link to comment
Phirus Posted May 15, 2009 Author Report Share Posted May 15, 2009 So.. I need to find a matchbox distributor? Anyone have a link? It's kinda hard to search for without a SHITLOAD OF HOTWHEELS ADDS. Quote Link to comment
izzo Posted May 15, 2009 Report Share Posted May 15, 2009 one on the left ill try to find u a better pic Quote Link to comment
Phirus Posted May 15, 2009 Author Report Share Posted May 15, 2009 So If I go to a parts store, or a scrap yard, and ask for a matchbox distributor for an l20b 4 cylinder engine, they'll know what to give me? They damn sure won't know what an l20b or a datsun is, might not have even heard of a 4 cylinder lol. Are distrubutors all the same sizes, Just find one for ma 4 cylinder? Quote Link to comment
ggzilla Posted May 15, 2009 Report Share Posted May 15, 2009 and ask for a matchbox distributor for an l20b 4 cylinder engine, they'll know what to give me?Do you really think the average store or wreckers are that good? Only Datsun people say "matchbox". Everyone else calls it a "1978-1982 Datsun electronic ignition distributor". Quote Link to comment
Phirus Posted May 15, 2009 Author Report Share Posted May 15, 2009 Do you really think the average store or wreckers are that good? Only Datsun people say "matchbox". Everyone else calls it a "1978-1982 Datsun electronic ignition distributor". Did you even read the rest of my message :lol: Quote Link to comment
banzai510(hainz) Posted May 15, 2009 Report Share Posted May 15, 2009 the matchbox is pretty much listed as a 79/80 L 20b and you want the mount that goes with it. I say again you want the mount that goes with it. there is a ealier type also but its a remote ignition box. and that another hook up to do which will confuse you more. as for a coil just get a MSD Blaster 2 coil. Its the correct ohm value for the matchbox. You can use the stock coil and ballast set up, you would just hook B on blk box to the + side of the ballast resisitor(blk/wht wire) C to the - side coil. if you want to hook it up with the MSD coil you dont need the ballast as this coil is designed to run a full 12volts. diagram here B of matchbox and the blk.white wire will be hooked up together at coil. if this diagram confuses you. Quote Link to comment
420n620 Posted May 15, 2009 Report Share Posted May 15, 2009 (edited) PAC did a write up just recent, heres the link. http://forum.ratsun.net/showthread.php?t=11828 sometimes you just need to read some of the threads instead of using the search control it's so much more friendlier. edit :::: I just noticed that h2theizzo beat me to the link, O well shit happens :) now put down the bong and geta reading..... :lol: Edited May 15, 2009 by 420n620 shit happens Quote Link to comment
hang_510 Posted May 15, 2009 Report Share Posted May 15, 2009 So.. I need to find a matchbox distributor?Anyone have a link? It's kinda hard to search for without a SHITLOAD OF HOTWHEELS ADDS. i got some of each (used dizzy and hotwheel ;) ) Quote Link to comment
Phirus Posted May 15, 2009 Author Report Share Posted May 15, 2009 now put down the bong and geta reading..... :lol: Make me! Quote Link to comment
Weaver Posted May 15, 2009 Report Share Posted May 15, 2009 Curious, why is it referred to as matchbox dizzy? I'm guessing it's because the ICM looks like a matchbox? Quote Link to comment
hang_510 Posted May 15, 2009 Report Share Posted May 15, 2009 cuz youll use matches to burn the points dizzy after replacing it :lol: Quote Link to comment
datzenmike Posted May 15, 2009 Report Share Posted May 15, 2009 (edited) I'm wanting to switch to electronic ignition on my 75 620 (l20b).Where do I start? I don't know the basics of it, all I know is it should increase performance and reduce maintenance. Plus I think it would be a good combo with a set of pulsar plugs on my birthday wish list. I still use the same coil right? cause I'm working on getting a 60k volt mallory. (I think that's the brand) So Can someone tell me what I need to buy and kinda step by step walk me through it? thanks peoples. Forget the 60 K volt coil! The voltage required to fire a spark plug depends on the width of the gap, how much load it is under (throttle) and the compression ratio. A fast idle of 2,000 RPMs will be easier to fire than full throttle climbing a hill at 2,000 RPMs. The average engine needs only 12K-15K volts to fire the plugs. A high performance motor with high compression up to 20K, a turbo motor 25K. (all at full throttle cylinder filling) No spark plug will fire with the full output voltage available from the ignition system. The coil output does not instantly produce 60K volts. Instead the voltage climbs up from zero. It does so very fast but as soon as it reaches a threshold where it can jump across the air gap of the plug it does so, in effect causing a short to ground. The voltage cannot rise any higher. An L engine needing say 15-20K to fire the plugs will not need a 60K coil. Use the Nissan coil that came with the EI dizzy...it's more than you will ever need. Mallory counts on selling selling these things to people who think more (or shiny) is better. Btw: Plugs are plugs. Stock NGK are the best for the money. If the after market 'platinum/iridium multi-gap split fire resistor plasma' plugs were significantly any better, Nissan would use them from the factory, don't you think? Edited May 15, 2009 by datzenmike Quote Link to comment
hang_510 Posted May 15, 2009 Report Share Posted May 15, 2009 ... counts on selling selling these things to people who think more (or shiny) is better. you mean its not true? :eek: shiny = more HP than 2 stickers! Quote Link to comment
Weaver Posted May 16, 2009 Report Share Posted May 16, 2009 ^Yep, and ground effect kits add at least 20 HP, right? :lol: cuz youll use matches to burn the points dizzy after replacing it :lol: Ha, I have a 79, so no need. :fu: Quote Link to comment
Phirus Posted May 16, 2009 Author Report Share Posted May 16, 2009 Forget the 60 K volt coil! The voltage required to fire a spark plug depends on the width of the gap, how much load it is under (throttle) and the compression ratio. A fast idle of 2,000 RPMs will be easier to fire than full throttle climbing a hill at 2,000 RPMs. The average engine needs only 12K-15K volts to fire the plugs. A high performance motor with high compression up to 20K, a turbo motor 25K. (all at full throttle cylinder filling) No spark plug will fire with the full output voltage available from the ignition system. The coil output does not instantly produce 60K volts. Instead the voltage climbs up from zero. It does so very fast but as soon as it reaches a threshold where it can jump across the air gap of the plug it does so, in effect causing a short to ground. The voltage cannot rise any higher. An L engine needing say 15-20K to fire the plugs will not need a 60K coil. Use the Nissan coil that came with the EI dizzy...it's more than you will ever need. Mallory counts on selling selling these things to people who think more (or shiny) is better. Btw: Plugs are plugs. Stock NGK are the best for the money. If the after market 'platinum/iridium multi-gap split fire resistor plasma' plugs were significantly any better, Nissan would use them from the factory, don't you think? I'm getting the high performance plugs and high voltage coil because I'm running Hydroxy. Quote Link to comment
datzenmike Posted May 17, 2009 Report Share Posted May 17, 2009 I'm getting the high performance plugs and high voltage coil because I'm running Hydroxy. Is that like Brown's Gas or HHO? The jury is still out on that. On the face of it it's snake oil like the 'Turbonator' http://www.turbonator.com/ Why has no one done a serious scientific test on this and settled this once and for all? But still it hangs on like an urban myth. One thing is for sure, the amount of gas produced produces less energy than that needed to make it. Quote Link to comment
Phirus Posted May 17, 2009 Author Report Share Posted May 17, 2009 Is that like Brown's Gas or HHO? The jury is still out on that. On the face of it it's snake oil like the 'Turbonator' http://www.turbonator.com/ Why has no one done a serious scientific test on this and settled this once and for all? But still it hangs on like an urban myth. One thing is for sure, the amount of gas produced produces less energy than that needed to make it. Not true.. I can put out 2 liters a minute drawing 5 amps. Won't find another one like it. People who mass produce they're units are to lazy to do any research, they're units suck! I have a couple people wanting to buy the units we make (including a guy from this site) but I'm not sure about putting them out till I patent the design, it's unique. Quote Link to comment
hang_510 Posted May 18, 2009 Report Share Posted May 18, 2009 Not true..I can put out 2 liters a minute drawing 5 amps. Won't find another one like it. the energy required to generate the oxyhydrogen always exceeds the energy released by combusting it (as paraphrased by DM) more H can be genenerated from ammonium (NH4+) than H20 why not just join the H revolution and produce a motor that runs on H? Quote Link to comment
