GERMS Posted April 17, 2009 Report Share Posted April 17, 2009 Greetings! Took the nice sunny day to search me a radiator for my 620...found a whole lot of volvos, their recent 90s nd up radiators were recommended to me...did find myself a nice one. Got an electric fan with shroud only to know its about an inch too thick! pulley in the way... what setups do you guys have in ur 620s if any? pics? Do I really need an electric or mechanical wihtout shroud is fine? If I can fit the electric fan in the front is that recommended? Cheers! Quote Link to comment
bonvo Posted April 17, 2009 Report Share Posted April 17, 2009 go to the parts store and but a slim line or get one off ebay reversable blade (can but put in front or back) nice and thin and moves alot of air Quote Link to comment
GERMS Posted April 17, 2009 Author Report Share Posted April 17, 2009 (edited) go to the parts store and but a slim line or get one off ebay reversable blade (can but put in front or back) nice and thin and moves alot of air Nice nice, my radi is about 18.5" long x 17.5" tall should I get the larget I can fit...and maybe 2" thick? Now the reason I want pictures is because I don't know how exactly u install one...do you need a shroud (the square one that cover the whole square of radiator) and where u screw the fan to or can u use those tie rod dealies that go through the radiator and just hold the round fan close to the radiator? The one I bought needs the shroud so that makes it like 4" thick...man...it was nice looking too Edited April 17, 2009 by Germz12 Quote Link to comment
ariascarlos1990 Posted April 17, 2009 Report Share Posted April 17, 2009 keep your stock radiator and get a temp probe switch. works like a charm :D Quote Link to comment
GERMS Posted April 17, 2009 Author Report Share Posted April 17, 2009 keep your stock radiator and get a temp probe switch. works like a charm :D I bet it does! But didn't have a radiator and compared to stock the volvo radiators are crossflow, which cool somewhat to more better...plus I believe it has a thermal sensor built in...wonder if I can make it work... Quote Link to comment
ariascarlos1990 Posted April 17, 2009 Report Share Posted April 17, 2009 I'm sure you could. its a pain getting the stock fan clutch assembly off though. Mine still isen't totaly off. :D Quote Link to comment
zed Posted April 17, 2009 Report Share Posted April 17, 2009 I tried replacing the stock mechanical fan with an electric fan on my Toyota. The only place the fan fitted was in front of the rad - as a 'pusher'. It didn't work - I wasted a lot of money and time on it. The fan blocked airflow to the rad, so the car ran hot - so the fan stayed on, which drained the battery. It was a 30 amp Bosch S-bladed fan. I even upgraded the alternator to try to run it... no work Quote Link to comment
jovial_cynic Posted April 17, 2009 Report Share Posted April 17, 2009 zed - you sure the electric fan was the problem? Unless you had a tiny radiator and a monstrous fan, I can't imagine that the fan would block significant airflow while you drove the car. As far as the fan "staying on" and draining the battery, this wouldn't be an issue while the car was running, since I don't believe the fan draws a continuous 30 amps while on. If you're saying that the fan stayed on while the engine was turned off - yes, the fan would run off the battery, but you wouldn't have any air flow issues, since the fan would be sucking ambient air from the front of the car towards the radiator, and the radiator shouldn't take that long to cool down. I can't tell exactly what your setup was like, but it sounds like you might have had something wired improperly (perhaps your thermostatic switch was faulty, causing the fan to stay on?), or something else. I swear by electric fans, and can't really imagine a situation in which a similarly sized electric fan would be less preferable to a pully-driven fan, whether in front or behind the radiator. Quote Link to comment
Pacific coast Datsun Posted April 17, 2009 Report Share Posted April 17, 2009 Could you possibly trim the shroud where its hitting the pulley? Ive heard either a pusher or puller is fine. Should be able to hook it up to the temp. sensor on the rad.so it turns on at certain temps or....a switch you flip when you turn the truck on. Quote Link to comment
ariascarlos1990 Posted April 17, 2009 Report Share Posted April 17, 2009 Heres the simplest/cost efficient setup to my opinion. its what I have on my 620: Quote Link to comment
slodat Posted April 17, 2009 Report Share Posted April 17, 2009 Which fan is that? Quote Link to comment
ariascarlos1990 Posted April 17, 2009 Report Share Posted April 17, 2009 To be honest I don't know. It was just laying on the ground at U-Pull it next to a Volvo it might of been from it....... Quote Link to comment
GERMS Posted April 17, 2009 Author Report Share Posted April 17, 2009 Could you possibly trim the shroud where its hitting the pulley? Ive heard either a pusher or puller is fine. Should be able to hook it up to the temp. sensor on the rad.so it turns on at certain temps or....a switch you flip when you turn the truck on. I dont believe I can, the fan's motor is popping out by too much, and the shroud is not trimmable, only has half an inch in depth. I'm just gonna get a 2 to 2.5 maybe 3" slim fan, and wire up the thermal sensor on the radiator...if that doesnt work I'll buy one from the parts store...nice ideas. I will difenitley start a build thread and document everything I do with lots of pictures. I'll show hoe great of a replacement these volvo radiators are, and they are plentyfull at the yard, the inlet and outlets are the same as our stock ones and are very light. Quote Link to comment
GERMS Posted April 17, 2009 Author Report Share Posted April 17, 2009 Heres the simplest/cost efficient setup to my opinion. its what I have on my 620: I am sure those carquest sensor work nice, I've installed one on a impala before. Nice steup there! Quote Link to comment
ariascarlos1990 Posted April 17, 2009 Report Share Posted April 17, 2009 It does work nice. and the price is cheap Quote Link to comment
lynchfourtwenty Posted April 17, 2009 Report Share Posted April 17, 2009 It does work nice. and the price is cheap sweet you can come do that for me!!! hehehe Quote Link to comment
ariascarlos1990 Posted April 17, 2009 Report Share Posted April 17, 2009 how about this... I put electric fans in your truck and you swap my tranny's. :D deal? Quote Link to comment
lynchfourtwenty Posted April 17, 2009 Report Share Posted April 17, 2009 lmao!! what all are you waiting on anyway? skib said he had some shit for ya.. Quote Link to comment
ariascarlos1990 Posted April 18, 2009 Report Share Posted April 18, 2009 I'm waiting for him to finish is turbo swap so I can meet him at PIR. your comming to right? Quote Link to comment
lynchfourtwenty Posted April 18, 2009 Report Share Posted April 18, 2009 not until i get my header back and exhaust, the exhaust is orderd just waitin on it to arrive, nismopu an hks_john are doin some work to my header Quote Link to comment
ariascarlos1990 Posted April 18, 2009 Report Share Posted April 18, 2009 I see. We'll it needs to hury. :D Quote Link to comment
lynchfourtwenty Posted April 18, 2009 Report Share Posted April 18, 2009 i know i know :( i wont get my muffler till the 21st.. not even sure on the exhaust.. and the header is pretty much whenever kyle an john can get to it, until then my car aint goin no where Quote Link to comment
