datsun 160J SSS Posted April 16, 2009 Report Share Posted April 16, 2009 can anyone tell me what the water temp should be on the L18 ? I would like to run an electric fan when should it turn on and off ? and what temp tstat should I use ? Quote Link to comment
ggzilla Posted April 16, 2009 Report Share Posted April 16, 2009 (edited) It can be whatever you want it to be. Typically they run a gasoline engine from 160 degrees to over 212 degrees. Performance street cars often are run with 180 degree thermostat. That is also the optimum temp for motor oil in most older engine designs (oil runs about 20 degrees hotter than the coolant). Less pinging on regular gasoline too. Most emission-controlled engines are run hot, 212 degree thermostat, which requires a radiator pressure cap to prevent boiling. This also makes the radiator more efficient (can use a smaller radiator, the hotter it runs). Fan setting I'm not sure. It probably should be set a bit higher than the thermostat but not much higher. Edited April 16, 2009 by ggzilla Quote Link to comment
ariascarlos1990 Posted April 16, 2009 Report Share Posted April 16, 2009 just set your switch to the temp needle. I just waited for my truck to warm up until the temp needle is in the center of the gauge then set the fan to kick on then. Hope this helps. Quote Link to comment
bonvo Posted April 16, 2009 Report Share Posted April 16, 2009 just set your switch to the temp needle. I just waited for my truck to warm up until the temp needle is in the center of the gauge then set the fan to kick on then. Hope this helps. x2 works like a charm :thumbsup: Quote Link to comment
datzenmike Posted April 16, 2009 Report Share Posted April 16, 2009 Temp sensor should be low in the rad or on the return to block hose. Generally, if you are moving above 20-30 MPH there will be enough air passing through the rad from vehicle speed for cooling. If the sender is too close to the engine top hose the fan will trigger all the time. Give the rad a chance to cool the water first. My switch is spliced into the middle of the lower rad hose and uses an '86 CA20 200sx sensor. All I did was cut out about 2" and gear clamp in. Quote Link to comment
ariascarlos1990 Posted April 16, 2009 Report Share Posted April 16, 2009 yeha mine is close to the lower radiator hose. Hey datsunmike do you have yours wired through your ignition? do you think its needed? Quote Link to comment
datzenmike Posted April 17, 2009 Report Share Posted April 17, 2009 yeha mine is close to the lower radiator hose. Hey datsunmike do you have yours wired through your ignition? do you think its needed? I think it should be hot all the time. After a very hot day (110) in traffic you pull into the hot parking lot and shut her down and walk into Wall Mart. (whatever) The residual heat soaks into the coolant and sends it sky high. Pressure rises, hoses bulge, rad cap gets ready to vent. Now would be a good time for the electric fan to come on and blow some of that heat away. I don't know if there would be enough convection circulation to reach the lower sensor or not. I know my dad's old Sundance fan will come on after shut down, but very rare and has to be very hot out. Quote Link to comment
ariascarlos1990 Posted April 17, 2009 Report Share Posted April 17, 2009 I have mine wired straight up to my battery. So when I turn my truck off it cools the temp. of coolent in the radiator. warms up alot faster also. :D Quote Link to comment
Icehouse Posted April 17, 2009 Report Share Posted April 17, 2009 Temp sensor should be low in the rad or on the return to block hose. Generally, if you are moving above 20-30 MPH there will be enough air passing through the rad from vehicle speed for cooling. If the sender is too close to the engine top hose the fan will trigger all the time. Give the rad a chance to cool the water first. My switch is spliced into the middle of the lower rad hose and uses an '86 CA20 200sx sensor. All I did was cut out about 2" and gear clamp in. Mike the S12 temp switch is my trick!!!! :D Quote Link to comment
datzenmike Posted April 17, 2009 Report Share Posted April 17, 2009 Mines an '86 CA20 I think. And if that copies you, just remember: imitation is the sincerest form of flattery. :D Quote Link to comment
