Guest Rick-rat Posted April 15, 2009 Report Share Posted April 15, 2009 My valve cover bolts on my L 16 keep coming loose, took all the bolts out tonight without a need for a wrench, tigtened them down with socket last time when it was cold and retightened the bolts when it was was warm. Has anyone else had this happen? Should I put a little locktite on the bolts when I put it back on? thanks Rick-rat Quote Link to comment
datzenmike Posted April 15, 2009 Report Share Posted April 15, 2009 Easy, those are aluminum threads and will pull out. Are you using a good gasket or that RTV crap? Quote Link to comment
Guest Rick-rat Posted April 15, 2009 Report Share Posted April 15, 2009 I am using a good gasket, this is not the first time this has happened Quote Link to comment
ggzilla Posted April 15, 2009 Report Share Posted April 15, 2009 It is normal that you need to tighten them a little about every six months. Do not overtighten or it will get looser even more quickly. Quote Link to comment
Skib Posted April 15, 2009 Report Share Posted April 15, 2009 lol and dont break em :rolleyes: its not fun Quote Link to comment
Guest DatsuNoob Posted April 15, 2009 Report Share Posted April 15, 2009 Maybe try a little rtv on the ends of the bolts? Quote Link to comment
72240z Posted April 15, 2009 Report Share Posted April 15, 2009 Maybe try a little rtv on the ends of the bolts? For that though why not lock tight/thread lock w/e? I mean rtv would prob work by why not use the proper thing. Have you tried retorquing them prior to them loosing up substantially again? Some cars require it but after the retorquing they hold. Quote Link to comment
ggzilla Posted April 15, 2009 Report Share Posted April 15, 2009 For the valve cover bolts? All cars I've had, Datsun, Chrysler, Ford or GM, requires periodic re-tightening. Except for engines with a one-piece bead seal. Don't fix it if it aint broke. Quote Link to comment
72240z Posted April 15, 2009 Report Share Posted April 15, 2009 For the valve cover bolts? All cars I've had, Datsun, Chrysler, Ford or GM, requires periodic re-tightening. Except for engines with a one-piece bead seal.Don't fix it if it aint broke. Ya me too but in my experience over time that gasket gives way when you do that. I had some weeping on my d21 and when I retorqued the gasket got all cracked up. Just an example of what I mean. Cork prob holds up way better but still constant required retorquing is unacceptable to me. Some of my past cars like the bimmer called for a 1 time re tq. Quote Link to comment
Guest DatsuNoob Posted April 15, 2009 Report Share Posted April 15, 2009 For that though why not lock tight/thread lock w/e? I mean rtv would prob work by why not use the proper thing. Have you tried retorquing them prior to them loosing up substantially again? Some cars require it but after the retorquing they hold. You may want to be able to get them off some day, right? I've found that using rtv on bolt ends works well, without the super aggresive bond like loctite. Everyone knows how easy Datsun bolts shear off I'm sure. Quote Link to comment
athoose Posted April 15, 2009 Report Share Posted April 15, 2009 Put some anti-seize on them and see if it helps. Quote Link to comment
72240z Posted April 15, 2009 Report Share Posted April 15, 2009 You may want to be able to get them off some day, right? I've found that using rtv on bolt ends works well, without the super aggresive bond like loctite. Everyone knows how easy Datsun bolts shear off I'm sure. Actually I never had a problem getting bolts out with anti seize on so I didn't think of it that way. I wouldn't argue with you about ti but I honestly think if that a prob just a little dab would be fine. No? Quote Link to comment
hang_510 Posted April 15, 2009 Report Share Posted April 15, 2009 not had a problem before...how 'bout using lock washers? Quote Link to comment
Madness Posted April 16, 2009 Report Share Posted April 16, 2009 lockwire? if you want to go all out. Quote Link to comment
