odmanjohnson Posted April 13, 2009 Report Share Posted April 13, 2009 (edited) picked up this little orange dat for 100 bucks put a hitatchi carb on it drove it, lowerd it and then put a carrier bearing in it cause i couldnt take the driveshaft wallering around anymore when id take off. then i got this crazy idea, i would put a set of 4 mikuni sidedraft (i think 26-28mm) motorcycle carbs on it. got the intake built put the carbs on it runs!! but will not go above approx 1/4 throttle without spitting and sputtering and will not go anymore. low rpms going up my driveway it pulls real hard but nothing over 2000 rpms. Any ideas?? i already checked for leaks at all the appropriate spots with carb cleaner and didnt find any... Edited April 13, 2009 by odmanjohnson Quote Link to comment
808DA6 Posted April 13, 2009 Report Share Posted April 13, 2009 How healthy is the bottom end? Pretty sure you've got to be pulling good vacuum to run quads. -Brian Quote Link to comment
72 327 Posted April 13, 2009 Report Share Posted April 13, 2009 (edited) You may have to rejet the carbs. The cfm on the carb maybe to low. When it sputters does it smell like gas? Check the plugs if there wet there is a issue with the carbs dumping too much fuel. I have a big feeling those came off something about 600-1000 cc not enough CFM. Way bigger jets will be required to run it right. Your engine should be 1600cc to 1800cc depending if its stock or not. So saying those are 1000 cc carbs you will have to jet 60% more to get enough fuel. Thats if the carbs can supply enough air to make them work. Edited April 13, 2009 by 72 327 Quote Link to comment
lynchfourtwenty Posted April 13, 2009 Report Share Posted April 13, 2009 ya if its not getting the amount of gas /air it needs to rev it wont work, not sayin this setup wont work. Quote Link to comment
datzenmike Posted April 13, 2009 Report Share Posted April 13, 2009 Prob lean. If you have chokes on it try applying some and see if it will rev a bit higher. If yes, this would point in the right direction. Quote Link to comment
lynchfourtwenty Posted April 13, 2009 Report Share Posted April 13, 2009 each one of those carbs needs to provide enough fuel to each 500cc cylinder the engine has, wonder what size cc the engine was that those came from, and does the engine they came from use 4 or only 2 carbs?? also maybe a balance tube might help in tuning Quote Link to comment
LCDC Posted April 13, 2009 Report Share Posted April 13, 2009 Wow, how many times have I thought of running motorcycle carbs on a datsun motor. Hope you get it to work. did the slots come with the truck? pretty good deal if they did. I picked up a set of slots for 150 bucks. Quote Link to comment
tdaaj Posted April 16, 2009 Report Share Posted April 16, 2009 i finally get to see it, we'll gewt that body cleaned up for ya. slots look good on there. Quote Link to comment
72240z Posted April 16, 2009 Report Share Posted April 16, 2009 Hasn't Zuum been running R1's for a while now? Quote Link to comment
Bleach Posted April 16, 2009 Report Share Posted April 16, 2009 welcome back Odman. You do good fab work. Quote Link to comment
Icehouse Posted April 16, 2009 Report Share Posted April 16, 2009 Hasn't Zuum been running R1's for a while now? He sold that car, I saw it at Golden Gardens with the new owner. :( He'll be back :D Quote Link to comment
KFD Posted April 16, 2009 Report Share Posted April 16, 2009 Have the carbs been synched...? I had that problem with the mikunis on my Katana, and my SRAD. I got tired of that and got an Aprilia. No more carb problems! KFD Quote Link to comment
72240z Posted April 18, 2009 Report Share Posted April 18, 2009 He sold that car, I saw it at Golden Gardens with the new owner. :( He'll be back :D Ah that sucks, so much for me going to suggest asking him for pointers lol. Quote Link to comment
odmanjohnson Posted April 21, 2009 Author Report Share Posted April 21, 2009 after i asked you guys for help i took them back off and drilled out the jets i think to a number 53 drill from about a number 40. it actually drives!! its still kinda slow but hey at least i can say i did it. I may need to go just a hair bigger yet but we'll see. I also Just need a couple of parts for the 32/36 and it will probably be goin on soon. Quote Link to comment
tdaaj Posted April 21, 2009 Report Share Posted April 21, 2009 what parts do you need, i found a box full when we were moving Quote Link to comment
