92 -
Plusnone's Achievements
https://shopdeftones.com/collections/all-merchandise/products/goon-squad-puff-embroidered-hat its a deftones song, but thought you some of y'all with goons might be interested
I used this, the. resold it on craigslist for 3/4 the price https://a.co/d/hjQ77PB EDIT : sorry, actually reread the above anD saw your issue was that it is lowered. I recall having the car on jack stands with the suspension in droop and not having any issue. maybe used the jack under an arm to keep it located. Do you not have enough travel?
Put on new sway bar bushings, end links and tightened down the seat mounts with my soon to be 13 year old. Also got insurance and took it off non-op... Hope to putt around the block soon No idea why the photos are coming in upside down
THIS ADVERT HAS EXPIRED!
- FOR SALE
- NEW
So I pm'd mklotz70 about his downpipe flanges, but sadly he no longer sells them. He graciously provided a link to his site with further links to CAD and pdf of the dimensions. I took the CAD and uploaded to sendcutsend.com To get above the minimum order without additional fees, I ordered 3. I will keep 1 and sell the other 2 at $20 shipped continental US. Cost for 1 (not meeting the min.) is $17+ from sendcutsend.com so its cheaper than you could do through them. Ordering 3 brings the cost to $11.65 per. not sure what shipping will be but I think $20 shipped is reasonable and covers my time at the post office... Estimated ship date to me was 7/12. I'd turn them around as soon as I get them. Let me know if you are interested and mods, please remove if this crosses any lines. paypal or venmo when I have them in hand cheers,$20
, California
Plusnone started following Just another (LOOK AT ME!!!) 69 DIME build thread. , What do we actually know about semi trailing arms? , Powerland 2021.(II) in the books and 3 others
Code: 153888544141183628 Thank You for Being a RockAuto Customer for over 3 Years! Using your discount code is easy! Enter your discount code in the 'How Did You Hear About Us?' box without any other numbers or characters for an additional 5% savings. Discounts cannot be applied once an order is marked as shipped. Your code expires on December 6, 2020, 12:00 Midnight CT, so do not wait! SHOP NOW
Code: 106522079100995235 Thank You for Being a RockAuto Customer! Using your discount code is easy! Enter your discount code in the 'How Did You Hear About Us?' box without any other numbers or characters for an additional 5% savings. Discounts cannot be applied once an order is marked as shipped. Your code expires on June 9, 2019, so do not wait!
this celica is pretty sweet too https://youtu.be/UNJsfLCQWDM?t=366
can someone tell me what this ride is? @ 7:13 https://www.youtube.com/watch?v=UNJsfLCQWDM&feature=youtu.be&t=433 <iframe width="560" height="315" src="https://www.youtube.com/embed/UNJsfLCQWDM?start=433" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Registered here when I was looking to buy my current 510. Had been a lurker forever, but actually needed to ask a few questions. I've had a 260z and a goon prior but for the last 10 years if I had needed to RSVP to a datsun owners gettogether my response would have been plusnone.... 😢😕 I guess technically, I'd be a plus one, now! But doesn't have the same ring to it... Also, the dime is kinda my escape. My time away from wife, kids, work.... so plusnone?
Plusnone replied to 510revisited's topic in Project Datto
Happy New years to you as well. I owe you a response to your pm from a few days back, but I'll chime in here to your questions above as I've just gone through most of this (my project thread is in desperate need of an update...). I'd say if your interested in efi, then tune up your carb first so you have a reliable driver while you piece parts together and can have something to swap back on as you test the efi set up. When you're fully converted, you have a running carb and mani to sell... For the front end, source the 14 mm steering arms and go from there ( or drill out the ones you have? It's a tapered hole). 14 mm ball joints are available from many sources. As for all the other front end bits, rockauto. For the shortened strut, going to 280zx struts gets you larger (and more readily available?) wheel bearings, vented rotors and bigger calipers, and is already a shorter strut body by 1 1/2" if I remember. Unless your wheel won't allow the larger brakes no reason not to go 280zx. They pull the track width in a bit, but this might help depending on how low you are going and can be bumped back out with spacers if not desired) Im currently running 280zx struts but have a shorter insert as I will section those for another 1-2", there are spacers in the strut body for the insert until the sectioning is done. For the rear, if you are going lower you will benefit greatly from adding some adjustment via brackets it slotting at a minimum (there's a few options out there). I've got a bunch of old parts you could use as reference (11 mm ball joints and steering arms for example) 280zx struts with brakes to check wheel clearance, rear chopped springs, extra coilover springs, perches, etc.. Some of the used stuff could be yours for some beers... Others may be for sale, but mostly they are here to check out, measure, etc.. against what you're thinking (no charge, of course). Great progress on the dime!!! I'll follow up with a bunch of links to what I have referenced as I went through this. -
Thank you for being a RockAuto.com customer! To show our appreciation, we have a special discount for you. Your discount code is: 9650818889721679 How to Use Your Discount Code Enter the code above in the "How did you hear about us" box without any other numbers or characters. The discount takes 5% off our reliably low prices. This discount code expires on January 13, 2019 so do not wait!
The aud-dat-citi... All kidding aside, I'm enjoying the build!
Time Left: 2 days and 5 hours
- WANTED
- USED
Hoping someone local has an extra set of control arms they don't need. Also looking for a rear seat in any condition. I'm in the SF Bay area, CA and will drive to you. I'm low on funds but I might have some parts for trade + $. Let me know if your interested, PM me and we'll figure something out. Thanks$5.10
Berkeley, Ca
Nice score! I'll be watching your build! Also, this shot reminded me of my late night gas stop while picking up my 69
