clutch question..... L series god?
  • Replies 28
The L20B has the six bolt pattern, L18 and L16 are five. The measurement is across the clutch disc or its wear pattern on the flywheel.
If you don't have a metric tape:
A 200mm would be 7.88"
A 225mm would be 8.865"
A 240mm would be 9.456"
A six bolt 200mm flywheel can be found on:
'75-'77 710 (L20B)
'75-'76 610 (L20B)
'77-'79200sx (L20B)
'78-'81 510 (L20B & Z20)
'80-'83 200sx (Z20, Z22)
'76-'78 280z coupe
All these flywheels may have different weights.
  • 7 months later...
Well I was looking around the internet and I found that a 240sx clutch will fit the l20b engine? http://www.exedyusa.com/oe/06805A So would a 240sx flywheel fit an l20b engine? The reason I ask is that they sell reduced weight flywheels and aluminums cheap for a 240sx that I would like to install on my l20... Thanks!!!!!!!!
