datman Posted January 24, 2009 Report Share Posted January 24, 2009 found this while searching the net. It's located in Alberta about 4 hrs from me. here's what the seller has to say about it. 1976 datsun 620, most of the bodywork is done, its in grey primer, brand new 16" wheels, new tires front and back, still got the nubs on them, and a second set for the back too, its a bench seat and a standard tranny, its lowered 2" in the front and 3" in the back, recently had motor work done, the head was sent out and rebuilt and now it doesnt run, i checked it out, no compression on cylinders 1 and 4, im guessing that the shop that rebuilt it screwed up or the guy i bought it off put it back together wrong, this truck has a lot of new good parts in it and would be a great project for any aspiring mini trucker! im looking for 1200 bucks. So is it worth the drive? I'd have to haul it back here also since it needs work to get it running. looks like it will need rockers Quote Link to comment
tdaaj Posted January 24, 2009 Report Share Posted January 24, 2009 sounds a bit pricey. i wonder how much of the body work was done, looks beat up and rusty with primer. Quote Link to comment
phatdave Posted January 24, 2009 Report Share Posted January 24, 2009 It's 1200 $? Not running, it would sell around here for maybe 300$ Quote Link to comment
Bleach Posted January 24, 2009 Report Share Posted January 24, 2009 In Canada its tripple the price. Probaby a $900 truck there. These are more rare than an east coast USA 620. Quote Link to comment
Buzzbomb Posted January 24, 2009 Report Share Posted January 24, 2009 Offer him $750 and see what he says.. Primer is a good hider, and that truck probably has holes patched with Bondo. $1200 would be a decent price if the truck was running, but that's too much for one that doesn't run and probably has more filler filled holes than you'd like to see. Quote Link to comment
fisch Posted January 25, 2009 Report Share Posted January 25, 2009 In Canada its tripple the price. Probaby a $900 truck there. These are more rare than an east coast USA 620. I don't know about that Bleach! Well at least a New England 620. I shit you not, I've never seen one on the road here. In fact I've never seen any non Z datsun on the road here. Quote Link to comment
datzenmike Posted January 25, 2009 Report Share Posted January 25, 2009 First of all if you can't drive it, you can't make an informed decision on it. You cant drive it around to see if the brakes work, rear end clunks/whines, driveshaft vibrates, tranny whines, grinds, or even if all the gears are there, if the clutch works, does the engine smoke, knock or over heat, steering, alignment and front and rear suspension is safe. If it doesn't run and you don't know the owner, cut the price in half at least. This is a good rule of thumb to follow. If the owner want's that much for it, it had better run 'real good'. Quote Link to comment
datman Posted January 25, 2009 Author Report Share Posted January 25, 2009 thanks for the help guys. probably going to pick up S10 in the spring if i can't locate a 620. Or maybe a D50. I still be on the look out for a datsun though. Quote Link to comment
sanitys Posted January 25, 2009 Report Share Posted January 25, 2009 (edited) thanks for the help guys. probably going to pick up S10 in the spring if i can't locate a 620. Or maybe a D50. I still be on the look out for a datsun though. couldnt you just do a road trip and pick one up from the westcoast USA? Looks to be about 19 hrs, give or take to seattle. Gas would come to 326 dollars there and back at 2.20 per gallon, and getting 15 miles per gallon. Not all that bad, I had to pay 1100 to get my truck from the westcoast to hawaii Edited January 25, 2009 by sanitys Quote Link to comment
Steroid Posted January 27, 2009 Report Share Posted January 27, 2009 If it wouldn't run, could the distributor be 180 degrees off??? Easy to check. Remember also parts that add up like a carrier shaft bearing and other things like that. Half of what He is asking would be reasonable. My 2 cents........ It's Your journey in this life. If You have ever wanted a 620 and they are hard to find up there, half of Your battle is done. No body else can put a price on Your dreams. If You always wanted one, Your dreams can begin literally by one phone call. How can You put a price on that???? Quote Link to comment
banzai510(hainz) Posted January 27, 2009 Report Share Posted January 27, 2009 no compression on cylinders 1 and 4, valve lash??????? this is a EZ fix. oil pump/dizzy valve lash chain off. Quote Link to comment
