gen4maxima536 Posted January 6, 2009 Report Share Posted January 6, 2009 Anyone know the free length and diameter of the stock rear springs? Quote Link to comment
DISLEXICDIME Posted January 7, 2009 Report Share Posted January 7, 2009 no but if you putt thunder bird springs in the back they are stiffer;) Quote Link to comment
510er Posted January 7, 2009 Report Share Posted January 7, 2009 "510ER, you asked about the stock 510 spring rate...it was around 800 lbs/inch if I remember correctly." Quoted from bertvorgon off of the 510realm. Quote Link to comment
banzai510(hainz) Posted January 7, 2009 Report Share Posted January 7, 2009 http://www.racetep.com/datsunsusp.html Quote Link to comment
Tedman Posted January 11, 2009 Report Share Posted January 11, 2009 Anyone know the free length and diameter of the stock rear springs? Stock 510 rear springs are 357 lb/in per my '72 Service Manual. Free length is 12.047" (LH) and 11.772" (RH). Weird that RH and LH springs are different lengths, but that's what the book says. Coil diameter is 3.543" and coil wire diameter is 0.559". Quote Link to comment
