dreamers_vault Posted January 5, 2009 Report Share Posted January 5, 2009 Im just wondering...can i fit another L series ( L18, L20B ) head on the L16 block? ie : L16 Block + L18 / L20B head ? or L16 Block + L16 Head + L18/L20B cam? if possible...if...which will be the best setup? im not sure about the water jacket or the inlet/outlet size...will it fit? sorry if this a noob question...i really dont know... Quote Link to comment
freaky510 Posted January 5, 2009 Report Share Posted January 5, 2009 yes go with the l20 head Quote Link to comment
banzai510(hainz) Posted January 5, 2009 Report Share Posted January 5, 2009 go to olddatsuns.com http://www.olddatsuns.com/620tech.htm Quote Link to comment
dreamers_vault Posted January 5, 2009 Author Report Share Posted January 5, 2009 (edited) thanks....that is sure need lots of reading... i like :D 1 question...since L20B is hard to get here...so the best option is using the L18 head...but what if i only use the L18 cam on the L16 head? Edited January 5, 2009 by dreamers_vault Quote Link to comment
datzenmike Posted January 5, 2009 Report Share Posted January 5, 2009 Assuming you have performance in mind. The original 219 SSS head would give pretty much the biggest cam, intake port size and valves plus it is a closed chamber head. Alternatively, any closed chamber A-87 head could be converted over into it equivalent, by opening the intake ports out to a larger size. Because you are in Malaysia, and closer to Japan you may be able to acquire a domestic only W-53 closed chamber head and port out the intakes as above. The W-58 from the later L20Bs, was also available with closed chamber (I had one from a '78-'79 200sx) and can be 'converted' like the two above heads. This will involve more work as the exhaust ports have steel liners in them that can or should be removed. The exhaust ports are also round and are not a perfect match to the square exhaust manifold. (but they will work) IF you were to run this head you might also run a round port header to match. The W-58 is considered a smog head, but can easily be de-smogged. Now the reason for the closed chamber head, is to preserve the compression on the smaller L16 motor. An L16 with a closed chamber head will have a compression of 8.39 which is fine. An open chamber head will be 7.8 compression. In both cases the head could be shaved to raise the compression but why not start out in the right spot to begin with. As for a cam, the L20B cam is very close to the L16 SSS cam. I don't know what cam is in the A-87 or W-53 heads, but an L20B cam could be swapped into them. Quote Link to comment
dreamers_vault Posted January 6, 2009 Author Report Share Posted January 6, 2009 thanks for the explanation. :D im thinking of buying this set...im sure its an L18 A-87 Quote Link to comment
Phlebmaster Posted February 15, 2009 Report Share Posted February 15, 2009 It looks like a W58....does it have round exhaust ports? If it does then it is off of an L20. :D Nice head, just has liners in the exhaust ports. Quote Link to comment
dreamers_vault Posted February 15, 2009 Author Report Share Posted February 15, 2009 i've opened up my 510 head...it has the a87 head...is there any way that i can identify the cam model? Quote Link to comment
Phlebmaster Posted February 15, 2009 Report Share Posted February 15, 2009 i've opened up my 510 head...it has the a87 head...is there any way that i can identify the cam model? Not really, unless you are good with a micrometer and math. lol The head in the picture you posted has a W58 on it...that is off of an L20b and if unmolested has an L20 cam in it. I ran a L20 cam in my L16 and notice a bit of improvement. :D Quote Link to comment
datsunfish Posted February 15, 2009 Report Share Posted February 15, 2009 If that is a w58 in the picture then it is a closed chamber version which is great. I believe that if you use the stock square port exhaust then you should leave the liners in place as they should help to guide the air into the runners since the actual opening size is slightly beyond the edge of the square port walls. I have ran a w58 with square mani a few times and it works wonderfully. Quote Link to comment
dreamers_vault Posted February 16, 2009 Author Report Share Posted February 16, 2009 everyone is getting confused...hehe..the picture above is not mine..its on sale while ago that i intended to buy but didnt... so after opened up my L16 head...there is a mark saying A87..:D hmm...there is few mark n words on the cam..but i cant really understand it,,:lol: Quote Link to comment
datzenmike Posted February 16, 2009 Report Share Posted February 16, 2009 (edited) The A87 is a good head for an L16. It was used on larger motors so should breath fine on an L16. Just below and behind the #1 plug is the casting number for the head type. Can you see if yours is like the picture with small kidney shaped combustion chambers??? Called a p-nut head this is preferable to keep the compression up on a smaller L16 motor. Several cam types were used on the L18. However an L20B cam is almost the equivalent of the L16 SSS cam with very similar lift and duration. L20B cams usually have this double casting bump in the center if you find one. There's no wrighting on it but a U60 may be cast in it. Edited February 16, 2009 by datzenmike Quote Link to comment
dreamers_vault Posted February 16, 2009 Author Report Share Posted February 16, 2009 thanks mike...will check on it..:) Quote Link to comment
dreamers_vault Posted February 16, 2009 Author Report Share Posted February 16, 2009 any unusual at that pic? this the comp chamber.. Quote Link to comment
Phlebmaster Posted February 16, 2009 Report Share Posted February 16, 2009 (edited) Not that I can see....is this a trick question like where's waldo? :D Looks like you have a closed chamber A87 head...good one to have. Edited February 16, 2009 by Phlebmaster Quote Link to comment
dreamers_vault Posted February 16, 2009 Author Report Share Posted February 16, 2009 no trick at all..im so noob about L engine..n it was actually a stock engine from my 510..i just want to learn more...:D Quote Link to comment
Phlebmaster Posted February 16, 2009 Report Share Posted February 16, 2009 Hahaha....Sounds like me a year ago. :D You are in the right place to learn. ;) Quote Link to comment
datzenmike Posted February 16, 2009 Report Share Posted February 16, 2009 Has a Nissan combination oil pressure gauge and low oil pressure (red dash light) sender. Can't see very well. Looks like an L20B cam, stock fuel pump. What tranny is that?? Got pix of it? Quote Link to comment
Phlebmaster Posted February 16, 2009 Report Share Posted February 16, 2009 Has a Nissan combination oil pressure gauge and low oil pressure (red dash light) sender. Can't see very well. Looks like an L20B cam, stock fuel pump. What tranny is that?? Got pix of it? My L16 had a U20 cam in it with cam bosses and everything....but it was an L16 stock cam. Wierd! :D Quote Link to comment
dreamers_vault Posted February 17, 2009 Author Report Share Posted February 17, 2009 its a 5 speed tranny..came stock with it...its quite impossible if its from Z tranny..as Z is a very20x rare here.. most probably the tranny is from the 510 itself or PA10 or 910...most of it is a 5 speed. L20b cam? hmm...will try to get a better picture.. Quote Link to comment
datzenmike Posted February 17, 2009 Report Share Posted February 17, 2009 (edited) its a 5 speed tranny..came stock with it...its quite impossible if its from Z tranny..as Z is a very20x rare here.. most probably the tranny is from the 510 itself or PA10 or 910...most of it is a 5 speed. L20b cam? hmm...will try to get a better picture.. Take a picture of the tranny, I may be able to tell you what it ISN'T at least. My L16 had a U20 cam in it with cam bosses and everything....but it was an L16 stock cam. Wierd! :D After almost 40 years things get swapped around a lot. The L20B would be a 'poor man's' L16SSS cam. Edited February 17, 2009 by datzenmike Quote Link to comment
dreamers_vault Posted February 18, 2009 Author Report Share Posted February 18, 2009 here is the tranny pic.. n here is the cam...U20 printed there.. Quote Link to comment
datsunaholic Posted February 18, 2009 Report Share Posted February 18, 2009 U20 is just the base camshaft casting. I've seen plenty of L16s with stock U20 casting cams, and L18s, and L20Bs. Hardly unusual. Tells nothing of the grind. They all started out the same. Early L16 cams were different castings. The transmission is a common F4W63 4-speed. You can tell by the square bottom cover and the waffled external ribs, plus the shifter linkage. Quote Link to comment
dreamers_vault Posted February 19, 2009 Author Report Share Posted February 19, 2009 (edited) so the U20 does not tell the grind? ok ok.. but the tranny is a 5 speed same as my other 510. identical tranny with 5 speed. n its not a dogleg either. Edited February 19, 2009 by dreamers_vault Quote Link to comment
datzenmike Posted February 19, 2009 Report Share Posted February 19, 2009 (edited) It's a 4spd. Pretty durn close: F4W63 http://i138.photobucket.com/albums/q251/datzenmike/Tranny/transshortF4W634spd.jpg[/img]"] Edited February 19, 2009 by datzenmike Quote Link to comment
