slodat Posted July 7, 2007 Report Share Posted July 7, 2007 Experimental Engineering 510 5 speed trans crossmember with Nissan trans mount $125 Professionally shortened and balanced driveshaft for long trans in 510 $100 ZX 5 speed with .754 5th gear $200 Wilwood rear brake setup - brackets, z31 rotors, wilwood 2 piston calipers, pads $450 Wilwood front brake setup for 280zx struts. 12.2" x 1.25" rotors. 4 piston HUGE calipers. Pads. Billet aluminum hats & brackets. All hardware. $750. Aeromotive fuel pressure regulator with VDO pressure gauge & -6AN fittings. $150 Top Motoring rear coilovers. About 3000 miles on them. In great shape. 225# springs. $400 Gauge cluster with tach. Red in color. $200 '68 grill. Not perfect, but will polish up very nice. $150 NOS front hood trim. $75ea Stock 510 fuel tank. Very nice condition. $50 L20b. Recent rebuild (from previous owner). About 3k miles. 1mm overbore. 8.8 compression. Oil pan plumbed for turbo return line. Round port head. Stock cam. Long block with oil pan, early 1600 valve cover with nissan comp oil spray bar. $1000 Lightened 225mm flywheel (Dan Hall machine did the work). Balanced with new Daiken clutch. New T/O bearing. $300 Garret T3 turbo. Zero shaft play. $200 Brand new Blitz blow off valve. $150 Brand new Tial 38mm wastegate. .5 bar spring. $200 The entire L series EFI setup I have put together $1600 - L18E intake. Injectors with custom fuel rail. 60mm throttle body with rod actuator setup All sensors MSII ECU with relay board Wiring kit EDIS setup - trigger wheel, pickup mount, coil pack, etc. It is all there to do the conversion. S12 5 lug entire front suspension, including crossmember & power rack. $200 Another L20b. Was in a car I bought. Was told it was a "performance" build. Not sure what that means. Was pulled because of oil leaks. $100 Adjustable LCA's for 510 with Battle Version adjusters and heim joints. $250 Perfect 510 hood. $100 and you give me your old hood Nice passenger fender $75 Pair of rear 1/4 windows - nice $40 New Nissan later style auto adjusting (280ZX) clutch slave. Steel body not aluminum. $40 New Nissan 510 throw out bearing $25 NOS 510 heater valves. I have one of each style. $75ea Z car day/night mirror. fits z cars and 510. $25 250A AC/DC TIG welder. Complete runner with new 150a air cooled torch with cable cover. New owned bottle (Full). New argon manifold. Very nice machine with digital display. Torch mount current control. $1500. First come, first served. Cash in hand. Call me at 503.933.2967 or PM. Link to comment
DISLEXICDIME Posted July 7, 2007 Report Share Posted July 7, 2007 if only my pockets where super phat right know Link to comment
slodat Posted July 7, 2007 Author Report Share Posted July 7, 2007 2eDeYe;12065'']??? What's the question? Link to comment
]2eDeYe Posted July 7, 2007 Report Share Posted July 7, 2007 Are you selling your car off? Got any picks of the rear coilovers? Curious to see if they'd work in the front of my truck... Link to comment
slodat Posted July 7, 2007 Author Report Share Posted July 7, 2007 2eDeYe;12079']Are you selling your car off? Got any picks of the rear coilovers? Curious to see if they'd work in the front of my truck... yes' date=' my car is listed and yes I am selling it. I have no clue if they work on your truck. Info at http://datsun510.com/shop5/product_info.php?products_id=1 Link to comment
countrydiscount Posted July 8, 2007 Report Share Posted July 8, 2007 Got a good used valnce for a 72 I don't need the new NOS one just a nice used one banged up less than mine......LOL Joe Link to comment
]2eDeYe Posted July 8, 2007 Report Share Posted July 8, 2007 mmm gears are turning... So did you get another 510? You still have the 620 right? Link to comment
slodat Posted July 8, 2007 Author Report Share Posted July 8, 2007 I don't know how else to say it - I am selling all of this stuff. I'm keeping the 620 to get around town for right now. Link to comment
Icehouse Posted July 8, 2007 Report Share Posted July 8, 2007 I want all the stuff your going to give away for free :D Link to comment
SHADY280 Posted July 9, 2007 Report Share Posted July 9, 2007 hmmm too bad, cant afford the 280zx stuff, cause i could use it all. Link to comment
slodat Posted July 9, 2007 Author Report Share Posted July 9, 2007 update parts for sale in first post of thread. added some stuff.. Link to comment
Icehouse Posted July 9, 2007 Report Share Posted July 9, 2007 Do you have wagon leafs to go with the axle? If so I will but it :) Link to comment
slodat Posted July 10, 2007 Author Report Share Posted July 10, 2007 leafs aren't hard to come by are they? Link to comment
slodat Posted July 11, 2007 Author Report Share Posted July 11, 2007 If you are interested in something, act now. Going to start listing things on ebay to speed the process along. Link to comment
BEEBANI Posted July 11, 2007 Report Share Posted July 11, 2007 Dumb question, Steve, do you have any 620 shit? Link to comment
slodat Posted July 11, 2007 Author Report Share Posted July 11, 2007 Nothing comes to mind, other than my 620. Which I'm not currently planning on selling. Link to comment
