shelleyhelley Posted January 17 Report Share Posted January 17 Does anybody know if I take the head off my 1600 521 Datsun truck do I have to use new bolts when I put it back together are they at one time use bolt only? Quote Link to comment
datzenmike Posted January 17 Report Share Posted January 17 Yes, they can be reused if not damaged. Clean the threads and those in the block, wipe bolts with oily rag, make sure the head is flat using a proper straight edge, do not use a sealer or any gasket coatings and away you go. Use a good torque wrench and tighten in this pattern to 20 ft. lbs.... R..A..D 7......8 3......4 1.......2 5......6 9....10 Repeat this pattern to 40 ft. lbs and one last time to 60 ft. lbs. Quote Link to comment
Crashtd420 Posted January 17 Report Share Posted January 17 Also if you are not trying to redo the front cover make sure you read up on blocking the cam chain tensioner..... Common mistake is the tensioner pops out during a head gasket change and it's not realized.... 1 Quote Link to comment
datzenmike Posted January 17 Report Share Posted January 17 Good point I didn't read the first post enough. Yes the chain tensioner must not be allowed to pop out. If it does the whole front of the engine (timing cover, water pump, distributor, oil pump, alternator, radiator) has to be removed to retrieve it... and you have to drain the cooling system and buy a few new gaskets. Quote Link to comment
mklotz70 Posted January 18 Report Share Posted January 18 (edited) This is the chain holder they're talking about. I'm pretty sure it prints 1:1 so you can use it as a template to cut your own from a block of wood. http://www.bluehandsvideo.com/l-series-timing-chain-tension-retainer.html and if you need the manual.... http://www.bluehandsvideo.com/manuals.html Edited January 18 by mklotz70 added link 2 Quote Link to comment
banzai510(hainz) Posted January 18 Report Share Posted January 18 (edited) why take the head off again ? maybe some datsun guy can help live locally Edited January 18 by banzai510(hainz) Quote Link to comment
