Chance Posted January 9 Report Share Posted January 9 I Recently had my some holes in my fuel tank weld repaired (see photo) now it has some light surface rust, i'm gonna get it cleaned but I'm wondering if I should line the tank after or just keep it as is? the tank is in great shape otherwise. Thanks Quote Link to comment
datzenmike Posted January 10 Report Share Posted January 10 Leave it alone. 1 1 Quote Link to comment
MikeRL411 Posted January 10 Report Share Posted January 10 "Perfect" is the enemy of "Good enough", Quote Link to comment
Crashtd420 Posted January 10 Report Share Posted January 10 19 hours ago, Chance said: I Recently had my some holes in my fuel tank weld repaired (see photo) now it has some light surface rust, i'm gonna get it cleaned but I'm wondering if I should line the tank after or just keep it as is? the tank is in great shape otherwise. Thanks If you wanted to now is the time to do it since all the prep work is basically done..... If you do use this product and follow the cleaning and prep instructions for it... It's the same as what professional shops use... I have used it twice myself successfully with no issues after 5 years..... It doesn't even care about the small bit of surface rust... don't get it where you don't want it because it dries quick.... Do you need it, that a matter of opinion.... I'd do it just as added insurance but that's my opinion.... 1 Quote Link to comment
Stinky Posted January 18 Report Share Posted January 18 I'd put 2 fuel filters on, if I were you. Quote Link to comment
