datzenmike Posted December 31, 2023 Report Share Posted December 31, 2023 Look on the engine tag, located on the left or driver's side inner fender, above the coil. A camper conversion company would have (should have) ordered a Cab/Chassis option that comes without the box. Cab/Chassis is an E code. The top of the engine tag would say EHL 620 XXXXX. If not a Cab/Chassis then the camper is on a regular set of truck springs. 2 Quote Link to comment
MrShuford Posted January 1 Author Report Share Posted January 1 Thanks, I will give this a look and report back. Quote Link to comment
MrShuford Posted January 2 Author Report Share Posted January 2 Well I was only able to find the easy one in the drivers door sill. I did not see anything under the hood. Quote Link to comment
datzenmike Posted January 2 Report Share Posted January 2 The driver's door one has been removed and the conversion sticker applied. The engine tag should be riveted on the left inner fender near the coil. For the '78 model year Cab/Chassis production numbers are 310,001 to 375,000 so if the bottom number on your sticker is the old car number then 323,850 is well within that range. 2 Quote Link to comment
Stoffregen Motorsports Posted January 2 Report Share Posted January 2 @paradime - those coilover shocks are good for about five years, then they always go soggy bottom. I would replace them with air bags. Like this kit from Air Ride. https://www.amazon.com/Air-Lift-Company-57399-Loadlifter/dp/B01LZTJN7M/ref=asc_df_B01LZTJN7M/ 3 Quote Link to comment
MrShuford Posted January 3 Author Report Share Posted January 3 I found what looks like the divots for the tag, but it looks like nothing has ever been attached there. 1 Quote Link to comment
MrShuford Posted January 10 Author Report Share Posted January 10 Had to take ChiChi Nooks to CHP to get her VIN verified. 3 Quote Link to comment
MrShuford Posted January 10 Author Report Share Posted January 10 Really hope she passes the smog test this afternoon. 1 Quote Link to comment
MrShuford Posted January 12 Author Report Share Posted January 12 On 12/31/2023 at 7:04 AM, datzenmike said: Look on the engine tag, located on the left or driver's side inner fender, above the coil. A camper conversion company would have (should have) ordered a Cab/Chassis option that comes without the box. Cab/Chassis is an E code. The top of the engine tag would say EHL 620 XXXXX. If not a Cab/Chassis then the camper is on a regular set of truck springs. So when I went to DMV they looked at the stamp on the frame and it had the "E". Would that be the same? Quote Link to comment
datzenmike Posted January 12 Report Share Posted January 12 Yes. The Cab/Chassis begins with an E. A King Cab begins with a K and a regular cab (long or short wheelbase) has no letter 1 Quote Link to comment
Stoffregen Motorsports Posted January 12 Report Share Posted January 12 Did it pass emissions testing? 1 Quote Link to comment
MrShuford Posted January 14 Author Report Share Posted January 14 On 1/12/2024 at 8:08 AM, Stoffregen Motorsports said: Did it pass emissions testing? Yes! Registration is now behind me. That is a huge relief! 4 Quote Link to comment
Stoffregen Motorsports Posted January 14 Report Share Posted January 14 Nice. I wonder, since it is a cab/chassis, does it require a catalytic converter? My cab/chassis Chevy K30 does not. Quote Link to comment
datzenmike Posted January 14 Report Share Posted January 14 California remember???? All trucks for California had cats from Aug. '75. 1 Quote Link to comment
Stoffregen Motorsports Posted January 14 Report Share Posted January 14 Right, except certain cab/chassis models. My K30 is a 1980 and does not require a cat. 1 Quote Link to comment
MrShuford Posted January 14 Author Report Share Posted January 14 There was no cat on this one. 1 Quote Link to comment
datzenmike Posted January 14 Report Share Posted January 14 Because it's not from California. California emissions required them on the 620. Don't know about E code Camper/Cab/Chassis but being California... likely. 1 Quote Link to comment
thisismatt Posted January 15 Report Share Posted January 15 Passed smog with no cat? 1 Quote Link to comment
Stoffregen Motorsports Posted January 15 Report Share Posted January 15 My K30 has a sticker stating that because it's a cab/chassis, it didn't need a cat. 1 Quote Link to comment
thisismatt Posted January 15 Report Share Posted January 15 3 hours ago, Stoffregen Motorsports said: My K30 has a sticker stating that because it's a cab/chassis, it didn't need a cat. Skips the sniffer test also? 1 Quote Link to comment
Stoffregen Motorsports Posted January 16 Report Share Posted January 16 Well, I have never registered it. It stays on the property, used for fire wood, gravel, whatever job needs a dump truck. 1 Quote Link to comment
MrShuford Posted January 17 Author Report Share Posted January 17 This rv has a 4 speed manual and I have a 5 speed I can put in. What are the pros and cons. Should I just leave the 4, will it change the speedo? 1 Quote Link to comment
datzenmike Posted January 17 Report Share Posted January 17 The 5 speed was never offered on the 620 Cab/Chassis. The L20B just doesn't have the torque to effectively use a 5 speed plowing all that air at highway speeds. In fact the Z22 720 didn't either and five speeds were only available on the '83 and up Z24 powered Cab/Chassis. I guess you could try it but it may not be able to maintain highway cruise speeds. 1 Quote Link to comment
Stoffregen Motorsports Posted January 19 Report Share Posted January 19 It may not help all of the time, but it could help to keep the R's down while cruising on flat or downhill sections. 1 Quote Link to comment
Stoffregen Motorsports Posted January 19 Report Share Posted January 19 At least it's not an automatic. Those are power suckers. 1 Quote Link to comment
